Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
99 registered members (2K2AcuraTL, 4WD, 53' Stude, alarmguy, Alaskanmont, 007, 9 invisible), 1,935 guests, and 20 spiders.
Topics303,305
Posts5,233,638
Members71,038
After adding RP Water Wetter, heat blows hot intermittently? #5362206 02/28/20 09:13 AM
G
gr8gatzby Offline OP
G
New to me LS460, 6 weeks and 6k miles (125k total) while in my stable.
Added RP water wetter 2 weeks ago and now my heat blows hot about half the time. No measurable change in engine temps. Removed coolant to add RP WW without overflowing, coolant level has remained constant and at max level since addition.
What in the world is happening here...
Updated: Redline, not RP.
'12 Lexus LS460 AWD
'89 Volvo 244 | 322k
'95 Ford F150 | 4x4 | 5.8 | 9MPG
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362213 02/28/20 09:21 AM
R
racin4ds Offline
R
Blend door issue, or heater core. Doubt it had anything to do with the water wetter. Just coincidental..
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: racin4ds] #5362221 02/28/20 09:26 AM
demarpaint Offline
Those are my thoughts as well.
God Bless Our Troops
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362222 02/28/20 09:26 AM
K
Kira Online Content
Online Content
K
Aren't those water wetters specialty products for 100% water (race car) applications?
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362225 02/28/20 09:29 AM
B
Bottom_Feeder Offline
B
What was the point of adding Water Wetter to a street car running antifreeze?
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: Bottom_Feeder] #5362235 02/28/20 09:34 AM
G
G
Because mad horsepowers.
But, mostly for the chicks.
'12 Lexus LS460 AWD
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362236 02/28/20 09:35 AM
K
kschachn Offline
K
So we are just making stuff up?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362239 02/28/20 09:37 AM
K
kschachn Offline
K
There won't be a measurable change in engine temperature unless the water wetter somehow affected the set point of the thermostat, which is highly unlikely.
This is a mechanical problem, not an issue with the coolant.
1994 BMW 530i, 252K
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362242 02/28/20 09:39 AM
B
BMWTurboDzl Offline
B
Ya, it allegedly enhances heat transfer. In any case, I can't think of why it would impact on the heat transfer by the heater core because coolant temps are inherently hot enough on a fully warmed engine.
Is the engine getting up to normal operating temps? It's a big V8 no? The only thing I can think of is that the thermostat is beginning to fail or as others have said the heater core itself is getting gummed up.
If the T-stat is fine what about a citrus flush of the cooling system?
435i
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: kschachn] #5362243 02/28/20 09:40 AM
G
G
Many thanks for the input! Now to tough it out till my extended warranty kicks in on 3/5.
'12 Lexus LS460 AWD
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362248 02/28/20 09:47 AM
A
ARCOgraphite Online Content
Online Content
A
When did you open the rad? Was it stone cold or close to that?
How did you "remove" AF? Turkey baster?
Maybe run the thing high idle with the cap off untill it starts flowing then see how the level is and if its moveing around.
Also, its a new-to-you car, you may not notice everything going on right off the bat, and many new cars are designed to run cool air out the vents and heat to the feet at a mid temp setting.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362252 02/28/20 09:48 AM
V
Virtus_Probi Offline
V
Is this possibly a symptom of some air having unintentionally gotten into the system?
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gr8gatzby] #5362325 02/28/20 10:44 AM
G
gman2304 Online Content
Online Content
G
You more than likely let air into the cooling system. From your previous thread about being new to Lexus....and having been a Saab owner....it seems the best advice one could give you might be to just service the LS at recommended intervals and drive it. It ain’t a Saab!
Re: After adding RP Water Wetter, heat blows hot intermittently? [Re: gman2304] #5362419 02/28/20 12:56 PM
J
JMJNet Offline
J
This!!!
  • 2017 Toyota Sienna
