Bumblebee Ahi tuna poke
by atikovi - 03/31/20 06:05 PM
2007 RDX Differential and Transfer Case?
by maverickfhs - 03/31/20 06:02 PM
Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
Are harbor freight generators any good?
by NavyVet88 - 03/31/20 12:37 PM
Anyone on RD Forum .org? I've been banned
by FADEC - 03/31/20 11:48 AM
A picture of me in my youth! :-)
by SLO_Town - 03/31/20 11:18 AM
5w50 Motorcraft in 6.2L Raptor
by KlenFrappe379 - 03/31/20 11:16 AM
Fast 22 LR
by stockrex - 03/31/20 10:33 AM
Filter size info required please
by Richierich56 - 03/31/20 09:50 AM
Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
TreyT42, Abi, Transpections, burgM, SantiagoT
71067 Registered Users
102 registered members (ammolab, amusing, 4WD, 53' Stude, 10ecfarmer, ABerns, 11 invisible), 2,303 guests, and 23 spiders.
Topics303,519
Posts5,235,647
Members71,067
New to the LS460 and The World Of Lexus. Questions! #5361339 02/27/20 09:41 AM
G
gr8gatzby Offline OP
G
Having come from 15 years of Swedish cars, I'm new to the world of Lexus. I never imagined myself in a Lexus, but I found this LS for less than the cost of a new KIA and I figured I'd give it a try.
Stats: 2012 LS460 AWD with 126k, mint condition in and out. 2 previous owners from NY and TX. Bought from Carmax for $16k. They replaced the left axle, speed sensor, updated software after purchase. I spoke to them about my concerns with the odd trans shifting and paid Lexus to perform a full post-purchase inspection, but everyone tells me the transmission is operating within spec.
Questions:
1) Having tried all shifting modes(PWR/ECO), the trans is quite annoying. Shifts are lazy and not crisp. Under heavy acceleration it holds onto the gear way too long, and at 3-4k rpm for 5-7 seconds before upshifting. Is the unit fundamentally flawed by engineering or do I have a trans on the way out?
2) Both the manual and oil cap call for 0w20 or 5w20 only. Is this set in stone or can I play with higher weights without risking damage to the block?
3) Are there any fuel economy hacks that will make my ozone depleter better on fuel? After back to back RP and BG44k fuel treatments I'm getting close to max of EPA ratings, so I think it may not get better than this.
4) Heat is intermittent, blowing hot air about half of the time when needed. Any ideas for a fix?
5) HVAC settings defaults to 'Feet' EVERYTIME instead of last known setting whenever the car or HVAC is power cycled. Is this bad engineering or is something wrong here?
6) How powerful is the AWD...meaning, how extreme and hard can I push her? I've previously pushed my AWD Volvo wagons to the edges of the Earth and they owned it completely.
7) AWD maintenance, how often do I replace the fluids?
8) Trans flush and fill...is there an off the shelf equivalent to the Toyo/Lex fluids or just stick with OE?
Purchased a full bumper to bumper extended warranty with coverage up to 221k miles! or 6 years from Carchex.
I've put 5k miles on the clock in the first month of ownership and really quite enjoy her overall. Most comfortable and quiet land yacht I've ever owned, and the V8 power is unbelievable.
Thanks for the help!
[Linked Image]
'12 Lexus LS460 AWD
'89 Volvo 244 | 322k
'95 Ford F150 | 4x4 | 5.8 | 9MPG
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361346 02/27/20 09:54 AM
Char Baby Offline
One thing that I've learned about owning Toyota & Lexus models it to leave them alone as anything you try to do takes away from their goodness. Even replacing shocks/struts with non-OEM will not do. Or replacing parts in general with aftermarket parts is just subpar. No aftermarket parts seem anywhere near as good as OE.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: New to the LS460 and The World Of Lexus. Questions! [Re: Char Baby] #5361348 02/27/20 09:56 AM
G
G
This was the case for the Saab I owned, Volvo is more forgiving with non-OE, but with any car it all comes down to the quality of research one does prior to going off the plantation for parts.
'12 Lexus LS460 AWD
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361376 02/27/20 10:19 AM
F
ford46guy Offline
F
Better to go on ClubLexus and search/ask there. I have a GS 350 so some things are different. I don't want to say anything I'm not sure about. They are very reliable cars though.
I know those cars eat front end bushings. I test drove one and it had bad handling. It is a problem.
The other thing is it has brake by wire and it is very expensive to repair. It is a failure item. Maybe do a brake fluid exchange.
I suggest only toyota WS trans fluid, but others may have different opinions. There is a procedure for a pan drop, it has to be at temperature.
Diffs should be changed at 100K. The rear diff (on the GS 350 anyway) is speced for a special weight (85w75 I think). Only Toyota and Redline have it.
I think you have a better AWD system then the GS 350. They both have a planetary, full time t/c differential. This is actually what Subaru puts in their WRX. There is a clutch that locks if there is wheel slip, so it becomes 4x4.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361391 02/27/20 10:43 AM
B
Brybo86 Offline
B
Nice car.
I would do a trans drain and fill to see how that improves the shifts.
I would go with toyota ws to minimize variables.
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361430 02/27/20 11:38 AM
L
Lolvoguy Online Shocked
Online Shocked
L
Most of your issues can be addressed with TechStream- Toyota/Lexus' software where you can personalize settings for things such as HVAC, lighting etc.
I had issues with my Lexus with the HVAC always switching the a/c on when I put it to the lowest temp settings (very annoying).
It also would automatically move the steering wheel every time I'd turn it on/shut it off....also very annoying (I could imagine the cost of replacing the motor(s) when that fails).
After I got Techstream, I was introduced to a world of settings I could enable, disable or custom tailor to my preferences.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: New to the LS460 and The World Of Lexus. Questions! [Re: Brybo86] #5361435 02/27/20 11:44 AM
G
G
Originally Posted by Brybo86
Nice car.
Have a link to the OE fluids? Also, how many qt's will I need?
'12 Lexus LS460 AWD
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361436 02/27/20 11:47 AM
N
nthach Offline
N
You can change the car's hard-coded settings with Techstream or Carista if you'd rather not deal with TIS and buying a $500 Mongoose USB interface or a Chinese pirated cable for the offical program.
The only things to look out for on the 4th gen LS is the control arm bushings going out - it seems to be a common malady with the LS series anyway. They are solid cars, if not thirsty but expect to see mid-20s on the freeway. I'd do a few spill and fills of the tranny, I prefer WS but MaxLife will work. the transfer case does take a esoteric Toyota-only lube but the front/rear diffs do take 75W-85/90.
The AWD system is loosely based off a truck layout but with a 1-speed transfer case that uses a Torsen diff.
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361439 02/27/20 11:54 AM
F
fordtough Offline
F
Change the transmission fluid. I bought a 2011 is250 the fluid has never changed. I have done 3 drains and fills and the transmission shifts better each time.
Fluid was black
https://drive.google.com/open?id=1hm5nvolVY5LyRnM02_QdPfZ4nlDpT9LW
Aisin makes these transmissions. and suggest changing the fluid every 2 years,
Attached PDF (Fluid should not be black)
Toyota suggests changing the WS fluid every 3 years
https://www.joemyerstoyota.com/service/toyota-transmission-repair-houston-tx.htm
Lexus tells you the non-synthetic WS fluid is a lifetime.
Attached PDF document
2011 Lexus IS250 AWD
Valvoline Advanced Full Synthetic SAE 0W-20
OEM Toyota Oil Filter
Toyota WS Transmission Fluid (Drain and Fill every 10K miles)
Re: New to the LS460 and The World Of Lexus. Questions! [Re: Brybo86] #5361557 02/27/20 02:35 PM
M
maxdustington Offline
M
Nice car.
WS? C'mon, don't be a wuss. Maxlife!
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361722 02/27/20 07:29 PM
F
fdcg27 Online Content
Online Content
F
That seems like a lot of car for $16K.
Toyota's S-Class equivalent has always been a very nice car.
As others have noted, a dedicated Lexus board would probably be worth joining.
They'll have the answers as well as fixes for all of your concerns.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 36K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: New to the LS460 and The World Of Lexus. Questions! [Re: gr8gatzby] #5361850 02/27/20 09:25 PM
J
john_pifer Online Content
Online Content
J
I’ve always loved these ever since they came out for 1989. I liked that first body style the best. But the later ones are neat, too.
Late 80s, early 90s was a really, really good time for Japanese automobiles!
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: New to the LS460 and The World Of Lexus. Questions! [Re: john_pifer] #5362140 02/28/20 08:10 AM
G
G
She's the quietest and cushiest car I've owned. A 2004 Saab 9-5 preceded it and though I miss the raw balls to the wall paddle-shifting turbo4 that netted me 30mpg, it's nice to have found this girl. The aircon seats aren't as good in the Lex as they were in the 15 year old Swedish chariot, though.
'12 Lexus LS460 AWD
