Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
100 registered members (4WD, 53' Stude, 94astro, ammolab, 77GrandPrix, 2oldtommy, 10 invisible), 2,639 guests, and 18 spiders.
Topics303,641
Posts5,238,889
Members71,105
Flaring tool #5359830 02/25/20 02:52 PM
P10crew Offline OP
I’ve been tooling up on all of the goodies to do brake, fuel and steam lines on our hot rods. I first purchased US made Rigid precision 37 and 45 double tooling but much to my chagrin the #%}€!| tubes slipped in both tools while flaring. Sent both of them back and after much research on the Earls turret tools I found that K tool is the MFG of the Earls tooling as well as several others. It arrived this morning and I did 7 single and doubles on all of the different tube material including .028 wall stainless. Absolutely flawless flares and ZERO slipping of any kind, centered perfectly.
The tool looks and feels very robust and a half decent case.
[Linked Image]
That’s about as close as I can focus. [Linked Image]
Made in 🇹🇼 sorry shame shame spank
Re: Flaring tool [Re: P10crew] #5359846 02/25/20 03:08 PM
P10crew Offline OP
[Linked Image]
5/16 and 3/16 benders coming shortly to complete the set.
Now the move is on to build a kick €#% 6 mandrel tube straightener out of this junk. [Linked Image]
Re: Flaring tool [Re: P10crew] #5359860 02/25/20 03:35 PM
E
exranger06 Offline
E
I have the same tool (Eastwood brand). Overall it works well and I'm happy with it, but I've found that the line tends to slip a little in the tool, resulting in a bad flare. I have to REALLY tighten the die down to make sure there's no slipping. This happens when I use Ni-Copp line, which is the only kind of brake line I use anymore.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Flaring tool [Re: P10crew] #5359862 02/25/20 03:38 PM
Scuder Online Content
Online Content
I'll be interested to see that. Good luck, and please post pictures of the result.
Re: Flaring tool [Re: P10crew] #5359917 02/25/20 04:47 PM
T
Traction Offline
T
Very nice tools. I've had good luck with my Ridgid flare tools, but probably wouldn't do stainless well. For bending 3/16 line around objects, and tight bends my tube bending pliers made by Lisle works perfect for me.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Flaring tool [Re: P10crew] #5359937 02/25/20 05:19 PM
P10crew Offline OP
Normally when a flare tool starts to slip you can set the 2 die halves on a piece of sand paper on a flat surface and take a couple thou off to tighten it up some.
These dies are real tight as the tube will stick in the die after it’s clamped in. I’m sure they will loosen up over time and when they do I’ll just take a few thou off each half.
Scuder..... will do.
Traction..... I’ll snag me a pair.
Re: Flaring tool [Re: P10crew] #5360056 02/25/20 07:30 PM
T
Trav Offline
T
Looks like a decent tool that will get the job done. thumbsup
Re: Flaring tool [Re: P10crew] #5360058 02/25/20 07:32 PM
T
Traction Offline
T
I don't know how many flares I had to make for this project, and none leaked. This was coming out of 2 master cylinders to 2 brake pressure gauges, an adjustable prop valve for the rear brakes, and a hydraulic park lock for the front brakes.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Flaring tool [Re: P10crew] #5360121 02/25/20 08:25 PM
P10crew Offline OP
Very nice looking work there traction.
Dirt car?
Re: Flaring tool [Re: P10crew] #5360832 02/26/20 05:12 PM
T
Traction Offline
T
Dirt car?
Actually it is a built from scratch, street legal tribute stock car, to all of the local Camaro's that ran at all of the dirt tracks all over the state of Iowa, years ago
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Flaring tool [Re: P10crew] #5360955 02/26/20 08:09 PM
P10crew Offline OP
Wow that is cool! Brings back memories fo sho!
I wondered why you would have a front park lock on a dirt burner.
Thanks for posting.
Re: Flaring tool [Re: P10crew] #5361406 02/27/20 10:58 AM
T
Traction Offline
T
Not trying to jump your thread, but the hydraulic park lock I use for a parking brake. Plus it works good for burnouts, and donuts. It would be fun to get it on a dirt track even as a pace car, but I would never get it clean again. Here is the whole story of how I spent 18 years to build a complete drivable car from a pile of steel tubing and parts.
https://bangshift.com/bangshiftapex...unique-homebuilt-corner-burning-monster/
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Flaring tool [Re: P10crew] #5361532 02/27/20 01:58 PM
P10crew Offline OP
Awesome story and awesome job. Thanks for posting!
Re: Flaring tool [Re: P10crew] #5362695 02/28/20 07:34 PM
J
jhellwig Offline
J
[Linked Image]
I didn’t know that they had 5/16 and 3/16 of those benders. What sizes are the ones in the pic? I do lots of stainless at work and have Swagelok benders. I have used the old rigid benders with the solid shoe and was intrigued buy those Swagelok knockoffs they are making now.
What are “steam” lines on a vehicle?
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
