Discount oil in Oz.
A SCA 4th - 15th December 2019
Castrol GTX UltraClean 15W40 semi-synthetic
API SN/CF, ACEA A3/B3
half price $22 for 5L
Penrite HPR30 (20W-60) mineral
API SM/CF, ACEA A3/B3
KV100 = 23.5 cSt
TBN = 8.4
SA = 1.15%
Zinc = 1530 ppm
25% Off, $36 for 5L
Penrite 5W30 Full Synthetic
API SL (high ZDDP), ACEA A5/B5, Ford M2C913-D
KV100 = 9.6 cSt
TBN = 10.1
SA = 1.09%
Zinc = 1050 ppm
30% Off, $47.50 for 6L (six)
Nulon LongLife 5W30 Full Synthetic
ILSAC GF-5, Dexos1-Gen2
KV100 = 10.66 cSt
TBN = 8.5
SA = 0.9 %
30% Off, $51 for 6L (six)
Gulf Western Premium Gold 15W40 semi-synthetic
API SN-Plus, SN/CF
KV100 = 14.9 cSt
TBN = 6.5
SA = 1.2 %
25% Off, $22 for 5L
Hi Wemay,
Yes I agree, the GTX UltraClean is one of the best value oils in Australia right now.
The 15W40 viscosity is listed in my OM, so I have already used it one, and I have a few more GTX UC changes lined up to go.
I'm sure that Shell RGT is treating you well.
At SCA to 22 December
Penrite HPR 10 (10W50) and HPR 5 (5W40) full synthetics
40% Off for the big 6L jugs ($41)
Most other Penrite oils are 30% Off.
Shell Helix HX8 5W30 full synthetic (SN/CF & A3/B4) 30% Off ($47 for 5L)
Shell Helix Ultra, mid-SAPS ECT 5W30 (C3, BMW LL-04, MB 229.51) and full-SAPS 5W40 (A3/B4, BMW LL-01, MB 229.5) full synthetics are 25% Off ($55 & $45 respectively for 5L)
Valvoline Engine Armour semi-synthetics 10W30, 10W40, 15W40 are 30% Off ($34 for 5L)
At Repco to 22 December
Castrol GTX UltraClean 15W40 (SN/CF & A3/B3)
55% Off, $20 for 5L
Penrite HPR 5 (5W40) full synthetic
45% Off, $49 for 7L (seven)
Castrol Edge 5W30 A3/B4 full synthetic
45% Off, $75 for 10L
At Bunnings hardware (thanks for the heads-up GreatWhite7), some good everyday prices
Valvoline EngineArmour 15W40 semi-synthetic
API SN/CF, ACEA A3/B4, VW 505.00, MB 229.1
It's $20 for 5L
Valvoline DuraBlend 5W30 semi-synthetic
API SN-Plus & ILSAC GF-5.
It's $30 for 5L
Valvoline DuraBlend 10W30 semi-synthetic
API SN-Plus, SN/CF & ILSAC GF-5.
It's $35 for 5L
Valvoline DuraBlend 10W40 semi-synthetic
It's $30 for 5L
At Repco in Australia, 8th - 21st Jan 2020
Nulon Long Life 5W30 Full Synthetic
API SN, ILSAC GF-5, Dexos1-Gen2
KV100 = 10.66 cSt, TBN = 8.5 , SA = 0.9 %,
55% Off, $29 for 5L
Castrol Magnatec 10W40 semi-synthetic
It's $23 for 5L
API SM, ACEA A3/B3
KV100 = 25 cSt, TBN = 11.1, Zinc = 1530 ppm, SA = 1.47 %
It's $25 for 5L
Penrite Vantage Multi-Vehicle 5W30 Full Synthetic
API SN/CF, ACEA C3
KV100 = 12 cSt, TBN = 7.7, Zinc = 880 ppm, SA = 0.81%
Half Price, $55 for the 7L cube.
At SCAÂ 11 - 19 January
Penrite 10W40 Full Synthetic
API SN/CF, ACEA A3/B4, BMW LL-01, MB 229.5, JASO MA
KV100= 14.9 cSt, TBN = 10.2, Zinc = 1080 ppm, SA = 1.21 %
API SL (high ZDDP), ACEA A5/B5, Ford WSS- M2C913-D
KV100 = 9.6 cSt, TBN = 10.1, Zinc = 1050 ppm, SA = 1.09 %
Both 40% Off, $40 for the 6L jug
API SM, ACEA A3/B3
KV100 = 23.5 cSt, TBN = 8.4, Zinc = 1530 ppm, SA = 1.15 %
It's $25 for 5L
Correct specs above
API SM, ACEA A3/B3
It's $25 for 5L
Correct specs above
It goes in the diff that oil...
API SM, ACEA A3/B3
It's $25 for 5L
Correct specs above
Too much TBN
At SCA, 29 Jan to 9 Feb, 2020
API SN/CF, ACEA A3/B4, BMW LL-01, MB 229.5, Porsche A40
KV100 = 14.4 cSt, TBN = 10.4, Zinc = 1240 ppm, SA = 1.28%
40% Off, $39.30 for 5L
Penrite HPR 10 (10W50) full synthetic
API SN/CF, ACEA A3/B4, BMW LL-01, MB 229.3
KV100 = 18.6 cSt, TBN = 10.0, Zinc = 1080 ppm, SA = 1.21 %
40% Off, $36.30 for 5L
Shell Helix HX7 10W40 semi-synthetic
API SN/CF, ACEA A3/B4, MB 229.3
30% Off, $30 for 5L
Thank you for the detail, iam looking for thin oil on 20 weight that hopefully as robust as M1 EP. In here the Shell Helix Ultra still cost more than Pennzoil Ultra Platinum for the same 0w 20 and seems SHU slightly thicker even though with lower VI
Shell Helix Ultra is very good oil, I would always be happy to use it.
We don't get Pennzoil Platinum or Pennzoil Ultra Platinum in Australia.
Both the SHU and PP / PUP should be GTL based which is good. Slightly thicker SHU sounds fine to me. I like thicker.
We have a new Shell Helix Ultra 5W-30 in Australia
It's rated API SN-Plus, ACEA A3/B4, BMW LL-01, MB 229.5 / 226.5 and Renault RN 0700 / 0710.
It's made in Hong Kong
At SuperCheapAuto (SCA) to 1st March
Half Price, $35.50 for 5L
At AutoBarn to 8th March
Nulon 5W30 Full Synthetic
Dexos1-Gen2
60% Off, $25 for 5L (that's a very good price)
60% Off, $25 for 5L
Looking back at a year of posts, that is the best price I have ever seen for that oil. It's worth picking up at that price.
API SN, ILSAC GF-5, Chrysler MS-6395, Dexos1-Gen2
Good for the Holden drivers out there, and most Japanese & Jeep brands too. Shame about what is happening to the Holden brand in Australia.
At Repco, 4 to 17 March
Penrite Vantage 15W40 semi-synthetic and a Penrite Engine Flush treatment (valued at $20)
Oil is API SN/CF and ACEA A3/B4
TBN = 10.7, Zinc = 1050 ppm
It's $29 for the big 6L jug (Save $43 or $$63 inc engine free flush)
