Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
95 registered members (762fermeandyou, 2015_PSD, 2002 Maxima SE, 53' Stude, 4WD, 2004tdigls, 8 invisible), 2,748 guests, and 20 spiders.
Topics303,643
Posts5,238,956
Members71,105
2007 Vibe coolant smell #5358436 02/23/20 09:36 PM
P
philipp10 Offline OP
P
I have a 2007 Pontiac Vibe, 1.8 L, auto. 110K miles. Been using the car to teach wife parrallel parking. When it heats up, I can smell coolant. It's a very faint whiff of it and I am not losing much if any coolant. Like over a year, maybe an ounce. I cannot detect the smell inside the cabin but standing outside, I can however, if I lift the hood, the smell quick dissipates.
Could the reservoir leak vapor and cause this? Would a new radiator cap help? Any ideas? No leaks on the ground and minimal loss of coolant over a year.....
Re: 2007 Vibe coolant smell [Re: philipp10] #5358445 02/23/20 09:43 PM
slacktide_bitog Offline
radiator caps do go bad, and they're not a lot of money, but if you do replace it, get an OE cap smile
Does the car overheat?
Re: 2007 Vibe coolant smell [Re: philipp10] #5358453 02/23/20 09:49 PM
O
oldhp Offline
O
If it has a coolant recovery tank, that's probably the smell. My new 17' Jeep Wrangler was doing the same thing. I learned to ignore it.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 2007 Vibe coolant smell [Re: slacktide_bitog] #5358469 02/23/20 10:01 PM
P
P
no overheating
Re: 2007 Vibe coolant smell [Re: philipp10] #5358472 02/23/20 10:02 PM
P
P
The wife complains it gives her a headache but it may be all the idling around the CO.
Re: 2007 Vibe coolant smell [Re: philipp10] #5358614 02/24/20 06:25 AM
STIcandy Offline
My 2006 vibe has it every now and then. Look at the radiator. If I look down from the engine bay, mine has some crusted engine coolant on the fins. It's "leaking" I suppose but I very seldom top it up and it's not dripping so I just monitor every oci.
Re: 2007 Vibe coolant smell [Re: philipp10] #5358620 02/24/20 06:32 AM
B
bullwinkle Online Confused
Online Confused
B
Watch the water pump weep hole, the 1.8s are known for seeping SLLC out of the hole. My mom's '06 1.8 Matrix does it occasionally and then suddenly stops again.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: 2007 Vibe coolant smell [Re: philipp10] #5358784 02/24/20 10:35 AM
N
nwjones18 Offline
N
If you aren't loosing any coolant (1oz in a year is none) then I wouldn't sweat it.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
