10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
VIDEO: Degreasing cast aluminum engine parts!
by dwcopple - 03/28/20 01:37 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
28 registered members (ddown, 4WD, DaHen, BlueOvalFitter, Char Baby, claluja, 2 invisible), 685 guests, and 20 spiders.
Topics303,303
Posts5,233,531
Members71,038
Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect #5360662 02/26/20 01:16 PM
The Critic Offline OP
A quick review of these 3 products: 3M Headlight Restoration (HLR) kit, 3M Quick Headlight Clearcoat and Rupes Uno Protect.
3M HLR Kit: This kit included 500, 800, 3000, buffing pad and compound. The kit included an attachment for use with a household drill. I only used the 500, 800 and 3000 since I was applying clearcoat. The paper worked well, but more 500 grit sanding discs would have been nice. If I recall correctly, it came with five 500-grit discs, four 800-grit discs and one 3000-grit disc. 500-grit and 800-grit are used dry, 3000-grit is used for damp sanding.
3M Quick Clearcoat: After damp-sanding with 3000-grit, I thoroughly dried the headlight and the surrounding crevices. I then wiped with 91% alcohol. Wear gloves before applying - the product comes in pre-moistened towelettes that are similar to alcohol wipes. I applied one coat and allowed it to dry for 15 min before applying the second coat. It is possible to get runs so be careful about over-applying. I have included before/after photos below.
Rupes Uno Protect: This is an all-in-one (AIO) cleaner wax that is intended for production detail environments. It promises 90 days of protection. Rupes suggests using their yellow polishing wool pad for the best blend of cut and finish, but I found the polishing wool to leave a bit too much DA haze for this particular paint so I used their yellow foam pad. Prior to service, this car's paint was in terrible shape - lots of visible oxidation, deeper swirls and the metallic was no longer visible. After a normal wash and clay, I used the Rupes Uno Protect with a Rupes yellow foam polishing pad and their MKIII 15 DA polisher. I used speed 3 and made 4-5 passes at a medium arm speed. The product has decent cut (less than Meguiar’s D166 though) but finishes incredibly well. No dust and wipe-off was easy. Plus it leaves the surface very slick. It is on the more oily side so it is important to work the product long enough and not short-cycle it. I spent about two hours polishing the vehicle below.
45DE839E-CF4A-4B7E-AD55-915A7FBC8AB7.jpeg9E47B550-2D4E-4D46-8DA4-B5DD246EA711.jpeg21997F07-3969-4D0A-BC96-5BA6AAC36B8E.jpeg989A8B4B-F848-42C8-A5EB-2F9CC6E71A0C.jpeg9FF6507A-B0A2-493E-8A99-E01B32897F45.jpeg6221F038-61DB-4556-AFB0-BDCBE698B69F.jpeg57C6503A-5C2B-4995-A8EA-CCA12106D8B6.jpeg
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5360688 02/26/20 01:57 PM
R
racin4ds Offline
R
D.A.M.N.! now that is an incredible transformation! You do great work!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5360689 02/26/20 01:57 PM
N
nickaluch Offline
N
Wow great job
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5360788 02/26/20 04:21 PM
Char Baby Online Content
Online Content
Nice work!
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5360887 02/26/20 06:45 PM
Snagglefoot Online Content
Online Content
That’s a lot of headlight. Looks great!
smile
If you want the job done right......do it yourself.
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5360937 02/26/20 07:44 PM
J
JeffKeryk Offline
J
Have mercy...
Killer job Michael.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: The Critic] #5364987 03/02/20 08:25 AM
RTexasF Offline
Very nicely done. The depth of shine and reflection of the paint is really nice especially for an AIO. The headlights are well....new!
Re: Reviews: 3M HLR Kit, 3M Quick Headlight Clearcoat & Rupes Uno Protect [Re: RTexasF] #5365257 03/02/20 01:16 PM
Thanks for the kind comments, everyone.
I agree. Using a polishing MF or wool pad would have resulted in more correction but foam delivered the best possible finish for this paint. The wool was leaving a small amount of DA haze that would have been evident once the sealant wore off.
