I need to verify the accuracy of the tachometer on my boat engine. I know that there are cheap tachometers for small engines that use a wire to count spark impulses, but I also saw one that uses a laser. I presume you shine to at the flywheel or something like that? Has anyone used one and is it a better solution than a cheap hour meter/tach combo?
