Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
3+ weeks in, and no TP
by MrQuackers - 04/04/20 06:20 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
UOA, DexronVI, 26k miles, GM 6L80
by jetman - 04/04/20 05:37 PM
2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
northestPM, dgvu89, Kevin1987, Thetrashman33, YLK
71099 Registered Users
24 registered members (928, bachman, Char Baby, Cdn17Sport6MT, ctechbob, blufeb95, 2 invisible), 1,184 guests, and 17 spiders.
Topics303,612
Posts5,238,335
Members71,099
Oil additive and effects on oil analysis results #5357969 02/23/20 10:48 AM
M
MoneyJohn Offline OP
M
If I add Kreen or Gumout Multi-system Tune up (6oz in 3qt sump), what difference it may make to the oil analysis results. Does anybody have an idea or an educated guess?
Thanks in advance.
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5357978 02/23/20 11:02 AM
demarpaint Offline
Added to the oil? For starters it is probably going to drop the viscosity, it might increase the wear metals as well, perhaps from cleaning, maybe not. Either way if you're looking for an accurate UOA I wouldn't taint what's in the sump with a strong solvent.
God Bless Our Troops
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5358029 02/23/20 12:16 PM
B
blufeb95 Online Content
Online Content
B
Why don't you see for yourself, drain off your oil, take a small sample, then add the oil back to the engine and add the MSTU, then when you're done with your flush collect another sample when you drain it off.
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5358037 02/23/20 12:32 PM
B
BAJA_05 Offline
B
When I had Black Stone perform a UOA on my Acura in signature -- I told them/noted that I used Chevron Techron Complete Fuel System Cleaner in my oil that I sent them. There reply to me -- that the fuel system cleaner would not show up on a UOA. That was about 2 years ago by now.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Oil additive and effects on oil analysis results [Re: BAJA_05] #5358051 02/23/20 12:52 PM
csandste Offline
Dale
But OP was talking about putting it in the sump. I also bought some of that Gumout and was thinking about putting most in gas and a few ounces in sump before oil change-- have been doing it with Marvel for a couple OCI's.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5358056 02/23/20 01:15 PM
B
Online Content
B
The oil additive itself won't show on the UOA, but signs of a oil additive may, like reduced viscosity, possibly lowered flash point, and the solvent might get registered as fuel dilution.
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5358084 02/23/20 01:56 PM
T
Triple_Se7en Offline
T
BAJA
Techron Fuel System Cleaner in the oil? Is there a dosage recommendation on the back of Techron bottle?
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Oil additive and effects on oil analysis results [Re: Triple_Se7en] #5358145 02/23/20 02:53 PM
B
Online Content
B
Originally Posted by Triple_Se7en
BAJA
Nope, it is strictly sold as a fuel additive.
Re: Oil additive and effects on oil analysis results [Re: blufeb95] #5358165 02/23/20 03:18 PM
I
Imp4 Offline
I
Best comment of the thread.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Oil additive and effects on oil analysis results [Re: MoneyJohn] #5358253 02/23/20 05:40 PM
CT8 Offline
Why would you do a uoa on a cleaning interval? I have to ask.
2015 F150 2.7
2018 F350 6.2
Re: Oil additive and effects on oil analysis results [Re: CT8] #5358264 02/23/20 05:54 PM
RDY4WAR Offline
As carbon deposits form throughout the engine, they can trap wear particles in them. If you dissolve those carbon deposits with a flushing oil, those wear particles will go back into suspension. A UOA will show those wear particles.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Oil additive and effects on oil analysis results [Re: RDY4WAR] #5358284 02/23/20 06:28 PM
I
Imp4 Offline
I
Not sure how an oil knows it's a 'flushing oil' and that it would dissolves deposits at a rate different than any 'non-flushing oil'. And a solvent would throw the data off even further.
But let's pretend it did. Maybe it had 'intelligent molecules'.....
The result would be an oil with non-representative characteristics for the OCI being run. It would show, relatively speaking, higher wear/contamination rates per mile than is typical for the engine as the 'flushing effect' dissolved all those extra deposits/wear particles.
Now, we all know that oil analysis data is best utilized when it is part of a program that tracks trends over time on an individual engine. So how would a trending analysis program with known controls use data from an OCI that was uncontrolled by definition???
Seems like a bunch of mumbo jumbo but maybe there's something I'm not taking into consideration...
Cheers!!!
cheers
Re: Oil additive and effects on oil analysis results [Re: CT8] #5358290 02/23/20 06:34 PM
demarpaint Offline
Exactly my thinking. Why set yourself up for unwarranted concern, by tainting the oil with a solvent? Find an oil you like, run it for 2 OCI's, do a UOA after the second OCI. That should give an untainted snapshot of how the oil is doing in the engine, and if there are problems with poor air filtration, fuel dilution, coolant in the oil, etc.
Re: Oil additive and effects on oil analysis results [Re: Triple_Se7en] #5358323 02/23/20 07:17 PM
csandste Offline
BAJA
Not Techron, Gumout Multisystem, unlike other Gumouts, this lists oil. I plan on 75 percent gas, 25 oil.
