I picked up a Sig P516,
Pros - OAL of 23 inches , piston
Cons - Triggers needs to be replaced, may be the worst AR trigger I ever experienced. Gas Block needs a little adjustment from what they suggested for 55g XM193LC1, quite sharp recoil.
Pretty accurate for my needs and a 7 inch barrel. I was able to hit an 8 inch gong with a 2 MOA red dot while I was zeroing my red dot,
LOUD, this sucker is LOUD, I ordered a Sig Can but I won't see for nearly a year.
I might try polishing the trigger a little before replacing it if that does not help with the first stage grittyness.
