New WEN 56225i First Oil Change 1 Hour
by gathermewool - 04/08/20 05:04 PM
Fast Food Specials Dissapeared
by 007 - 04/08/20 04:17 PM
Amber Alerts at 5am
by rekit - 04/08/20 03:16 PM
MC FL-910S cut open
by kstanf150 - 04/08/20 03:12 PM
Cartridge Weight Question
by Gebo - 04/08/20 02:54 PM
Auto insurance rate cut
by Wolf359 - 04/08/20 02:18 PM
Do you "correct" your service technician or not?
by SevenBizzos - 04/08/20 02:07 PM
How to keep glasses from fogging up?
by Chris142 - 04/08/20 01:58 PM
1.6 EB ,RL 5w20,18175 miles OCI,TAN>TBN
by ovidiu - 04/08/20 01:02 PM
cut ADBV in Mobil1 oil filter
by RavenTai - 04/08/20 12:55 PM
Oil shopping USA vs France
by M119 - 04/08/20 11:50 AM
Blackstone labs... open??
by researcher - 04/08/20 11:41 AM
Hyundai 2.4 Engine Issues
by Hallj49803 - 04/08/20 11:36 AM
Do old style centrifugal filters do anything?
by atikovi - 04/08/20 11:34 AM
NAPA oil deals
by Oildudeny - 04/08/20 11:17 AM
Oil weight spec thinning over time?
by MontePrix28 - 04/08/20 10:12 AM
High Performance Lubricants PDS
by High Performance Lubricants - 04/08/20 10:11 AM
13 Hyundai Sonata 24 vs 12 Jetta 2.0 TDI
by Hallj49803 - 04/08/20 10:09 AM
Mustang 4.6L spark plug change
by kstanf150 - 04/08/20 10:03 AM
LMVLS1, Jotorobi, jhoffy22, EcoBoosted, mmich187
71126 Registered Users
105 registered members (4WD, 53' Stude, aquariuscsm, 762fermeandyou, 2015_PSD, 28oz, 7 invisible), 2,794 guests, and 18 spiders.
Topics303,778
Posts5,241,779
Members71,126
MTF drain = chocolate milk #5357686 02/22/20 11:02 PM
T
Texasdoc Offline OP
T
I have a TKO 600 with no external coolers/pumps, etc. It has about 4000 miles total on it - weekend/sunny day car only. I have run it pretty hard on the track a handful of times (maybe 6 days over the last 3 years). After the initial break-in, I changed the oil to Valvoline MTF. The manual calls for ATF for the 1st 500 miles, then GM Synchromesh and Valvoline was what O’Reilly had. The bottle says it is compatible with the GM stuff.
Over the last few weeks my tranny has been hard to get into gear. Any gear. (I know, I need to check the clutch disengagement). Anyway, I decided to change the oil. The tranny is known for its notchy shifting and I have a buddy who raves about Amsoil, so I figured I’d try it. When I drained the old Valvoline stuff out, it looked like chocolate milk. It was still pretty thick and I didn’t see much particulate material (I didn’t look that closely at the time). It didn’t smell burnt. I don’t have any other fluids that can get in there. No water/antifreeze/motor oil, etc has access to the tranny. It is just a self contained unit. It has not been out in the rain - no way for water to get inside.
Would the residual ATF left in the case after draining, mixed with Valvoline MTF cause a chocolate milk appearance?
I haven’t put the Amsoil MTF in yet. I hate to “waste” $20/qt Amsoil if I will need to drain and fill again in xxx miles. Should I fill it with cheaper MTF or other gear lube, run it for 100 miles, then D/F with Amsoil?
Any other thoughts?
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357692 02/22/20 11:14 PM
A
AC1DD Offline
A
Factory told you GM synchromesh and you used valvoline mtf. which specific product
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357703 02/22/20 11:33 PM
4WD Online Confused
Online Confused
Valvoline Synchromesh is what, $10/quart … Can you run one bottle through with plugs out before the AMSOIL?
Redline MTL is also popular for synchromesh applications
Re: MTF drain = chocolate milk [Re: AC1DD] #5357722 02/22/20 11:57 PM
T
Texasdoc Offline OP
T
How, exactly, does this help? The FACTORY didn’t tell me anything. The AUTHORIZED TREMEC Dealer I bought the thing from said the Valvoline was ok. Even Tremec can’t decide what version of GM synchromesh to use, every website you visit gives you a different answer. Sometimes Tremec recommends GM 12345349, sometimes ATF, sometimes Dexron III - they don’t make that anymore, sometimes ATF then synchromesh. — So I went with the Valvoline MFT Synchromesh that says it is compatible. Again, how does this help the current problem?
Yeah, good idea. I may even have a bottle sitting around. Plug the drain, put in a quart, spin it around a bit, let it sit, then drain it.
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357742 02/23/20 12:35 AM
A
AC1DD Offline
A
The FACTORY didn’t tell me anything. The AUTHORIZED TREMEC Dealer I bought the thing from said the Valvoline was ok. Sometimes Tremec recommends GM 12345349,
Never count on a dealer to be competent. You mentioned here that tremec said use GM fluid.
Use that GM fluid the factory calls for.
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357747 02/23/20 12:56 AM
O
oldhp Offline
O
TREMEC now makes there own fluid for their transmissions. Give them a call.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357781 02/23/20 04:24 AM
M
montero1 Offline
M
I'd use Mobil 1 Synthetic ATF. I see nowhere on their website that calls for MTF of any kind.
https://www.tremec.com/faqs.php
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 V-Star 1300 Deluxe (Hers)
'13 VFR1200F
'14 Porsche Cayman
'16 Harley Electra Glide Limited
'18 GMC Canyon Denali (Hers)
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357785 02/23/20 04:28 AM
O
Olas Offline
O
drain and fill with cheap stuff. repeat until no more milkshake comes out.
fill with the appropriate Redline or Schaeffers product (they are world leaders in gear oils)
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357799 02/23/20 06:09 AM
Z
zeng Offline
Z
cholocate milk is surely water contamination in thousands of ppm .
I hear you discounting such .
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357801 02/23/20 06:32 AM
demarpaint Offline
I'd say water is finding its way into the transmission. I'd get the spec'd fluid, drain the unit, drive it a bit and repeat. Look for possible water entry points. Then drain and check the fluid condition in a thousand miles. After that keep an eye on it to see if it is changing color after some heavy rain storms. You can do that by extracting or draining a small sample and topping it off.
God Bless Our Troops
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357810 02/23/20 07:24 AM
Mr Nice Offline
What vehicle is this ?
I would only the Manufacturer spec fluid for now.
Re: MTF drain = chocolate milk [Re: Mr Nice] #5357859 02/23/20 08:30 AM
T
Texasdoc Offline OP
T
It is a kit cobra. Its not even driven thru puddles, much less in the rain. I just don’t see how it can be water.
Except now they even recommend their own MTF - specs say it is a GL-4 75W-85 gear oil (whatever that means).
Tremec MTF
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357867 02/23/20 08:44 AM
O
Olas Offline
O
trans-fluid cooler built into the radiator would allow water ingress and mixing if it were faulty. Failed water/oil heat exchangers make people think theyre HG is failing, similar effect is in play here maybe?
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357878 02/23/20 09:00 AM
cronk Offline
I had a pickup with a new venture 3500 transmission that called for gm synchromesh fluid.
The trans was a bit worn out and the shifting was notchy. I tried the Gm fluid, Pennzoil synchromech, and Amsoil synchromesh. The shifting was noticably better with the Amsoil fluid than the other 2.
As far as the milky look, it is normally moisture, although I guess it could possibly be from mixing 2 different fluids.
If there is a vent on top of the transmission, I would make sure moisture isnt making its way in that. Like if there is a vent nipple that needs a hose attached to it, or ac condensate water isnt running down near the vent.
I would probably get some of the cheaper valvoline or Pennzoil fluid, and put that in as a flush and drive it for 50-100 miles to get it hot and dump it. Then install the Amsoil fluid.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: MTF drain = chocolate milk [Re: Texasdoc] #5357961 02/23/20 10:38 AM
O
oilpsi2high Offline
O
OP my Cobalt SS had milkshake MTF when I did the first change around 30,000 miles. That was ten years ago or so. I’m at 150,000 miles now.
I’m not sure what causes it. The OEM fluid is dark red btw. My guess would be moisture easily getting in through a vent, coupled with wear material and just age.
Not being able to go into gear is concerning. Did a fluid change fix that? I’d start by finding out what the proper fluid is for your trans and then doing a drain and fill with that. Check the drain plug magnet for shavings - install one if you don’t have one.
