Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
12 registered members (Aries, bachman, NoNameJoe, FordCapriDriver, anndel, Kibitoshin), 510 guests, and 17 spiders.
Topics303,255
Posts5,232,687
Members71,032
LG Red in a VW DSG trans? #5360753 02/26/20 03:31 PM
R
racin4ds Offline OP
R
Hi guys, I just recently purchased a new-to-me 2013 Passat TDi with the DSG (tiptronic) trans.
I'm a huge LubeGuard advocate and use the stuff in all my Auto Trans vehicles with great success. However, the DSG trans is a different animal with no real torque converter and duel clutch setup. It also uses a very unique fluid. Is it safe to use LubeGuard Red in this and have any of you VW guys done this successfully?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360775 02/26/20 04:08 PM
skyactiv Offline
The DSG is basically a high tech manual transmission that shifts itself. DSG fluid is like a thinner gear oil, not an automatic transmission fluid. So do NOT add it to your particular application.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360784 02/26/20 04:17 PM
T
TTK Offline
T
Ask Lubegard, they will give you the correct answer Just email them with the question Then come back and tell everyone.
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360790 02/26/20 04:25 PM
Chuckh Offline
I hope you did not use regular ATF in that. If you did you might have problems. Volkswagen also recommends changing the fluid in the DSG every 40,000 miles last time I checked. Of course for my Passat with a 09G they say 60,000. I feel that they specify intervals that are just too long. I know a mechanic who works on Volkswagens mostly and he disagrees with 10,000 mile oil change intervals. He recommends 5000. I wonder what he would say about ATF and DSG fluid change intervals. If in doubt about the fluid type you can call or visit a VW dealer with your VIN and they will tell you what you need or at least give you a better idea what fluids you do need for that car. I do believe that DSG fluid is not dyed red like many ATFs are.
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360803 02/26/20 04:38 PM
The Critic Offline
It is more similar to a manual trans than an automatic. So no, I would not use it.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360815 02/26/20 04:50 PM
Chuckh Offline
Take a look at this page: What makes DSG fluid unique?
The best thing is to use the recommended DSG fluid.
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360818 02/26/20 04:51 PM
sloinker Offline
There is a some friction modification for this automatically shifted dual clutch transmission. If LG has a specific fluid for this transmission I say go for it. Otherwise change the fluid and filter every 40,000 miles with approved fluid.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360842 02/26/20 05:28 PM
MolaKule Offline
Global Moderator
Global Moderator
LG Red is mainly used for removing varnish on the hydraulic solenoids and clutch faces so I would avoid ANY LubeGard additive unless I knew there was a specific problem such as hard shifting or flare.
What is the G XXX XXX part number of your transmission?
It appears the DSG has a Spider Gear differential and if that is the case then a LV ATF with a healthy AW content such as MaxLife ATF should work.
Have the fluid analyzed to make sure it is a Low Viscosity ATF, which I suspect, it is.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360868 02/26/20 06:11 PM
B
benjy Offline
B
a Tiptronic is not a DSG from past ownership, so check its numbers or with someone with more knowledge
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5360870 02/26/20 06:15 PM
B
benjy Offline
B
look at your owners manual or go to VW Vortex
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5361009 02/26/20 09:09 PM
dbias Offline
No. Just no. A DSG transmission is 4 to 7k to replace.
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
2019 VW Jetta factory fill
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5361094 02/26/20 10:36 PM
B
BBDartCA Offline
B
Just use the Pentosin kit and forget about it. Home brew cocktails have no place in this kind of trans.
http://www.pentosin.net/literature/Pentosin%20DSG%20Kit.pdf
Former lube industry insider...now vehicle OEM engineering insider.
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5361136 02/26/20 11:42 PM
U
UG_Passat Offline
U
Lubegard will probably recommend you to use its DCT fluid.
https://www.lubegard.com/products/dct/
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: LG Red in a VW DSG trans? [Re: racin4ds] #5361578 02/27/20 03:14 PM
R
racin4ds Offline OP
R
All good info! Thanks guys, wasn't planning on using it or the ATF. I was just asking you pros for your thoughts. I know it isn't a regular Auto and I also know it requires a special "DSG" fluid that is stupid expensive. Mine was just purchased as a CPO and with 40k miles on it they just serviced the trans so I won't have to touch it for another 40k.
I however now have a peaked interest with molakules post about MaxLife.... I love that stuff! lol
05 F350 Powerstroke
05 Hyundai Tucson
Re: LG Red in a VW DSG trans? [Re: Chuckh] #5361590 02/27/20 03:29 PM
R
racin4ds Offline OP
R
Great read, thank you for that!
05 F350 Powerstroke
05 Hyundai Tucson
