It's not scientific but you should get the idea of which oil you might want to use in the winter.
Olas said:Now if Mobil 1 5W30, you may be correct, though I don' know the latest base stock blend.
The latest SDS I've seen for plain jane Mobil1 5w30, is less than 10% PAO, 10-20% GTL, and the rest would probably be hydrocracked crude.
I'm sure even like it is right now it will be more than adequate for most situations.
