Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
70 registered members (b1amgm47, amh, AandPDan, BlakeB, 87sammy, 6 invisible), 2,331 guests, and 36 spiders.
Topics306,039
Posts5,285,412
Members71,572
Flywheel pic #5356794 02/21/20 08:49 PM
Chris142 Offline OP
Got the transmission out of my jeep today. The throw out bearing is definitely bad. Clutch and flywheel are like new. No burns on the flywheel so I wont surface it.
Sorry for the bad pic.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Flywheel pic [Re: Chris142] #5356797 02/21/20 08:53 PM
W
wings&wheels Offline
W
Were you getting a squeal or chirp? Curious, I am getting a occasional squeal from my Series just as I depress the clutch.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Flywheel pic [Re: wings&wheels] #5356800 02/21/20 08:55 PM
Chris142 Offline OP
It started as a scream on cold starts. Then I could hear it grinding when I pushed the clutch down.
Re: Flywheel pic [Re: Chris142] #5356844 02/21/20 10:05 PM
A
atikovi Offline
A
Looks like some glazing. I'd at least go over it with a disc.
[Linked Image from fototime.com]
Re: Flywheel pic [Re: Chris142] #5356853 02/21/20 10:18 PM
W
W
Thanks. Good luck. I'm looking at this myself...
'05 Lotus Elise S/C
'74 Triumph TR6
'74 BMW 2002
'99 Porsche 996
Piper Pa28-236
Re: Flywheel pic [Re: Chris142] #5356873 02/21/20 10:41 PM
Driz Offline
I can’t see how a clutch and pressure plate could make it scream when it’s cold. It would pulsate or grab unevenly I would think. The one thing that I could see and it’s dirt cheap is the tiny pilot bearing in the middle of the engines crankshaft. Its so cheap, a few $$$ literally I’d replace it just because...... The throw out bearing might be the culprit too, again pretty cheap to save yanking it apart again.
Re: Flywheel pic [Re: Driz] #5356878 02/21/20 10:43 PM
Chris142 Offline OP
I bought the whole kit with both bearings and clutch components. The scream was from the throw out bearing.
Re: Flywheel pic [Re: Chris142] #5356938 02/21/20 11:42 PM
G
GMBoy Offline
G
Don't cut corners now - you've come this far. You really need to replace that flywheel and the bearing in it. Flywheels are cheap and I would not even consider resurfacing.
Re: Flywheel pic [Re: Chris142] #5356940 02/21/20 11:46 PM
K
KneeGrinder Offline
K
LOL, there is some funny comments tonight! Brakes to clutches...to what oil for my genny.
I have done a number of clutches for people that I know that were low on funds, they just don't get the "You need to replace the throw out bearing when a new clutch is installed"
Why, its not broken...
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Flywheel pic [Re: GMBoy] #5356942 02/21/20 11:47 PM
K
KneeGrinder Offline
K
He is a professional mechanic, he can decide for himself. He won't make another post tomorrow about why his clutch is chattering.
Re: Flywheel pic [Re: KneeGrinder] #5357004 02/22/20 03:47 AM
G
GMBoy Offline
G
I am quite aware of that and respect him. I am also a pro for the record. You?
Re: Flywheel pic [Re: GMBoy] #5357027 02/22/20 05:40 AM
demarpaint Offline
+1
God Bless Our Troops
Re: Flywheel pic [Re: Driz] #5357041 02/22/20 06:29 AM
L
Lubener Offline
L
He never said the clutch and pressure plate were causing the noise, he always suspected the throwout bearing. Anyway, clutch kits come with all the things you mention, no need to itemize.
The "thinking" man's friend.
Re: Flywheel pic [Re: GMBoy] #5357131 02/22/20 09:22 AM
A
ARCOgraphite Offline
A
Master here .
If the flywheel isn't worn and it works well, Why would you replace it?
That is absolute non-sense. Youm ust be brainwashed by your Service Manager smile
Many replacement parts are suspect, and you can get yourself into un-suspected trouble going wil·ly-nil·ly with " new" parts.
NO chattering - just bad bearings.
Now PP and clutch are a consideration. But again if no abnormal wear with long service ahead.
Leave em.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Flywheel pic [Re: Chris142] #5357173 02/22/20 10:11 AM
Chris142 Offline OP
I'm cheap and if need be I can replace the flywheel in the future. The jeep flywheel can't be resurfaced. I don't want to knock the balance out with a chinese flywheel. I see no reason to replace it as it looks great. A few swipes with a rolloc disc and It should last another 180k.
