It's NAPA time!
by SlavaB - 04/03/20 12:57 AM
Parts for a $1000 computer
by Toy4x4 - 04/02/20 11:45 PM
Bottle jack as jack stand?
by JHZR2 - 04/02/20 10:45 PM
Freedom 500
by earlyre - 04/02/20 09:41 PM
What would a missing egr valve gasket cause?
by 2009Caraman - 04/02/20 09:25 PM
2008 Accord 2.4L 4,044 PPHM 5w-20
by Brolly - 04/02/20 08:34 PM
Nu Finish
by rrretiree7 - 04/02/20 07:18 PM
Leases?
by wallyuwl - 04/02/20 07:04 PM
Ford A/C quick connects
by Colt45ws - 04/02/20 06:16 PM
Steel rims ; How good are ...
by odie - 04/02/20 03:42 PM
I'll be back hopefully
by 53' Stude - 04/02/20 02:09 PM
Mazda CX-5 Skyactive Transmission fluid?
by Drew99GT - 04/02/20 01:32 PM
Transfer pics / videos iPhone to PC
by diyjake - 04/02/20 11:47 AM
Valve train noise on start up
by NavyVet88 - 04/02/20 11:24 AM
Eezox vs Prolix?
by Gebo - 04/02/20 10:52 AM
Tool battery question
by supton - 04/02/20 10:36 AM
ebarker, Knop, AConstructionGuy, MPDano, ferdna
71079 Registered Users
18 registered members (4WD, Char Baby, AnthemBassMan, edhackett, Bailes1992, Donald1953, 2 invisible), 1,124 guests, and 20 spiders.
Topics303,501
Posts5,236,493
Members71,079
Page 1 of 4 1 2 3 4
Oil Recommendation :2020 Subaru Legacy 2.4 turbo #5361886 02/27/20 10:06 PM
R
R18A1 Offline OP
R
Hi guys and gals,
Just recently bought a new 2020 Subaru Legacy with the 2.4 turbo engine in it. Looking for opinions on what oil I should use after dumping the initial fill. OCIs are 10000km with 0w20 oil. In town driving with some highway as well, the occasional spirited driving. Also lots of cold starts in the winter up here in northern Ontario Canada.
Any insight would be appreciated, as well as any recommendation for a great oil filter.
Thank you fellow bitogers!
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5361908 02/27/20 10:23 PM
R
Rand Offline
R
I'm not convinced on 0w20 in a turbo motor.
but maybe I'm a dinosaur. A brand name 0w20 api sn+ would be a good place to start.
It shows 0w20 Subaru manuals are horrible. They have statements from 10 years ago and its never revised.. so it gets contradictory.
It also says higher viscosity might be needed for hot climates.
Using a syn 5w30 D1G2, API SN+, such as Pennzoil Platinum 5w30 would be my preference.
it also says 5w30 conventional is ok for top off is 0w20 is unavailable.. uh how about 5w30 syn?? also the 0w20 unavailable hasnt been the USA/North America for 10 years.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5361911 02/27/20 10:25 PM
E
Eddie Offline
E
Surprised that 0w20 is listed for that turbo charged engine. I have several good UOAs from a MAZDA turbo 2.3L CX7 using Pennzoil Platinum 5w30 at 6K oci with a OEM or WIX filter. ed
2014 CX5 Touring 2.5L :-)
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5361922 02/27/20 10:30 PM
STIcandy Offline
If the manual allows it in your region I'd definitely move up to a 5w-30 for sure. I guess an SN+ although I've used Motul xclean efe 5w-30 which is an SN synthetic in the Fa20 engine with good results.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: STIcandy] #5361931 02/27/20 10:42 PM
B
bluesubie Offline
B
Same language as in all other Subaru’s that spec 0W-20:
Quote
0W-20 synthetic oil is the required oil for optimum engine performance and protection. Conventional oil may be used if synthetic oil is unavailable.
*: If 0W-20 synthetic oil is not available, 5W-30 conventional oil may be used if you need to add oil. However, you should change to 0W-20 synthetic oil at the next oil change.
And on another page:
Quote
Engine oil viscosity (thickness) affects fuel economy. Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required to properly lubricate the engine.
edit: D’oh! Just saw Rand’s pic! Did you add more?? smile
I’m an “oil thickie” in the EJ, but I’m being a guinea pig and running 0W-20 in my FA24DIT during the 5/60 Powertrain Warranty.
'20 Subaru Outback Onyx XT | Idemitsu 0W-20 dexos 1 G2
'04 Subaru Forester 2.5XT | Castrol Edge 0W-40
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: bluesubie] #5362010 02/28/20 01:17 AM
R
Rand Offline
R
I did infact revise my post to add the manual snip about 10 min later.
I wouldnt worry about 0w20 in the FA24DIT in most circumstances.. however in more extreme circumstances such as summer towing, high speed mountain driving etc.. I wonder how well the oil temp would be controlled.
If I was towing in an Arizona summer for example I wouldnt use 0w20. my fb25 would see 230f+ just in normal high speed summer driving(in Ohio)
and a turbo engine puts alot more heat into the oil quick.
just look how the Ram ecodiesel's first oil recommendation turned out in real life.
Of course VW is using their 508 spec oil in turbos...
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362025 02/28/20 01:57 AM
SubieRubyRoo Offline
We all know EJs, especially in WRX/STi guise, are friendly to heavier weights. NA EJs are not really as picky.
But come on, Rand, with 14,000+ posts and all you've got is opinions? Not posts of failures in the FA-DIT series from 0W20s? Did you ever think that since this was a clean-sheet engine design, just maybe they got it right? You are being a little ridiculous to compare an Italian turbodiesel V6 in a heavy truck to a Japanese flat four in a car that's half the weight. The FA20DIT has been around for several years now, and since I don't go off of opinions, but data, I did some digging. NASIOC actually has a table of whoever felt like signing up their vehicle with a list of mods, and if there was a problem with their vehicle. On this list, only 7 of over 700 samples were completely stock cars, for a failure rate of about 0.9%. And there's no telling what the root cause failure was for those. From what I can find, in America/Canada, Subaru has sold around 130,000 WRXs since 2016, and since people are much more likely to speak up about failures rather than something that works as expected, even if we use the failure rate of 0.9% across the entire population, this means most likely a maximum of about 1,200 engine failures from all causes including plain stupidity. Since members on NASIOC are likely more vocal, and likely drive their vehicles much harder than the average buyer (including OP since he specifies mostly in-town driving), I'd expect that percentage is slightly inflated compared to reality.
Am I saying don't run a Xw30? Nope, if you want to, feel free. The manual allows for it. In fact, if you are modifying the engine with a tune and other bolt-ons, it's probably a good idea. But to spew 0W20 hate towards a new owner, with warranty, that will apparently be keeping the car stock, and no real data showing there is any real need for a heavier oil is going a little overboard. For the record, I don't think anybody with real experience on this board would consider excursions into the 230*F range even close to being excessive for a synthetic oil, especially in a car with an oil cooler.
NASIOC FA20DIT list
North American WRX sales since 2016
OP, it's your choice. Running any SN+ 0W20 will meet warranty requirements, but yes, if you're so inclined, you can run a D1G2 rated 0W20 or XW30 oil if you prefer. But there's not any real data to show that Subaru's recommendation is insufficient for the engine as it rolls off the factory floor. Sweet car BTW, let us know how you like it once it's broken in!
De omnibus dubitandum.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362034 02/28/20 02:21 AM
N
nthach Offline
N
0W-20 or 5W-20 D1G2 would be my pick.
Now, if you plan on tuning the engine I'd consider something a little heavier if the tune is going to push the engine. Doesn't like you're going to plug an Cobb AccessPort and throw on a intake/exhaust/downpipe on it so xW-20 will work. Ditto for towing.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362054 02/28/20 04:29 AM
wemay Offline
0W-20. This viscosity has become the norm in more and more turbocharged 4s in N.A. without issue. Even when a thicker viscosity is recommended in other countries.
19 VW Passat Wolfsburg 2.0TSI: VW 508.00 0W-20+VW o.filter+Fram CA9711 a.filter
13 Hyundai Santa Fe Sport 2.0T: Shell RGT 5W-30+H/K o.filter+NAPA 9670 a.filter
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362056 02/28/20 04:39 AM
W
wdn Offline
W
First of all did you not get three years free oil changes with your Subaru in Canada? You should be using Subaru 0W20 synthetic and Subaru oil filters, paid for by them not by you. My son just bought a 2020 Impreza and his first six oil changes are included.
Second, the manual says 0W20, so 0W20 it is. These are new engine designs. The FB20 DI on the Impreza is only three years old and is 80% all new parts compared with the previous non-DI engine. If Subaru says use 0W20 for your turbocharged engine and the graph shows all temperature ranges that’s what they mean.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: Rand] #5362068 02/28/20 05:11 AM
W
wdn Offline
W
You left out the following sentence right after that, which states:
Quote
The following table lists the recommended viscosities and applicable temperatures.
Followed by the table itself that states
Quote
0W20 is the required oil for optimal engine performance and protection.
Note the operative words ‘required’, ‘performance’, and ‘protection’. The chart then shows 0W20, and 0W20 only, across all operating temperatures. No contradiction whatsoever. No wiggle room either. A general guidance that you noticed, is followed by a specific instruction that you omitted.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362071 02/28/20 05:34 AM
sopususer Offline
Originally Posted by R18A1
Hi guys and gals,
As far as the filter is concerned I'd stick with OEM or use a Wix/NAPA Gold 57055/7055. All of these are spec'd to the proper high Subie bypass pressure. Most if not all of your other aftermarket options have a much lower bypass psi spec. No use dumping unfiltered oil back into the system if not necessary.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362072 02/28/20 05:35 AM
T
Triple_Se7en Offline
T
Hi guys and gals,
Mobil-1 0w20 contents are well regarded here. Use it after ALL of your free oil changes at the dealer have expired.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: wdn] #5362116 02/28/20 07:40 AM
B
bluesubie Offline
B
That’s a regional thing. I don’t get them.
Re: Oil Recommendation :2020 Subaru Legacy 2.4 turbo [Re: R18A1] #5362211 02/28/20 09:19 AM
R
racin4ds Offline
R
Of course the manual says use water for oil! Subaru has to keep that CAFE rating! Do as you will but if you plan to keep this car beyond the warranty I'd be running a 5W30 SYN in it. It is a high compression, DI Turbo engine, I also wouldn't even think about running 87 Octane fuel but thats just me wink
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Page 1 of 4 1 2 3 4
