Plenty of data presented by JASO can be found on what they've found regarding gearboxes and pitting with low viscosity oils in shared transmissions.
http://fuelsandlubes.com/digital/fli/201...html/page8.html
Quote:
For motorcycles, tests were conducted using various viscosity grade oils. Yoshinobu presented the results. SAE 5W-30 oils with an HTHS viscosity of 2.7-2.9 caused gear pitting during the tests. In contrast, SAE 10W-30/40 and 20W-40 had no pitting, which were measured using motorcycles from four vendors. The current JASO document specifies a minimum HTHS of 2.9. Given the test results, it may be difficult to lower viscosity substantially in the upcoming revision to JASO T903: 2011, he said
