Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
104 registered members (4WD, 55hambone, Alex38, 77GrandPrix, 928, 10WSmuckers, 8 invisible), 2,143 guests, and 23 spiders.
Topics306,027
Posts5,285,131
Members71,566
Original 2016 VW Passat air filter #5361438 02/27/20 11:54 AM
V
Vaca Offline OP
V
Recently replaced the original air filter in my son's 2016 VW Passat 1.8t. The car has ~49,000 miles. I'm sure the filter could have gone another 50k all the way to 100,000, but I changed it anyway.
As you can see (hopefully pics uploaded properly) the original filter was a Wix, made in Mexico. Replacement was a Mahle, made in Romania.
Mostly unremarkable, and that's a good thing in this case. Car is mostly suburban driven in Pennsylvania and a bit in New Jersey and Maryland with a couple thousand-ish mile road trips.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: Original 2016 VW Passat air filter [Re: Vaca] #5361462 02/27/20 12:19 PM
J
JOD Offline
J
what I find interesting is that VW has come around to the logical side of things and started specifying long intervals on air filters (60K I think for the 1.8T?). Having used a restriction gauge in the past, I realize that for my driving conditions, the gasket is probably the limiting factor for filter life. I imagine you're in the same boat.
It also appears that the snow grate in the air box does a good job of distributing airflow throughout the whole filter. The dirt look pretty evenly distributed.
Re: Original 2016 VW Passat air filter [Re: Vaca] #5361553 02/27/20 02:30 PM
sohccammer427 Offline
Some will argue that every time you breach the seal on the air box you introduce contaminants into the intake. No need to check it unless you intend to replace it. I believe 40k miles is the interval for VW now, but if you're not in an exceptionally dusty area, 50k miles would be fine.
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Original 2016 VW Passat air filter [Re: JOD] #5361619 02/27/20 04:20 PM
V
Vaca Offline OP
V
Yes, the owner's manual maintenance schedule is to replace air filter at 60,000 miles. I just did it when I opened it up at 49,000 miles. I remember back in the early 90's my friend's brand new BMW 3 series didn't have an air filter. After that long ago experience, I'm surprised I waited so long to make sure the Passat had a filter installed at the factory.:)
Re: Original 2016 VW Passat air filter [Re: Vaca] #5361660 02/27/20 05:48 PM
Z
ZeeOSix Offline
Z
That's seems crazy for a car maker to do - why would BMW do that? Was there some other kind of "dirt removing" system?
Re: Original 2016 VW Passat air filter [Re: Vaca] #5361675 02/27/20 06:22 PM
K
kschachn Online Content
Online Content
K
What model exactly and what year? I know a lot about "90s" BMWs and I don't know of any that didn't have an air filter.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Original 2016 VW Passat air filter [Re: Vaca] #5361710 02/27/20 07:21 PM
splinter Offline
It's done its job well.
Good timing.
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: Original 2016 VW Passat air filter [Re: kschachn] #5362444 02/28/20 01:32 PM
V
Vaca Offline OP
V
Originally Posted by kschachn
[quote=Vaca]Yes, the owner's manual maintenance schedule is to replace air filter at 60,000 miles. I just did it when I opened it up at 49,000 miles. I remember back in the early 90's my friend's brand new BMW 3 series didn't have an air filter. After that long ago experience, I'm surprised I waited so long to make sure the Passat had a filter installed at the factory.:)
What model exactly and what year? I know a lot about "90s" BMWs and I don't know of any that didn't have an air filter.[/quote
It was an early e36. I'm sorry I wasn't clear, it was SUPPOSED to have an air filter (and we put one in immediately), but the fact that someone in the factory forgot to install it was crazy to me. Good thing for my buddy that I was pretty careful about car maintenance even back then. Had I not witnessed that myself, I never would have believed it.
I was pleased to see that the 2016 Passat had an air filter installed when I opened it up. smile
Re: Original 2016 VW Passat air filter [Re: ZeeOSix] #5362472 02/28/20 01:57 PM
circuitsmith Offline
Because a factory worker simply forgot to put one in?
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Original 2016 VW Passat air filter [Re: circuitsmith] #5362566 02/28/20 04:10 PM
V
Vaca Offline OP
V
When I discovered it missing, that's what my friend and I assumed. He bought it new from a dealer in NJ in I think 1991 or 1992. We discovered it missing when it had maybe 1000 miles on it. I can't imagine the dealer removing it - why would they even look at it?
