0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
5 and 10 30 valvoline conv 1.49 a qt at TS
by Chesterr - 04/04/20 02:34 AM
Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
38 registered members (Bookmaker, bbhero, 1foxracing, Amkeer, c502cid, 6 invisible), 1,181 guests, and 18 spiders.
Topics303,562
Posts5,237,422
Members71,086
Timken Rear Wheel Bearing - Any Good? #5362556 02/28/20 03:47 PM
Delta Offline OP
So I've been chasing a groan/whine in my Tacoma since late fall, early winter. Been scratching my head as to what it could be and even had bought a front wheel bearing thinking the drivers side was bad (it wasn't). Finally decided to stop by the shop and he determined my drivers rear wheel bearing is going out. Makes sense as it is starting to leak gear oil as well (even if it isn't bad, it will not pass inspection and while it's tore apart you might as well replace the bearing anyways). The guy is letting me get my own bearing and seal. Rock Auto has a Timken assembly for a decent price. Thing is I have never had to replace something like this and am kind of out of the loop as far as brands. Are Timken assemblies worth anything anymore? We use their seals at work and seem to be ok. I know Moog has gone downhill so those are out.
'17 VW GTI 2.0T - 6MT - 20K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 139K - RGT 5w30
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362564 02/28/20 04:01 PM
slacktide_bitog Offline
Timken and SKF are good name brands smile
Re: Timken Rear Wheel Bearing - Any Good? [Re: slacktide_bitog] #5362576 02/28/20 04:21 PM
Char Baby Offline
SKF seems to be the new go-to wheel bearing brand these days. Timken used to be the safe choice but with so many parts being made around the world, times have certainly changed haven't they?
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362585 02/28/20 04:33 PM
Chris142 Offline
The Chinese made Timkin bearings seem to get lots of complaints. The ones from the USA, Austria,Poland etc seem to work well.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362592 02/28/20 04:43 PM
SatinSilver Offline
You can check prices for an oem one here. Sometimes their prices are the same or lower than Amazon. And not worry about getting a counterfeit.
https://partsbarn.sunnysidetoyota.com/
There's been fake SKF bearings hitting the market.
https://www.google.com/search?sourc....1..gws-wiz.......0i131j0i10.yg4PMrp1yQs
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362594 02/28/20 04:43 PM
N
nthach Offline
N
Timken makes their own tapered roller bearings in the US and France. For sealed wheel hubs they tend to be hit or miss. The Toyota ones I've seen were reboxed Koyo or NTN.
On a live axle Tundra, the bearing is a roller or ball bearing that's pressed onto the axle shaft or diff housing/axle tube.
Re: Timken Rear Wheel Bearing - Any Good? [Re: nthach] #5362608 02/28/20 04:58 PM
Delta Offline OP
That's what I've been reading as well. I'm thinking to go ahead and order the Timkin assembly. If it doesn't look to par I'll return it, can't get into the shop until the 11th so I have a little time.
Thanks for all the replies so far!
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362727 02/28/20 07:57 PM
P
PowerSurge Offline
P
SKF has a plant not too from from Atlanta.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5362986 02/29/20 04:38 AM
K
KneeGrinder Offline
K
The last Timken's I bought for my Acura with 243k were made in South Korea. I would have paid a few more bucks for SKF's, but S. Korea does actually make some good stuff. Would rather support American workers and companies.
Bought SKF's for the Subi a few years ago, they are U.S.A.!
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5363013 02/29/20 06:10 AM
M
MoneyJohn Offline
M
I know you are talking about Tacoma, but as a data point, the Forester board has a lot of complaints about Timken. My mechanic put SKF.
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5363027 02/29/20 06:34 AM
dlundblad Offline
I’ve also heard bad things about Chicom Timken products. Much like Moog, they were once a good name. Not so much now.
I bought a Timken bearing for either my truck or her car that was US made though. No complaints.
Nowadays, SKF would be my go to.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5363297 02/29/20 11:54 AM
Delta Offline OP
As much as I hate to I'm going to chance it. I have a little extra time incase it's absolute garbage. I did pick up all the other associated parts (seal, o-ring, retainer, and new C-clip) at the dealer and the prices on those items were well in line with what is listed online, that and I know they're genuine. I did price a bearing assembly; $495. Took all I could not to laugh. Some things they're good on, some not.
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5363652 02/29/20 06:36 PM
K
kkreit01 Offline
K
I recently bought a Timken rear hub/bearing for my daughter's Civic. It was Made in Japan. It was $80 vs. ~$50 for the Chinese brands. I figured it was worth the extra cost.
2017 Jeep Grand Cherokee 4x4 3.6: 0w20 PP/Napa Gold filter
2018 Ram 1500 CC Hemi: 5w20ish QSUD/Napa Platinum filter
2007 Honda Civic Hybrid: ? ?
Re: Timken Rear Wheel Bearing - Any Good? [Re: Delta] #5365266 03/02/20 01:27 PM
Delta Offline OP
Got the assembly in today and the bearing is indeed a Koyo, so I guess I lucked out. The rest of the unit seems well made. About 1/2 the cost of auto parts stores and 1/4 the Toyota dealer.
