Amber Alerts at 5am
by rekit - 04/08/20 03:16 PM
MC FL-910S cut open
by kstanf150 - 04/08/20 03:12 PM
Cartridge Weight Question
by Gebo - 04/08/20 02:54 PM
Auto insurance rate cut
by Wolf359 - 04/08/20 02:18 PM
Do you "correct" your service technician or not?
by SevenBizzos - 04/08/20 02:07 PM
How to keep glasses from fogging up?
by Chris142 - 04/08/20 01:58 PM
1.6 EB ,RL 5w20,18175 miles OCI,TAN>TBN
by ovidiu - 04/08/20 01:02 PM
cut ADBV in Mobil1 oil filter
by RavenTai - 04/08/20 12:55 PM
Oil shopping USA vs France
by M119 - 04/08/20 11:50 AM
Blackstone labs... open??
by researcher - 04/08/20 11:41 AM
Hyundai 2.4 Engine Issues
by Hallj49803 - 04/08/20 11:36 AM
Do old style centrifugal filters do anything?
by atikovi - 04/08/20 11:34 AM
NAPA oil deals
by Oildudeny - 04/08/20 11:17 AM
Oil weight spec thinning over time?
by MontePrix28 - 04/08/20 10:12 AM
High Performance Lubricants PDS
by High Performance Lubricants - 04/08/20 10:11 AM
13 Hyundai Sonata 24 vs 12 Jetta 2.0 TDI
by Hallj49803 - 04/08/20 10:09 AM
Mustang 4.6L spark plug change
by kstanf150 - 04/08/20 10:03 AM
Cutting Cable-Roku?
by PontiacHO - 04/08/20 09:59 AM
Mor gas price fun.
by Chris142 - 04/08/20 09:42 AM
LMVLS1, Jotorobi, jhoffy22, EcoBoosted, mmich187
71126 Registered Users
110 registered members (AC1DD, 53' Stude, 762fermeandyou, 2009Edge, 007, 2015_PSD, 5 invisible), 2,704 guests, and 16 spiders.
Topics303,776
Posts5,241,727
Members71,126
Conventional VS Synthetic In The Winter Months #5357767 02/23/20 02:36 AM
BlueOvalFitter Offline OP
It's not scientific but you should get the idea of which oil you might want to use in the winter.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5357782 02/23/20 04:25 AM
O
Olas Offline
O
Pennzoil dont make any full synthetics. Video and title are disingenuous.
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5357797 02/23/20 05:45 AM
Snagglefoot Offline
Olas, if this is a Group 3 vs Group 4 discussion, please start your own posting instead of trying to hi-jack BlueOval’s and go ahead and write a letter to Pennzoil. coffee
If you want the job done right......do it yourself.
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5357814 02/23/20 07:28 AM
T
Triple_Se7en Offline
T
Had both the conventional and synthetic been produced with the same [email protected] temps, then the overnight test would be a more correct challenge.
So try this test with a brand name that has a thicker synthetic than it's counterpart conventional next time. Then the test results would become 180 degrees opposite.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / AC Delco PF 1127
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Conventional VS Synthetic In The Winter Months [Re: Triple_Se7en] #5357835 02/23/20 07:53 AM
Snagglefoot Offline
I think the point here is the Pennzoil conventional has a CCS viscosity of 5950 mPa s and the Pennzoil full synthetic has a CCS viscosity of 4450 mPa s both at -30 C as they were both 5w30 oils. Unless someone makes a conventional oil with a CCS viscosity of 4450, the synthetic oil will pour out faster as in the video. I took the data from www.pennzoil.com .
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5357860 02/23/20 08:31 AM
53' Stude Online Content
Online Content
Snagglefoot: so in laymans terms PP/PU are good, serviceable oils smile. thumbsup
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Conventional VS Synthetic In The Winter Months [Re: 53' Stude] #5357873 02/23/20 08:51 AM
Snagglefoot Offline
For the $10 bucks they give me, yes!
laugh
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5357875 02/23/20 08:56 AM
B
BigCahuna Online Content
Online Content
B
I'm sure glad my motor has a motor driven pump, to distribute the oil thru out the motor instead of a coffee cup. As long as there's a coating of leftover oil on the internal parts, no matter how cold it is, there will be lubrication on a cold start. If it didn't, you might only get a 10 start lifespan on your motor. In the temps the guy was talking about, a low or dead battery will cause you more grief then how fast pumped oil will flow.,,,
Re: Conventional VS Synthetic In The Winter Months [Re: Olas] #5357884 02/23/20 09:07 AM
A
ARCOgraphite Offline
A
Originally Posted by Olas
Pennzoil don't make any full synthetics. Video and title are disingenuous.
Well it is a synthesized oil, but its just a form of alkane, the molecule must be branched given its low temp pumpability.
Now if Mobil 1 5W30, you may be correct, though I don' know the latest base stock blend.
Now for t the REAL elephant in the room ...
Winter in La ? smile
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Conventional VS Synthetic In The Winter Months [Re: ARCOgraphite] #5357886 02/23/20 09:10 AM
4WD Offline
Or you could state that about two dozen motor oils … but you don’t
Re: Conventional VS Synthetic In The Winter Months [Re: ARCOgraphite] #5358018 02/23/20 11:51 AM
B
bullwinkle Offline
B
Isn't that when it gets below 50F? I don't know how one handles the humidity in summer there, it's bad enough here! And Group III or GTL makes a fine synthetic base stock, unless "im Deutschland"!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Conventional VS Synthetic In The Winter Months [Re: ARCOgraphite] #5358031 02/23/20 12:27 PM
B
blufeb95 Online Content
Online Content
B
[quote=Olas]
The latest SDS I've seen for plain jane Mobil1 5w30, is less than 10% PAO, 10-20% GTL, and the rest would probably be hydrocracked crude.
Re: Conventional VS Synthetic In The Winter Months [Re: BlueOvalFitter] #5358090 02/23/20 02:02 PM
B
benjy Offline
B
there are synthetics + there are real synthetics, BUT even the cleaner more refined fake synthetics trump conventionals for a minimal cost. where real synthetics come into play is extreme conditions, as for cold temps i seen a graph on machinery lubrication showing that real synthetics thicken at a MUCH SLOWER rate in the cold + REMEMBER the cold spec is at 40C IS 104F so your typical group III is ALREADY thicker setting outside in your oil pan than the SPEC shows. the question is do you really need oil that costs 2 to 3 times more $$$. another reason to NOT extend changes as the additives "GO AWAY" with time + miles so the pour point depressants + viscosity improvers are less!!
Re: Conventional VS Synthetic In The Winter Months [Re: benjy] #5358120 02/23/20 02:35 PM
B
bbhero Offline
B
Interesting points ^^^^^
Many people forget what you are saying in that last sentence.... All oils are allowed to slip a W garde while in service... So a 5w can become a 10w... A 0w can become a 5w...
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Conventional VS Synthetic In The Winter Months [Re: Snagglefoot] #5358123 02/23/20 02:38 PM
B
bbhero Offline
B
Great point snagg.... All this video does is justify and verify the CCS results given by Pennzoil... And that BOTH of those oils would be just fine in service.
