AZjeff
$50 Site Donor 2023
Are you a finesse guy or a brute force guy? I guess I've always been a finesse guy, if I encounter a stuck nut or bolt or things aren't going together correctly I'll slow down and try work the problem out. I've worked with guys who will twist the nut or bolt until something gives and deal with the outcome. Either it lets go or breaks, no time for penetrating oil or heat. Or, pound or pry things into position never mind what it looks like, just get er done. This came to mind the other day when I was dealing with the handiwork of a former coworker.
Of course there are times you have to do what you have to do, and I can see where the overpowering force technique gives an instant result with a 50/50 chance of being good.
