Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
Are harbor freight generators any good?
by NavyVet88 - 03/31/20 12:37 PM
Anyone on RD Forum .org? I've been banned
by FADEC - 03/31/20 11:48 AM
A picture of me in my youth! :-)
by SLO_Town - 03/31/20 11:18 AM
5w50 Motorcraft in 6.2L Raptor
by KlenFrappe379 - 03/31/20 11:16 AM
Fast 22 LR
by stockrex - 03/31/20 10:33 AM
Filter size info required please
by Richierich56 - 03/31/20 09:50 AM
Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
TreyT42, Abi, Transpections, burgM, SantiagoT
71067 Registered Users
105 registered members (atikovi, AC1DD, 2015_PSD, 4WD, Al, 53' Stude, 9 invisible), 2,289 guests, and 21 spiders.
Topics303,517
Posts5,235,623
Members71,067
RON Octane Gasoline rating #5360526 02/26/20 10:26 AM
B
Building3 Offline OP
B
The 1966 Mustang owners manual says that the fuel should be 91 RON octane "Regular" fuel for the 2V carburetor and 99 RON octane "Premium" fuel for the 4V. About what are those ratings using today's R+M calculations? I know that the "Motor" rating is lower than the RON, so I am thinking that any 87 or 89 is probably good for the 2V but how about that 99 RON, what pump octane would that be now? Thanks
Re: RON Octane Gasoline rating [Re: Building3] #5360539 02/26/20 10:41 AM
K
kschachn Offline
K
99 RON would be approximately 93 AKI (R+M)/2, the current measurement here in the US. I've never seen a pump label distinguish between RON and MON, only the average.
It's as close as you will get here in the US without buying specialty (race) gasoline or leaded aviation fuel.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: RON Octane Gasoline rating [Re: kschachn] #5360595 02/26/20 11:34 AM
Y
y_p_w Offline
Y
The scales that are out there are imprecise rules of thumb. Pure iso-octane of course has a RON of 100 and a MON of 100. But in general it's close enough with most pump fuel to have a RON then an AKI octane recommendation.
Re: RON Octane Gasoline rating [Re: Building3] #5360668 02/26/20 01:31 PM
T
thastinger Offline
T
Research Octane numbers are generally on the order of 10% higher than Motor Octane numbers. This might give you an idea https://vpracingfuels.com/master-fuel-tables/
but I would think the fuel you're trying to buy would have the RON and MON posted somewhere on the website
Re: RON Octane Gasoline rating [Re: thastinger] #5360800 02/26/20 04:36 PM
Y
y_p_w Offline
Y
The only requirement when sold in the US is the (R+M)/2 rating. It is possible to have a different "spread", and of course there can be different fuels with different spreads being mixed into the same storage tank. They should average out to the same AKI.
Re: RON Octane Gasoline rating [Re: Building3] #5360833 02/26/20 05:12 PM
E
eljefino Offline
E
I've heard Research is 4 points higher than (R+M)/2.
Naturally the 4 bbl carb has a more aggressive (compression, cam, timing) engine sitting underneath it than the 2V-- carburetion is only incidental.
Re: RON Octane Gasoline rating [Re: Building3] #5360934 02/26/20 07:37 PM
B
benjy Offline
B
looking at the benefits of oxygenated fuels is interesting, kinda why NITRO an oxygen bearing fuel can be burned at such high volumes making OUTRAGEOUS power in top fuel drag racing
Re: RON Octane Gasoline rating [Re: Building3] #5360939 02/26/20 07:45 PM
R
Rand Offline
R
Quote
Difference between RON, MON, and AKI
Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel. This difference between RON and MON is known as the fuel's Sensitivity,[5] and is not typically published for those countries that use the Anti-Knock Index labelling system.
Re: RON Octane Gasoline rating [Re: thastinger] #5361405 02/27/20 10:58 AM
B
B
Thanks for your inputs. As was noted in one post, only the average of R+M is shown on the US gasoline pumps. I did click on the master fuel table link and found that the differences between R and M were from 3 to 15, so quite large differences. Maybe the best thing to do is to experiment. i think I will try the lowest octane and work up until I don't hear and knock/pinging going up hills. Start with 87 for the 2V and 90 for the 4V.
