Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
114 registered members (007, 53' Stude, 4WD, 762fermeandyou, 2010Civic, 2K2AcuraTL, 14 invisible), 1,731 guests, and 17 spiders.
Topics303,305
Posts5,233,629
Members71,038
6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? #5358678 02/24/20 08:36 AM
G
GMguy84 Offline OP
G
Thinking its the typical common intake gaskets leaks ?? smirk2
Valve cover gaskets were done last year with updated Fel pro blue gaskets
Application:
2001 Silverado HD LQ4 6.0 with 150K miles
Already New fuel pump, New WIX fuel filter, AC/DELCO tune up, LOTS of fuel cleaner, DEEP cleaned the intake with Gumout+PEA
No CEL, But my creade code reader got a codes P0171 P0174 ??
Very bad idle-sputtering in cold start, then after 2-3 minutes ECM compensates, warms up and runs great ??
Also i think i'm going nuts crazy, But looks like no EGR valve gasket also ?? Gonna get new one at AZ today and pull out EGR and see whats up ??
Dave
01 Silverado 1500HD 5W30 RTG/XG3675
07 Suburban 1500 LTZ CQ SYN HM 10W40/ M1-201A
09 Crown Vic Police SAP PKG 5W20 RGT/POBOSS
82 Trans Am (KITT) M1HM 10W40/XG5
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5358715 02/24/20 09:21 AM
ls1mike Offline
Have you ever replaced the intake gasket? It is probably time. The EGR stovepipe has an O-ring where it goes into the intake. The EGR itself has a gasket.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5358725 02/24/20 09:35 AM
Snagglefoot Online Content
Online Content
I have a 6.0 as well so I am interested in your issue. Here are some of the causes but you seem to have most covered. Can any of the Bitog mechanics chime in?
If you want the job done right......do it yourself.
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: ls1mike] #5358748 02/24/20 10:05 AM
G
GMguy84 Offline OP
G
Nope i havent replaced it yet. A job I dont have time/skill to do and prefer to find someone VERY qualifed to do !!
And I was referring to the EGR valve near the fan assembly. I have had MANY of these trucks and done a few EGR gaskets in the past. To me it looks like there's NOTHING between the EGR valve ??? shrug
[Linked Image]
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5358749 02/24/20 10:05 AM
classic70 Offline
Check IAC and clean well, check for vacuum leaks. Check fuel pressure to see what it is at idle.
2003 GMC Yukon 5.3 228k
1997 k1500 5.7 225k
1970 GMC C15 5.3 100k
2012 Honda Odyssey 118K
Big Stash
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: classic70] #5358766 02/24/20 10:21 AM
G
GMguy84 Offline OP
G
IAC i'll have to see. VAC leaks and fuel pressure have been checked before and nothing found ?? MAF sensor I haven't cleaned either ill do that tonight when I replace EGR valve gasket
Dave
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5358883 02/24/20 12:37 PM
ls1mike Offline
Here is the TSB number for the intake gasket problem.GM TSB #02-06-04-023A.
If you haver not done it at 150,000 it is time. The intake gasket on these takes about an hour and half. I have done about 10 of them. 5 on my own cars for various reasons. (2 on the WS6 for heads and cam and new LS6 intake, 1 on the Caprice for cam swap, 2 on my old 2500hd once to do knock sensors, once to do the actual gasket. 5 times on other people's stuff. Just about any Mechanic can do it. No oil or coolant touches the intake so it is simple.
My 02 2500HD did the same thing.
Those two codes with no check engine light are classic intake gasket. So it runs rough cold and smooths out with warm as the everything expands most likely partially sealing the gasket, but you still get unmetered air flow.
Have the Knock sensors ever been done?
How long have you owned it?
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5358991 02/24/20 02:41 PM
E
Eric Smith Offline
E
Is there a cut off year for intake gasket? Mine was a 02 build date in Express but had the new ones. 01 perhaps since Mike had a 02 (build date 01?) and this one is a 01? Pull one of the intake bolts and if it has blue loctite on it that might a good indicator?
05 Chevy 3500 (Class C RV) 71k
04 Escape 170k
02 Focus 152k
00 Dakota 95k
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: ls1mike] #5359392 02/25/20 12:21 AM
G
GMguy84 Offline OP
G
Ya Mike thinking the same thing on intake gaskets thumbsup I bought the truck last summer and just been using it around town carry parts/packages for my business, no towing or off roading.
And ya I know when the intake gaskets are done its best to replace the knock sensors, I know those are common failures also.
Sucks have to find a GOOD mechanic for that job. Back when I was in your neck of the woods few years ago, There was a guy who worked at a GM dealer in Tacoma who did stuff on the side in Olympia. His prices were VERY good for the skill and work he did.
Trying to find someone like that here in Dallas
Dave
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5359397 02/25/20 12:36 AM
G
GMBoy Offline
G
Dave
I am in the DFW area and can probably work your job into my schedule in a few weeks because I am backlogged at the moment. I work full time for the GM plant working 7 days a week plus running my shop. I've done a few including my own 6.0 in my Sierra Denali. It really is not a difficult job.
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMBoy] #5359437 02/25/20 02:35 AM
G
GMguy84 Offline OP
G
Dave
Awesome !!! thanks for the offer thumbsup So you work at the SUV plant in Arlington ?? Man you must be VERT BUSY at that place getting ready for new models coming out soon.
I guess PM me your info and we'll get in touch when your ready ???
I'll order the intake gaskets and knock sensors so i'm ready when you are thumbsup
Dave
Re: 6.0 LQ4 Rough idle cold start. ??? Bad Intake Gaskets ?? [Re: GMguy84] #5359447 02/25/20 03:58 AM
G
GMBoy Offline
G
Just replied to your PM
