Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
95 registered members (2015_PSD, 2002 Maxima SE, 53' Stude, 4WD, 2004tdigls, 2oldtommy, 8 invisible), 2,754 guests, and 20 spiders.
Topics303,643
Posts5,238,956
Members71,105
Paint Splatter #5357760 02/23/20 01:54 AM
R
rrretiree7 Offline OP
R
I got some touch-up paint on a tail light. Can I use goof-off or some lighter fluid to remove it? Thanks, guys
Re: Paint Splatter [Re: rrretiree7] #5357763 02/23/20 02:19 AM
9
97prizm Offline
9
I'd be careful of using chemicals to remove paint as it can damage plastic. I think goof-off is supposed to work well but check the label. Headlight lens polish might be a good starting point as its designed to clean up plastic.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Paint Splatter [Re: rrretiree7] #5357778 02/23/20 03:12 AM
W
Wolf359 Offline
W
Goof off is pretty strong. I wouldn't use too much of it and be ready with water to dilute it and don't leave it on too long. If you let it sit, it will dissolve the poly on the floor so it can probably do that to the plastic too. Wear gloves.
Re: Paint Splatter [Re: rrretiree7] #5357790 02/23/20 05:22 AM
demarpaint Offline
I'd try WD40 and a clay bar or Micro Fiber towel, or both. Goof-Off might ruin the plastic.
God Bless Our Troops
Re: Paint Splatter [Re: rrretiree7] #5357795 02/23/20 05:36 AM
PimTac Offline
Plastic razor blades.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Paint Splatter [Re: PimTac] #5357796 02/23/20 05:44 AM
demarpaint Offline
+1 They work well with WD40.
Re: Paint Splatter [Re: rrretiree7] #5357828 02/23/20 07:49 AM
spasm3 Offline
Easy to haze the light with chemicals. I'd try a small pick and pick it off mechanically.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Paint Splatter [Re: rrretiree7] #5357944 02/23/20 10:17 AM
F
FT92 Offline
F
fine rubbing compound ?? depends on how big the splatters are
Re: Paint Splatter [Re: rrretiree7] #5357983 02/23/20 11:04 AM
W
walterjay Online Content
Online Content
W
Did you get spatter or overspray on the lens?
