Originally Posted by RDY4WAR
The thread is archaic for sure, but still a good topic that's largely still debated today.
With the move to group III base oils has come more advancement in group III base oils. What I've learned in this regard is that group IV PAO doesn't hold any appreciable advantage over group III outside of cold start performance. If you need a 0w-20 that can start easily in -40*F temps then it's a good way to go. Outside of that, group III base oils are actually preferable to group IV PAO due to better solubility, pressure-viscosity coefficient, and additive response. Even your higher end racing oils, where cost usually isn't a concern, have gone majority group III now for that reason, using smaller amounts of trimer PAO or mPAO and POE to get a higher flashpoint.
What about volatility Noack, less vi improvers and better long drain capability, that's where pao also does better.
Group III oils can achieve NOACKs of 7% or better. How many people are actually going 25k mile intervals? VII isn't much different until you get into oils like 0w-40 and 5w-50. I'm personally not willing to sacrifice additive response for longer drains. An ideal high performance synthetic oil will be a blend of groups III, IV, and V with group III having the largest share.
0w40 is popular so yeah we are getting into them. Also, using 25k as a long drain example is stretching it. I'd consider anything over 10k as getting into long drains for a PCMO. Not many group III oils are at 7% noack.
