New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
3+ weeks in, and no TP
by MrQuackers - 04/04/20 06:20 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
UOA, DexronVI, 26k miles, GM 6L80
by jetman - 04/04/20 05:37 PM
2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
northestPM, dgvu89, Kevin1987, Thetrashman33, YLK
71099 Registered Users
31 registered members (bachman, Cdn17Sport6MT, blufeb95, Bailes1992, avi1777, Ctopher, 1 invisible), 1,305 guests, and 22 spiders.
Topics303,611
Posts5,238,317
Members71,099
07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM #5359144 02/24/20 05:41 PM
P
PotatoFarmer77w Offline OP
P
Hey guys,
I have a 07 Ford Ranger with the DOHC 2.3 and 5 spd manual trans currently at 90k km. When I start the truck today I notice the whole truck is vibrating/shaking at idle. The vibration is at worst around 1000 RPM and goes away after 1500 RPM. There are no check engine lights or codes, and no funny smokes coming out of the exhaust. The only thing I noticed is a very slight knocking sound coming from underneath the truck near the firewall, but that could be the known exhaust leak near the cat. I know this engine is known to have some vibration but this is abnormal.
The truck is in winter storage right now and I start it up to let it warm up once or twice per month. Last time when it was running everything is normal. Before I put it into storage back in October I added fresh gas and fuel stabilizer. I did this every winter and never had a problem with it.
I'm a little bit lost here so any help would be greatly appreciated, thanks.
1995 Chevrolet K1500 5.7 v8
2007 Ford Ranger 2.3 I4
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359158 02/24/20 06:11 PM
P
PowerSurge Offline
P
Check the idle air control valve. It may be dirty or needs to be replaced.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359159 02/24/20 06:12 PM
M
mk378 Offline
M
Test drive to see if it's running on 3 cylinders all the time, if it is conduct a cylinder drop test to find which one. Look for stuff that happens in storage like rodent damage to the wiring.
Really you're not going to damage anything to disconnect the battery and leave truck alone until spring.
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: mk378] #5359171 02/24/20 06:25 PM
P
P
Yes, I just clean the IAC valve last spring...
If there's a misfire there should be a check engine light right? I do have to go for a road test when the weather is a bit warmer. The truck is parked in a garage to minimize rodent damage but I'll still look for any signs. Thanks!
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359191 02/24/20 06:48 PM
01rangerxl Offline
Fords can be funny about setting CELs. When the cat was failing on my 3.0, it would flash the CEL indicating a severe multiple cylinder misfire, but never actually set a code for that or the cat/O2 sensors.
Make sure the scanner you are using can show pending codes. If not, the ones they use to check codes at parts stores usually do.
Like mk378 said, I'd be looking for rodent damage/debris given the truck has been in storage and ran fine before. They really like the taste of some wiring insulation and plastic/rubber used for electrical connectors, emissions/vacuum hoses, etc. Make sure they didn't get into your air filter housing.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359204 02/24/20 06:56 PM
N
nobb Offline
N
Happened to my 3.0L. Sounds like a misfire, but not severe enough to trigger the CEL. If you have an OBD that supports it, there's a special Mode $06 advanced diagnosis for Fords that you can use to count the individually recorded misfires so that you can see which cylinder it is. I was able to do it via the Torque app. This is more useful than your standard CEL because the CEL codes don't tell you which cylinder the misfire is occurring in. For my case it was a bad fuel injector, but it could be anything air/fuel/ignition related.
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359205 02/24/20 06:57 PM
E
eljefino Offline
E
A cold misfire may be excusable in the computer's programming. Exhaust should smell rich, unless the injector's plugged.
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359390 02/25/20 12:18 AM
B
Black_Thunder Offline
B
I've had a few vehicles do this from sitting for awhile and moisture in the gas regardless of additives etc. sometimes they just need to burn it out.
but since its been in storage if its anything like around here might want to check for chewed up wiring etc. are these a Coil over plug engine? could possibly be a bad coil or something as well or chewed up plug wires but I'm thinking it doesn't have plug wires
if the engine light isn't on sometimes you need to let it run for a bit or drive it around to get it to throw a code and then you'd have something to go on.
once on my sister in laws old car either mouse/rabbit etc got into the engine bay and chewed off the back 3 spark wires and also chewed up the crank position sensor wiring and the car wouldn't even start. little varmints laugh
edit: i see what I've posted has already been touched on wink
I'd buy Callahan autoparts if I could.
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5359595 02/25/20 09:27 AM
A
ARCOgraphite Offline
A
Is that the Ford Lima engine or the DOHC?
The waste spark ignition on the dohc is flaky with 2 of the 4 plugs at negative initial firing GND to Center electrode
I would pull the plugs and install new wires and some denso TT plugs to get it firing well.
These plugs fire well both directions.
This is, of course, assuming you have a misfire situation
Maybe injector poor pattern or HG or IM leak too
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: ARCOgraphite] #5360297 02/26/20 12:54 AM
P
P
Thanks for the suggestion! I will dump in a bottle of water remover this weekend and see if it fix it.
It's the mazda DOHC
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5361061 02/26/20 09:59 PM
clinebarger Offline
2007 will have Live Cylinder Balance Data & Relative Compression test, No need to review Mode $06 data like older Fords.
Forscan is dirt cheap......ELM327 HERE
I bought a 1 year extended licence for $10, But free versions are available, The software is free...... https://forscan.org/download.html
2001 Chevy Camaro L92/4L80E
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: PotatoFarmer77w] #5361238 02/27/20 06:20 AM
L
Lubener Offline
L
Hey guys,
You're not doing it any favors letting it idle a couple times a month "just to warm it up". Only thing I do is keep the battery charged, on a stored vehicle. I never run the engine when stored for the winter.
You could have a fouled plug from all that idling.
The "thinking" man's friend.
Re: 07 Ford Ranger 2.3L 5spd - suddenly shaking/vibrate at idle or low RPM [Re: Lubener] #5361941 02/27/20 10:53 PM
P
P
Hey guys,
I was told years ago by an old mechanic that it's best to let it run every once a while. I guess he was wrong. The next thing I'm going to check will be the plugs and wires.
