Forums Migration
Please read this thread
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
B2300 frame repair.
by simple_gifts - 07/08/20 01:48 PM
O2 sensor adapter with "mini catalytic converter"
by keantoken - 07/08/20 01:48 PM
Peeled veneer paint on vintage Pioneer
by Alfred_B - 07/08/20 01:40 PM
Shift Solenoids Cleaner additive?
by Husam - 07/08/20 01:11 PM
D rings for towing
by cknight49090 - 07/08/20 01:06 PM
Rotella T6 5w40 sale
by reaperman - 07/08/20 12:44 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
124 registered members (4WD, 77Se7en, 55hambone, afree, AdmdeVilleneuve, 379KITTY, 12 invisible), 1,886 guests, and 32 spiders.
Topics307,619
Posts5,314,346
Members71,888
How to get sediment out of heater oil tank? #5357903 02/23/20 09:37 AM
B
BAJA_05 Offline OP
B
Wondering how to remove sediment out of oil tank in basement? When there oil tank is run low and they get new oil put in -- sediment is clogging there lines. I know -- dont let it get that low in the first place right.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (48K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5357919 02/23/20 09:54 AM
W
walterjay Offline
W
If it is that bad they may want to consider a new tank.
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5357926 02/23/20 10:02 AM
K
Kira Offline
K
I've wondered that too.
Some fitting needs to be above the expected level of sediment/water....as stated above.
Design a clean out port into the side of a tank. It cannot possibly pay to retrofit one to an old tank.
What stinks is that water goes to the bottom of tanks and can rust.
Maybe a valved drain like on airplane fuel tanks?
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5357939 02/23/20 10:15 AM
A
ARCOgraphite Offline
A
Funny you say this, i just had a logged pump screen on my oil burner this past friday.
Dropped the tank filter and there was gritty crud and water blobs in the cup. The cart foam filter looked OK - no sludge.
I've been keeping the tanked topped up to to prevent moisture condensing in there since its open to the outdoors..
and the temps have been yo-yo ing something terrible.
20f then 45f, then rain then 10f next 40f then rain ...
50 degrees forecast today ! ? !
Back to the tank Now I think you can get an environment company to vacuum it. They have to clean them for removal and disposal
A couple jugs of alcohol should suck up the water.
Look at some HD Diesel additives for this
They making poly tanks now?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: How to get sediment out of heater oil tank? [Re: ARCOgraphite] #5357960 02/23/20 10:37 AM
B
BAJA_05 Offline OP
B
Same crazy/unpredictable weather here. I was wondering if they made an additive to break down the sediment but also not damage the lines or heater???
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5357975 02/23/20 11:01 AM
W
walterjay Offline
W
FYI a few years ago I had a customer with sludge in their oil tank. They put in an additive to break up the sludge and it made a terrible mess. Made the plugging worse. The burner lines and oil nozzles are too small on residential to handle all that.
I knew one other person with a tank that plugged things up after refilling and they would shut the oil burner down when filling and then leave it off for an entire hour. That solved their plugging problem.
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358005 02/23/20 11:32 AM
I
incognito_2u Offline
I
Wait........maybe I’m missing something here. You say it’s an Indoor tank (assuming it’s in a controlled environment) and your getting sediment/water inside the tank? Sounds like it’s coming from the Oil delivery company. Do you have a contract with a fuel company or do you get Cash on Delivery oil?
Tank needs to be vacuumed out and refilled with pure Number 2 Fuel oil. Get yourself some “Howe’s diesel treat” and treat at double the dosage first with a maintenance dose to follow.
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358014 02/23/20 11:46 AM
F
Fitter30 Offline
F
Gasoila makes a water detecting paste put on a stick inserted in the tank for a sample. The wool filter cartridges are 10 micron at 10 gph. Could use a hand pump to pull water from bottom of the tank.
https://www.amazon.com/Gasoila-Regu...=Kolor+kut&qid=1582475182&sr=8-5
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358149 02/23/20 02:59 PM
J
JohnG Offline
J
You might be dealing with bacteria growth. There are additives for that, but they are not normally needed in vehicles, so they are not included in the fuel for home heat either. Introduce just a little bio-diesel that is left in the delivery truck from a previous customer, and bang, bacteria.
The only way to clean a tank is, well, to clean the tank. The suction truck/environmental guys are the experts. They've seen it all before, trust me. Don't be afraid to do a rinse with a garden hose with high pressure. Suck the water out (same guys, same time) ventilate outside with hoses. They make a vortex suction funnel that is air powered, or just use the vac truck to get the water out.
Refill, and add bacteriacide if you can find it, done. You can even save to fuel that is in the tank if you get the right guys. They can just drum up the clean stuff and give it back to you when finished.
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358186 02/23/20 03:38 PM
CDX825 Offline
If the tank is old the last thing you want to do is try to clean the tank out. Not only will there be a lot of junk in it but also a good chance you will cause it to leak. Tanks rust from the inside out.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358210 02/23/20 04:21 PM
J
JohnG Offline
J
Quote
If it's that bad, It would be better to clean it and inspect it. The last thing anybody needs is a basement full of smelly diesel fuel! The environmental guys can also do Non destructive metal thickness tests AFTER the tank is clean. If it's badly pitted, its time is up.
So now you have another option, don't clean it, just replace it. Done.
Re: How to get sediment out of heater oil tank? [Re: BAJA_05] #5358343 02/23/20 07:42 PM
K
Kira Offline
K
1) A friend lived in a hollow where the oil truck had to go up and down steep hills. He swore that action stirred up whatever was in the truck's tank and got real good at cleaning/replacing orifices.
I always thought oil delivery trucks pumped from the bottom so their trucks stayed as contaminate-free as possible
Gasoline trucks dump from the bottom.
2) Steel tanks have to have a generalized lifespan. I grew up in a house with an inside oil tank. I remember my parents telling me that the cost of replacing the tank was factored into the cost of converting to natural gas. There has to be a rule of thumb about tank life.
3) +1 on not going the "solvent shortcut route". Send no bad stuff to your burner.
4) In Germany I saw framed plastic totes in basements for home heating oil. That made me lift an eyebrow. Punctures anyone?
Re: How to get sediment out of heater oil tank? [Re: Kira] #5358388 02/23/20 08:35 PM
W
Wolf359 Offline
W
Basically oil tanks last 40-60 years but I've seen some that were original to the house that were older than 60.
Oil tank itself is around $640.
https://www.homedepot.com/p/Vertical-275-Gal-Oil-Tank-275VOT/300636041
Pricing to swap them out varies, sometimes around $1000 depending on the company doing it and removal of the old one.
I've heard of some people doing it DIY. Run it dry, stick the rest in a bucket swap the tank. You can find used oil tanks on craigslists that aren't that old from people switching to natural gas.
Re: How to get sediment out of heater oil tank? [Re: incognito_2u] #5358745 02/24/20 10:00 AM
A
A
Its indoors. Basement is about 55deg in the winter.
When you get 90-100% humidity in a rain storm, the tank vent is open to ATM outside.
Quarts of water will condense on the wall of a 1/4. 1/2 full tank in a couple hours.
Then it settles on the bottom.
I think there is at least 5 gal on the bottom below the bung.and supply spigot.
Bet its mostly water.
Re: How to get sediment out of heater oil tank? [Re: Kira] #5358747 02/24/20 10:05 AM
A
A
Im on a steep hill.
But im sure the stop ligts and snakey roades around here still thing up just fine.
Of coures it teh fill of teh home tank thts stirring up sediment.
Age old problem with gas and oil
and Service Stations.
Remember the old guys telling you " dont get gas when they are filling the tanks!"
Now you have E10 then if that get jat a a little water in it, now ALL of that is on the bottom!
and you have 85 or less octane regular phase separated on top.
Happens many time a year to me.
An this is an engine killer.
