Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
26 registered members (928, Ammofirst, bachman, blufeb95, 14Accent, Bailes1992, 3 invisible), 589 guests, and 17 spiders.
Topics303,497
Posts5,235,142
Members71,061
MTD Snowblower issues #5358104 02/23/20 02:19 PM
9
97prizm Offline OP
9
Hi all,
I posted a little while back about my given to me free MTD Snowblower. I got rid of the old fuel, new spark plug and correct gap and a shot starter fluid for good measure. I picked up a bottle of carb cleaner from home depot that says to pour into the fuel tank and prime the carb and let it set. It was mechanic in a bottle Fuel system cleaner
I thought it was worth a shot. Unfortunately no matter what it seems like it won't even catch or try to fire. A new carb was quoted at $98 from mtd directly. Any thoughts. It's a tecumseh engine. My Briggs and Stratton powered push mower starts year after year.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: MTD Snowblower issues [Re: 97prizm] #5358125 02/23/20 02:39 PM
W
whatnext Offline
W
If it won’t even kick with starter fluid, then I suspect it’s not sparking. One way to check is to pull the spark plug, connect the ignition wire to it and with the curved electrode touching bare metal on the cylinder head, pull the starter rope. You should see the spark jump.
My mtd blower is from the 90s and the carb sucked (no mixture adjustments) so it ran poorly. The 2nd or 3rd year got tired of it and got a carb with the adjustable mixture screws and has been running like it suppose to at full power.
Re: MTD Snowblower issues [Re: 97prizm] #5358129 02/23/20 02:41 PM
JohnnyJohnson Offline
Now you know why Tecumseh is no longer in business. Are you getting any spark at your plug?
2004 Corolla 139577
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: MTD Snowblower issues [Re: 97prizm] #5358159 02/23/20 03:12 PM
I
Imp4 Offline
I
A replacement Chinese carb is $20 but, like others gave said, make sure there's spark first.
And fuel flow to the bowl...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: MTD Snowblower issues [Re: 97prizm] #5358280 02/23/20 06:20 PM
E
eljefino Offline
E
I have a chinese carb on my tecumseh rototiller. (I keep the engine because it has the rare backwards pulley for reversing.) It has no choke, just a primer, and I have to start it with starting fluid every darn time.
I say take apart your old carb. Start by ramming some thin wire, like found in a bread tie, up the main jet. If you can actually get the jet out, yay, more examination and cleaning can happen.
Re: MTD Snowblower issues [Re: 97prizm] #5358395 02/23/20 08:41 PM
A
Audios Offline
A
Pull plug and inspect, smell for fuel, check for spark.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: MTD Snowblower issues [Re: 97prizm] #5358449 02/23/20 09:47 PM
B
BrianF Offline
B
Also, how much cleaner is in there? Drain and add fresh fuel, ensure it's got spark and not flooded.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
