Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
127 registered members (2003f7, 97prizm, 14Accent, 87sammy, 4WD, 2K2AcuraTL, 12 invisible), 2,506 guests, and 47 spiders.
Topics305,921
Posts5,282,780
Members71,537
Page 1 of 3 1 2 3
Need oil additive advise for replacement engine. #5360114 02/25/20 08:18 PM
1
13Track38 Offline OP
1
The original 3.8L GDI engine in my daily driver 2013 Genesis Coupe lasted over 100k miles then ceased due to bad bearings despite regular 5k mile OCIs and Blackstone UOAs showing good wear #s on Mobil1 full synth 5w30 and oem filters. It had 1qt of oil burn every 5k miles that developed late and I kept it topped off.
Now the replacement 3.8L engine with around 60k miles that's out of a front collision Genesis has 2qt of oil burn every 5k miles and the UOAs show higher wear #s as well despite the lower miles. I'm wondering if people here that I've seen have much more experience than myself with oils believe that changing from Mobil1 to Amsoil along with using a oil additive like LM MoS2, Lubegard Biotech or Archoil 9100 would improve the UOA wear #s and help extend engine life.
The dealership service supervisor advised the MoS2 which they do sell btw wouldn't have prevented the bearings from going bad in my previous engine and advised that I not waste money on it but I want 2nd opinions here.
[Linked Image]
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360122 02/25/20 08:27 PM
sloinker Offline
I would think a modern oil designed for GDI engines may be your best choice along with shorter intervals if it is gas dilution that harmed your bearings. You may try an expensive short run of the high ester Premium Blue restore to see if it's a ring land coking problem causing the oil burn. If you are going to spend Amsoil money going forward you may consider Red Line which has higher ester levels or Ravenol which is mostly PAO but with certifications.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360139 02/25/20 08:40 PM
1
1
Gas dilution #s on both engines is only <0.5 so that shouldn't be the cause. Thanks for your help.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360156 02/25/20 08:54 PM
G
Greggy_D Offline
G
I'm sorry, OP. Your car sounds like a complete disaster. You took great care of it with 5k M1 changes. No daily driver engine should have blown up with that care.
Why throw good money after bad? There is no magical elixer in this case.
Greggy D.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360175 02/25/20 09:09 PM
1
1
Could be Greg and I'm considering that as well. I forgot to mention that in the 1st oil change at 500 miles after the engine install with dino oil in it I found a couple of 1" long silver colored non ferrous metal hair like pieces in the oil filter but I didn't find any pieces in the 2nd oil change with the synth oil.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360200 02/25/20 09:29 PM
Mike L. V. Offline
OP, cut your losses and find another car. 2 Quarts consumed in 5K miles just spells another future disaster. 60K and wear metal being higher sounds like an abused engine.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360241 02/25/20 10:11 PM
LTZ10 Offline
I’m with mv6845 on this as well. With burning two qts very 5k, I’d find another engine. What, if any, are the options for a rebuild?
US Army Veteran
Law Enforcement Veteran
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360265 02/25/20 10:49 PM
DrDanger Offline
2 quarts sounds bad... still having payed for the engine, you must try and get something out of it.
Valvoline Blue Restore (expensive) to try and free up stuck piston rings, restore clogged oil passages.
Hyundai/Kia factory fill in Europe is Total oil- with tons of organo moly (800ppm), is a better option than disulfite moly in LM MOS2.
https://catalog.lubricants.total.com/en/products/47w-6/QUARTZ-9000-ENERGY-HKS-G-310-5W-30
If not available in the US, get the highest containing zddp and/or boron and moly oil you can find (these are the anti-wear, film forming, surface coating additives in oil) or Valvoline Maxlife/Castrol Magnatec with 1 additive of your choice(I like the MoS2, but we dont get the others here so I have no clue on them).
Good luck to you.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360267 02/25/20 10:54 PM
L
Lolvoguy Offline
L
crush
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360311 02/26/20 01:51 AM
O
OilUzer Offline
O
A thicker oil may help more than a brand change. Either way oil can't solve the problems associated with a bad or inferior design ...
Did Hyundai help with the replacement engine and was your engine under a recall?
Hyundai has a great customer service. One of the best I've seen.
According to experts here, oil additives are like snake oil. I've bought some and never noticed any significant change.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360325 02/26/20 03:19 AM
M
Mad_Hatter Offline
M
You could try a thicker oil with higher levels of aw additives but there's also a good chance you got yourself another "bad" engine (the metal could be coming from the journals) with a bearings/crankshaft problem and it's just a matter of time before you spin those bearings as well. Bad conrod bearings can contribute or make oil burning worse too - and you say this engines already burning 2qts every 5k? This seems to happen to some of the first gen Genesis. Some speculation that it's a unbalanced crankshaft from the factory.
If you're not too invested in the car I'd sell it while you might be able to get something out of it, otherwise there's not a whole lot you can do other than just wait and see what transpires. Forget the pour in additives.. just buy a better oil with the addys you seek but just know that no oil is gonna "fix" a bearings issue, it's just a matter of time before those ones go.
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360394 02/26/20 07:37 AM
A
aquariuscsm Online Content
Online Content
A
2 quarts is unacceptable. What kind've warranty does your rebuild have? Definitely take it back.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360451 02/26/20 09:15 AM
A
ARCOgraphite Offline
A
NO magic band aids, sorry.
M1 isnt magic either.
Burning calls for Rotella T3 10W30 Dino oil .
I havent been able to find it anywhere in jugs, just 5gal pails.
OTW just run Formula Shell or QSGB
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Need oil additive advise for replacement engine. [Re: ARCOgraphite] #5360459 02/26/20 09:24 AM
T
tig1 Offline
T
So Rotella is a band aid when you said there is "no magic band aids". shrug
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 89K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Need oil additive advise for replacement engine. [Re: 13Track38] #5360462 02/26/20 09:26 AM
dogememe Offline
Tell me again how Hyunkias are so great? Lol 2qts/5k = sell the car NOW.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Page 1 of 3 1 2 3
