With a multi circuit transfer switch, after you have the generator running, you then flip the switch on (or not) for each of the circuits. So you know what loads you are hooking up to the generator. They may not be on when you flip the circuit transfer switch but that seems minor.
If you are powering your whole breaker panel with the generator, you must open your main breaker otherwise you are back feeding the power lines on your street (and all the other houses too, nuff said) which endangers line workers that might be working on the outage. Just want to point some things out for newbies to the generator scene.
