2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
50 registered members (2018matto, 928, alchargo, Avery4, Aredeeem, BHopkins, 5 invisible), 1,586 guests, and 23 spiders.
Topics305,925
Posts5,282,877
Members71,537
Good aftermarket shocks and struts? #5356885 02/21/20 10:49 PM
M
Micahmcmeen Offline OP
M
I am on the lookout for some quality aftermarket shocks and struts. I don't want to do quick struts as I have heard bad things.
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356901 02/21/20 11:07 PM
W
Wolf359 Online Content
Online Content
W
You've heard bad things because they're so popular. You're always going to hear bad things when things are sold in volume.
The best are usually OEM. But they're expensive which is why there's the aftermarket.
Quick struts are safer too, don't have to take the spring apart which can be dangerous if it lets go. I'd also replace the springs too because if the struts are worn out, the springs are probably worn out too.
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356913 02/21/20 11:15 PM
1
14Accent Offline
1
Vehicle info?
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Good aftermarket shocks and struts? [Re: 14Accent] #5356919 02/21/20 11:18 PM
M
M
2010 jeep commander.
Re: Good aftermarket shocks and struts? [Re: Wolf359] #5356920 02/21/20 11:18 PM
M
M
What quick struts would you suggest
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356925 02/21/20 11:24 PM
Nick1994 Online Content
Online Content
Rock Auto sells Mopar struts and shocks, price isn't too bad. That's what I'd use.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356944 02/21/20 11:50 PM
G
geeman789 Offline
G
Bilstein's, if available for your application, have been decent in a couple of past cars. I also had a set of Koni sport yellows that were very good.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356958 02/22/20 12:36 AM
slacktide_bitog Offline
If you're not using quick struts, get Bilstein 4600 smile
If you do consider them, the only name-brand quick struts made for your car are Monroe, so they would be the best quick struts to get
Too bad Mopar doesn't offer OEM quick struts (Ford and Honda have started offering complete assemblies from the dealer)
Re: Good aftermarket shocks and struts? [Re: geeman789] #5356966 02/22/20 01:00 AM
CKN Offline
Those things can be teeth jarring.........
KONI Sport (yellow). The KONI Sport dampers are designed for aggressive driving or cars with suspension upgrades while continuing to offer comfort. If a KONI Sport is listed as an alternative to the KONI Special, choose Sport for aggressive handling characteristics. (i.e. "stiff")
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5356997 02/22/20 03:21 AM
O
Olas Offline
O
H&R are excellent.
Also look at Eibach, Bilstein, Koni, Leda, Gaz and Penske.
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5357000 02/22/20 03:25 AM
1
14Accent Offline
1
Definitely go with the Bilstein 4600 series, if you're looking for a comfortable upgrade. I've yet to read anything negative about the B6 line, it should be a solid upgrade.
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5357069 02/22/20 07:37 AM
dnastrau Offline
I put Gabriel Ultra G57083 quick struts on our 2008 Commander two years ago and they have been good so far (about 30K miles). RockAuto has them.
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5357070 02/22/20 07:39 AM
dlundblad Offline
Sachs, Bilstein or OE.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Good aftermarket shocks and struts? [Re: Micahmcmeen] #5357081 02/22/20 07:59 AM
Donald Offline
Bilstein are excellent shocks & struts and lifetime warranty.
2015 Ford F-250 w/Powerstroke
Re: Good aftermarket shocks and struts? [Re: CKN] #5357103 02/22/20 08:31 AM
supton Offline
Aren't yellows adjustable? Been a while, but I had red's, and they could be adjusted. But. They could only be adjusted off the car! while yellows could be adjusted on the car. I guess that is how they make money... Anyhow, when I had Koni Red's, when set to near full stiff, they were stiff. They eventually went bad and the shop went against my (not well communicated) wishes and put them in near full soft. I couldn't tell the difference between soft and dead.
YMMV.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
