Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
3+ weeks in, and no TP
by MrQuackers - 04/04/20 06:20 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
UOA, DexronVI, 26k miles, GM 6L80
by jetman - 04/04/20 05:37 PM
2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
northestPM, dgvu89, Kevin1987, Thetrashman33, YLK
71099 Registered Users
25 registered members (928, bachman, Char Baby, Cdn17Sport6MT, ctechbob, blufeb95, 2 invisible), 1,164 guests, and 17 spiders.
Topics303,612
Posts5,238,335
Members71,099
Can I use 75w instead 70w gear oil? #5362420 02/28/20 12:57 PM
P
Polyalphaolefin Offline OP
P
My KIA Ceed recoomends for manual transmission oil: 70W API GL-4. I cant find nowhere 70w oil, so can I use 75w oil (api GL4) instead?
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362431 02/28/20 01:12 PM
Cubey Offline
It's not cheap, but it's 70W:
[Linked Image]
1985 Ford E-350 27ft Class C RV (6.9L IDI w/ ATS 085 Turbo, C6 A/T, Dana 70 4.10) MPG @ Fuelly
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362434 02/28/20 01:20 PM
Cdn17Sport6MT Online Content
Online Content
Highly rec. NOT exceeding mfr's rec'd SAE weight recommendation. Do you REALLY want gravelly-feeling shifts particularly when cold? That might happen.
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362445 02/28/20 01:33 PM
Brian553 Offline
Necessary cold weather performance depends upon your ambient operating temperature.
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362456 02/28/20 01:42 PM
B
blufeb95 Online Content
Online Content
B
There are plenty of 70W or 70W-75W dual rated products out there you'll probably have to buy it online since it's a European vehicle I don't know what retailer to recommend since I'm stateside , if it specs a GL-4 lube don't use a GL-5 gear lube as it can cause damage to brass parts.
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362458 02/28/20 01:44 PM
B
bulwnkl Offline
B
Here’s a 70W MTL:
https://www.redlineoil.com/mt-lv-70w75w
Does Kia not offer a fluid that meets their own specs? That occasionally happens.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362462 02/28/20 01:46 PM
J
jayjr1105 Offline
J
I just went through this fiasco wondering why I couldn't use 75w90 gear oil vs the 75w80 my manual tranny calls for. Molakule should chime in here but you really need to stay with a GL4. I ended up buying redline MTL which is a 75w80 and is made for manual transmissions.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362464 02/28/20 01:46 PM
P
P
I forgot to note: I live in Europe (Bosnia). Cant find any 70w here. not even in dealership!
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362473 02/28/20 01:59 PM
J
Jimzz Offline
J
As long as its GL4 in the 70-80 range it should be fine. I think many forget the ratings on oil are a range not an exact number. I have seen many 75s that perform as well or better in cold weather than a 70.
yup
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362488 02/28/20 02:18 PM
B
Online Content
B
Is there any place you can order liquimoly Top Tec MTF 5300 70W-75W
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362494 02/28/20 02:20 PM
Online Content
Totally agree. 70W is a range of viscosities... and even there are wide differences in the 40 degree C behaviours... and in the Brookfield Viscosity behaviours, and in the Viscosity Indexes... all within the same basic SAE oil "weight".
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362505 02/28/20 02:30 PM
JohnnyJohnson Offline
Yep and this is what I have in my Corolla.
[Linked Image]
2004 Corolla 139577
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362708 02/28/20 07:49 PM
A
AC1DD Offline
A
Any full synthetic reputable name 75w GL-4 will be just fine.
It's still good to look at the stats for cold flow if they can be found for any oil.
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362711 02/28/20 07:50 PM
Z
zeng Offline
Z
Yes, you can and you get stronger oil film for components protection .
But you might have higher tendency of encountering morning cold shift harshness ,depending on your locality .
Re: Can I use 75w instead 70w gear oil? [Re: Polyalphaolefin] #5362775 02/28/20 08:54 PM
Propflux01 Offline
I don't think '5W' is really going to make that much cold difference where the OP lives.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
