Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
Summer gas?
by wbwanzer - 03/27/20 03:13 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
26 registered members (Darren_L, AAIRCraig, 97prizm, 4WD, Dave_Mark, bachman, 2 invisible), 613 guests, and 20 spiders.
Topics303,254
Posts5,232,677
Members71,032
Drain Plug Washer Frozen to Oil Pan #5360926 02/26/20 07:31 PM
CrackyWainwright Offline OP
We've gotten ourselves a 5-year-old Toyota Highlander V6. The first oil change after we got the car I had to hire out because I couldn't get the filter cartridge to break free. Now that that's under control and not torqued to 300 foot-pounds, I have another small issue. I noticed as I did the last oil change at home the drain plug washer is frozen or stuck HARD to the oil pan. I couldn't remove it to replace with a fresh blue Toyota OEM washer (I keep a pack of those on hand), so I just reinstalled the plug. No problems, no oil leaks. But still, I'd like to use a fresh washer next time.
How do I remove a seized washer without damaging any part of the oil pan?
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360927 02/26/20 07:32 PM
B
BLND1 Offline
B
Flat Screwdriver and a hammer. You aren’t going to damage the oil pan.
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360932 02/26/20 07:34 PM
J
JeffKeryk Offline
J
Yep. Smack it off. I have done it a bazillion times.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360938 02/26/20 07:44 PM
P
philipp10 Offline
P
if you want to be super careful, find yourself a small piece of oak and use that in place of a screwdriver. Put against the washer and rap it with a hammer. The wood won't scratch the pan as a screwdriver could.
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360951 02/26/20 08:07 PM
1
14Accent Offline
1
All good advice. Hopefully the sealing surface under the washer is good, if there's any grooves you may want to take some emory cloth or 250 grit and smooth it out before using a new washer.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360968 02/26/20 08:15 PM
E
Eddie Offline
E
Thin blade paint scraper into the joint between washer and pan and a light but, firm tap should do it. Ed
2014 CX5 Touring 2.5L :-)
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5360982 02/26/20 08:39 PM
PimTac Offline
Hopefully that wasn’t the first oil change for that Highlander. The only times I’ve ever had that situation was changing out the factory fill.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5361010 02/26/20 09:09 PM
G
Gokhan Online Content
Online Content
G
It happened on a factory-installed oil-drain-plug washer on a 2009 Toyota Corolla I owned. I think it happens because they overtighten the oil drain plug. I had originally thought they glued it, but I doubt that was the case.
It eventually came off by itself after a few oil changes.
It will easily come off if you pry it. If you use a small screwdriver, tape the tip so that you don't scratch the oil pan and cause oil leaks. You can also use a razor blade, but keep it completely parallel against the oil pan so that you don't scratch it.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Drain Plug Washer Frozen to Oil Pan [Re: Gokhan] #5361022 02/26/20 09:24 PM
PimTac Offline
On the factory installed plugs they stick because they paint the pan with the plug and washer installed. Usually a quick tap with a screwdriver or a piece of wood will get the washer off.
2017 Mazda CX5
Roki OEM filter.
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5361039 02/26/20 09:36 PM
CR94 Offline
There's zero reason to bother knocking the washer off, as long as it doesn't leak. Being stuck on the pan means the other side of the washer will fit perfectly against the sealing surface of the plug the next time, and not leak. I've never replaced mine, and never had a leak---but bought spare washers anyway, in case of a problem.
2011 Toyota Prius now at 109K
Re: Drain Plug Washer Frozen to Oil Pan [Re: CR94] #5361053 02/26/20 09:51 PM
M
maxdustington Offline
M
A pack of washers was literally $5 CAD shipped. I used one for the first time last weekend, it was so satisfying!
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Drain Plug Washer Frozen to Oil Pan [Re: CrackyWainwright] #5361076 02/26/20 10:11 PM
G
Online Content
G
I like the Toyota OEM blue, gasket-coated aluminum oil-drain-plug washers.
The OP didn't mention the type of the washer. Perhaps someone used a metal washer, which crammed into the hole. You may need to pull it with a needle-nose pliers if that's the case.
Re: Drain Plug Washer Frozen to Oil Pan [Re: maxdustington] #5361079 02/26/20 10:15 PM
M
Mad_Hatter Offline
M
Never understood how people will spend $30 on oil but cheap out when it comes to the plug washer and not replacing it, especially when most filters come with a new crush washer. But to each his own I guess..
Re: Drain Plug Washer Frozen to Oil Pan [Re: Gokhan] #5361084 02/26/20 10:18 PM
M
Mad_Hatter Offline
M
My neighbor used the nylon washers. He says they never leak. I think he gets em for like 3 for $2 or something around that. Might have to try one some time..
Re: Drain Plug Washer Frozen to Oil Pan [Re: philipp10] #5361096 02/26/20 10:44 PM
Z
ZeeOSix Offline
Z
Yep ... don't use metal.
