Wait until you see who's driving...
by Shannow - 04/05/20 06:57 AM
Getting My Harley Back On The Road
by Silverado12 - 04/05/20 06:45 AM
Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
London, Dave66, Kurt_Kent_09, northestPM, dgvu89
71102 Registered Users
73 registered members (askani79705, atikovi, aircooled, Boomer, avi1777, Bud, 5 invisible), 1,869 guests, and 15 spiders.
Topics303,617
Posts5,238,430
Members71,102
Toyota NA vs Toyota Global... #5359679 02/25/20 11:11 AM
Mike L. V. Offline OP
2019 Toyota Corolla Hatchback XSE, North American Owners Manual recommends a 0W-16 or 0W-20 if 16 is not available. I found it very interesting that Toyota Japan and Toyota Austrailia recommend such a wide range of oil weights for the exact same model and engine combination.
Why wouldn't Toyota NA use the same broad spectrum of oil recommendations listed for Toyota Japan/Australia? MPG regulations?
This just goes to show that many engines can run nearly any weight of engine oil without catrosophic failures.
Personally after seeing the Australian owners manual oil recommendations I would feel comfortable running any oil viscosity listed here in the states.
Screenshot_20200225-110036_Acrobat for Samsung.jpgScreenshot_20200225-111245_Acrobat for Samsung.jpg
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359706 02/25/20 12:03 PM
P
parshisa Offline
P
I believe this has been discussed on the forum in the past. I've posted myself some info on my dad's camry that he owns in Eastern part of the world that specifies huge range of oil grades allowed to be used where's NA manual says 0w20 only. This proves again that "Tight tolerances" do not warrant only thin oils to be used.
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359714 02/25/20 12:15 PM
O
Oily_Thing Offline
O
I would use the recommended 0w16 in a good synthetic and not lose sleep over it.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359720 02/25/20 12:24 PM
I
Imp4 Online Content
Online Content
I
OEMs have been specifying 0w-16 in Japan for years.
Why not post an example of that as a justification for using a 0w-16???
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359723 02/25/20 12:25 PM
CT8 Offline
Why are we posting this?
2015 F150 2.7
2018 F350 6.2
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359724 02/25/20 12:29 PM
J
JMJNet Offline
J
Just to prove that oil is oil.
The car engines don't care, as long as it is oil.
Despite what people think, the car is soul-less. LOL!!!
Toyota engine is not picky.
  • 2017 Toyota Sienna
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359725 02/25/20 12:29 PM
R
Rolla07 Offline
R
Who cares what Toyota Japan or Toyota Australia recommends? Unless u live there. Id bet you could run anything without issue, but id use 0w16 or 0w20 for warranty purposes. What negative is there running 0w16 or 0w20? I cant think of any.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359731 02/25/20 12:44 PM
B
BMWTurboDzl Offline
B
Possible explanation: Higher sulfur levels in AUS gasoline.
435i
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359735 02/25/20 12:52 PM
Just an observation I found interesting since most OEMs recommend a certain weight when in reality one could probably run whatever.
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359764 02/25/20 01:28 PM
F
Farnsworth Offline
F
It tells right there “for cold weather starting” America has very cold weather and they sell the cars to be used in those areas in the winter including Alaska. It’s also up to each division like Toyota USA to make their own determinations and warranty service.
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359778 02/25/20 01:40 PM
N
nthach Offline
N
Toyota has also implemented a variable-volume oil pump on their new Dynamic Force engines rolling out with TNGA(but the 2016-present Prius still soldiers on with the 2ZR-FXE) but from a chat between The Critic and me, a different oil filter is used with 0W-16 service, while the standard issue F1/F2/B9(and the Wix/Fram replacements for which) are used with 0W-20 and thicker.
I'd stick with 0W-16 and not lose sleep over it. Toyota engineered the engine with 0W-16 in mind and the Japanese has been shipping cars with "thin" oil. Japanese and American driving isn't far different. Toyota is hamstrung by CAFE to list 0W-16 but also "thicker" oil is more appropriate for desert/tropical climates and dirtier gas like in Southeast Asia/South Asia(India/Pakistan/Bangladesh/Sri Lanka) and the Australian bush.
Re: Toyota NA vs Toyota Global... [Re: BMWTurboDzl] #5359781 02/25/20 01:42 PM
N
nthach Offline
N
Australia follows Euro specs for emissions and fuels. They are one of the major downstream producers for the Asia Pacific region but not as much as they did.
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359858 02/25/20 03:35 PM
O
OilUzer Offline
O
one theory :
NA is in general like leading edge of technology and new concepts are tested and/or tried here before other parts of the world ... It's like CA having more issues/concerns with lead than other states.
Re: Toyota NA vs Toyota Global... [Re: Mike L. V.] #5359868 02/25/20 03:44 PM
G
Gokhan Offline
G
I don't see any difference between US and international recommendations. US manual states a higher viscosity may be better suitable if the vehicle is operated at extreme speeds. They don't put an upper viscosity limit in US. There is no need to deviate from 0W-16 and lose mpg for 99% of driving conditions. I am averaging 70 mpg on gasoline on my Prius Prime with 0W-16.
One reason you see this in international manuals is the availability of oils abroad. I know in many countries 0W-20 and 5W-20 may not be available and 5W-30 may be rare, let alone 0W-16.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Toyota NA vs Toyota Global... [Re: Rolla07] #5359874 02/25/20 03:51 PM
I
Imp4 Online Content
Online Content
I
Agreed wholeheartedly.
My intent with mentioning the Japanese specs was to illustrate the somewhat odd notion that because it comes from overseas and it may be different, then it must somehow also be better.
It's an idea that pervades these boards.
Oddly, few posters seem to cherry pick the instances where a light weight oil is specified. And that puzzles me.
