Can I use 75w instead 70w gear oil?
EU
My KIA Ceed recoomends for manual transmission oil: 70W API GL-4. I cant find nowhere 70w oil, so can I use 75w oil (api GL4) instead?
It's not cheap, but it's 70W:
[Linked Image]
There are plenty of 70W or 70W-75W dual rated products out there you'll probably have to buy it online since it's a European vehicle I don't know what retailer to recommend since I'm stateside , if it specs a GL-4 lube don't use a GL-5 gear lube as it can cause damage to brass parts.
I just went through this fiasco wondering why I couldn't use 75w90 gear oil vs the 75w80 my manual tranny calls for. Molakule should chime in here but you really need to stay with a GL4. I ended up buying redline MTL which is a 75w80 and is made for manual transmissions.
As long as its GL4 in the 70-80 range it should be fine. I think many forget the ratings on oil are a range not an exact number. I have seen many 75s that perform as well or better in cold weather than a 70.
Totally agree. 70W is a range of viscosities... and even there are wide differences in the 40 degree C behaviours... and in the Brookfield Viscosity behaviours, and in the Viscosity Indexes... all within the same basic SAE oil "weight".
Any full synthetic reputable name 75w GL-4 will be just fine.
It's still good to look at the stats for cold flow if they can be found for any oil.
Yes, you can and you get stronger oil film for components protection .
But you might have higher tendency of encountering morning cold shift harshness ,depending on your locality .
The C66M-R transaxle in my Mazda (yes, I know - it's a different Mfr) has trough/shaft funnel/drilled shafts to feed lubricant to the speed-gears which run on splined journals. In my case I am unwilling to potentially feed less lubricant to the speed-gears using higher viscosity lubricant. Yes, film strength is higher with a higher viscosity lubricant but this lubricant flow matter is at hand... Not sure what the arrangement is for the car at issue... but I'm just saying...
I understand where are you coming from on the bold but IMO the rational/logic is invalid .......
until and unless OEM's (Kia or Mazda) specifically prohibits use of 75W grade in lieu of recommended 70W, in which case I interpret the prohibition as arises out of OEM design defects/faults .
Btw, manual trans lubrication systems are typically of oil bath/splash design .
Zeng, I'm not sure I follow your logic on why, if the Mfr specs 70W and does not specifically prohibit the use of 75W, you feel you have leave to use the higher SAE "weight" product.
As for shaft oil funnels, I have attached a couple of graphics. Yes, in most cases the lubrication for a manual transmission or transaxle is by splash... but specifically per the photos - in many Ford- or Ford-inspired transmissions/transaxles there also is a trough arrangement whereby oil splash feeds the trough, or "spent oil" from a higher-up shaft feeds the trough... and then the oil funnel directs the oil under a gravity feed arrangement along the shaft, and out the radially-drilled oil-feed holes (in this case, to the speed-gears). (The photos are for a Non-World-Class - NWC - Borg Warner T5. I guess this is not a Ford design, per se... but...). On the somewhat "poorboy" Mazda set-up the speed-gear journals comprise non-sharp-edged splines, and between spine-ribs the oil feed holes are in place to lubricate the speed-gears.
Higher viscosity manual transmission lubricant has a harder time making it along the shafting and out the journal oil-feed holes (i.e. lower flow rate). That is why in the case of the Mazda C66M-R transaxle I would not exceed the Mfr's 75W-80 recommendation. If the OP's car has this same design for the speed-gears (I have no idea, on that account) then I believe my logic stands for the Mfr's specification of 70W MTL.
