50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
87 registered members (Alfred_B, ABN_CBT_ENGR, AandPDan, 1978elcamino, 77GrandPrix, 2015_PSD, 8 invisible), 2,478 guests, and 40 spiders.
Topics306,015
Posts5,284,850
Members71,558
Removing silicone spray overspray/residue #5358479 02/23/20 10:13 PM
Calikura Offline OP
As per title: used silicone spray to remedy chafing power windows, was mostly successful at keeping the bulk of the spray confined to the window tracks, but as with any aerosol coming out of a pressurised can, some of it got into the air and a number of small droplets got onto the seat bolsters, door sills, door armrest, et cetera. Thankfully, none of it got onto my steering wheel, wiper and turn signal stalks, and gear selector.
It's not a massive amount that causes my fingers or bum to slide around everywhere, but while it is a very small amount, I can definitely notice it being on certain surfaces. Some of the droplets are still visible on the (PU) surfaces.
What might work to remove it? Some enthusiastic rubbing with a mildly abrasive household sponge? Would some 70% or 90% isopropyl alcohol do the trick? Or... do I just ignore it (I probably could, for a few weeks) and will the silicone residue just rub away over time with normal use?
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358484 02/23/20 10:28 PM
J
JamesBond Offline
J
A wet rag
Re: Removing silicone spray overspray/residue [Re: JamesBond] #5358491 02/23/20 10:42 PM
Calikura Offline OP
That's what my intuition told me as well, but as someone relatively inexperienced with working with silicone lube, I needed the reassurance from someone who knows better that I wouldn't inadvertently spread the stuff everywhere with the rag, and turn a 15 minute DIY cleaning job into a day at a professional detailer's.
edit: Thanks, by the way!
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358497 02/23/20 10:53 PM
AZjeff Offline
Water isn't going to do it. A rag with dishwashing soap and some kind of degreaser might work. IPA isn't a bad idea either. Silicone is extremely hard to completely remove from surfaces, we have to be careful with it at work.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358512 02/23/20 11:30 PM
R
Rand Offline
R
I would probably just buff it with a dry microfiber rag. otherwise you will need a detergent and its hard to remove.
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358577 02/24/20 03:52 AM
O
Olas Offline
O
brake cleaner followed by a rag
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358654 02/24/20 07:57 AM
T
Trav Offline
T
Prep-Sol. Auto body shops use it for paint prep before painting, any auto body supply place will have it or similar product.
Use a silicone grease on the window tracks, apply with a Q tip.
Re: Removing silicone spray overspray/residue [Re: Calikura] #5358858 02/24/20 12:15 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
There are no practical solvents for silicone. Just keep at it with scrubbing and soap.
Re: Removing silicone spray overspray/residue [Re: Kestas] #5358878 02/24/20 12:32 PM
T
Trav Offline
T
Prep-Sol removes silicone from paint. A lot of waxes and coating contain silicone and will bugger a paint job up in a heartbeat if not removed, scuffing the paint does not guarantee complete removal and give you fish eyes.
Quote
3M Prep Solvent-70 effectively removes oils, wax, grease, and silicone
Re: Removing silicone spray overspray/residue [Re: Calikura] #5359328 02/24/20 10:23 PM
Calikura Offline OP
Thanks for all your suggestions!
I got the affected parts of the interior to become far less slick, and more of a 'squeaky clean', first with degreaser, then dish soap, then wet paper towels, dry paper towels, and gentle but persistent rubbing with a microfiber towel. I know it won't be 100%, but the interior wasn't immaculate to begin with and I'm not too bothered by the squeaky sound. As long as the surfaces aren't slick anymore.
Definitely dodged a big bullet this time, as a mishap with a spray could have been so much worse. Will switch to silicone grease for the automobile and keep the spray for household use.
Re: Removing silicone spray overspray/residue [Re: Calikura] #5435359 05/21/20 07:20 PM
T
Too3zln Offline
T
Vinegar
2015 Subaru Legacy 36,000 miles
2011 Chevy 2500HD Duramax 114,000 miles
2004 F-150 FX4 5.4 ticker 232,000 miles
