Post your latest oil change
From reading this site HyperLube should help with wear where temperatures haven't activated the ZDDP yet. Plus these engines fuel dilute the oil and I'm hoping it helps, I'll run a UOA on the next change to see how it's doing. I'm curious as well so I figured it couldn't hurt.
2018 Ram 1500 5.7L 30k mi
5k on oil
Out: Formula Shell Conventional 5w20, Tough Guard 10060
In: Shield Choice Syn Blend 5w20, Mahle OC614
2012 Ford Fiesta 1.6L NA 84k
4.5k on oil
Out: 2qt Shaeffers 5w20/2qt Synpower 5w30, Champ
In: 4qts Amalie Syn Blend 5w20, Original Parts (CarID brand?) Filter.
07 Nissan versa
1.8(?) 4cyl
Out: unknown, FULL filter
In: napa 5/30, FULL filter
16 Chevy equinox
2.4 4cyl
Out: unknown, unknown filter
In: acdelco syn 5/30, napa gold filter
2014 Honda Accord Hybrid 2.0L LFA1
128,519 mi.; OCI 10,721 mi.; MM
Out: 3.9 qt. PP 0W-20; NAPA Gold 7356
In: 1.4 qt. PP 0W-20 & 2.5 qt. NAPA FS 0W-20; NAPA Platinum 47356
2008 F150 KR 5.4 3v
175,325 miles on truck
5,134 miles on oil
Out: Peak Synthetic 5w30, Purolator ONE
In: MileSyn blend 5w20, MC 820s
Noticed a leak around the filter adapter housing. I'll keep an eye on it an replace when the coolant is due in 20k, unless it gets worse. New gasket is 8 bucks.
2007 3500 Ram 6.7L Cummins @ 283,000 kms out; 15w40 T4 & Delco. In; 15w40 Duron & Fram Ultra.
2014 Escape 2L turbo, out 15W40 Duron, In; Duron SAE30 & Fram ultra 3600.
2018 3500 27,000 kms on truck, Chev 6.6L Duramax, out; 15W40 GM dealer?? & Delco filter. In; Havoline 15w40 CJ-4 & Hastings filter.
2007 Cadillac CTS
129,660 miles, 3k OCI
Out: 6qt Castrol Magnatec 5W30
In: 5qt Pennzoil Ultra Platinum 5W30 + 1qt Magnatec
Out/in: ACDelco PF2129G
2014 Ford F-150 STX 3.7L V-6
64,000 miles
Out: Unknown
Off: Motorcraft FL-500s
In: Chevron Havoline Pro DS 5W20 @ 6 Qt.
On: Motorcraft FL500s
09 Ford ranger
2.3 4 cyl
Out: probably napa 5/20, napa gold filter
In: napa 5/20, napa gold filter
94 Mazda b4000
4.0 v6
Out: napa 10/30, napa gold filter
In: napa 10/30, napa gold filter
95 Ford bronco
5.8 v8
Out: probably Castrol gtx 5/30, carquest red filter
In: Castrol gtx hm 5/30, napa gold filter
2019 F250 6.2L 8,841 miles
6,393 miles on oil
Out: Mobil 1 5w30 EP, Motocraft FL820S
In: Havoline Pro Ds 5w30 smart change, Wix 51372
Did some towing and a decent amount of idling since last oil change. Posted the oil filter c&p. No tears in media but glue was not adhered to neither end cap.
Applies to both cars in signature, done a week apart.
Out - Dealer Bulk ACDelco 5w30 D1G2 / PF64
In - Castrol Edge 5w30 (D1G2 SN+) / UPF64R
Done with the free dealer changes, sick of the non sense with them. Plus they aren't following the GM bulletin to move to the UPF64R.
2019 F150 5.0 15,136 miles on truck
7155 miles on oil
Out: not quite 7 quarts of Mobil 1 5w20 (9 quarts put in during last oil change)
Motorcraft FL500s
In: 9 quarts Rotella gas truck 5w20 motorcraft FL500s
Truck is definitely using oil. Definitely no external leaks but it was over 2 quarts low
Pic shows used oil in the containers I used to fill it. Just over 2 quarts low
[Linked Image]
[Linked Image]
[Linked Image]
I would be taking that into the dealer and getting them to begin monitoring oil consumption under Ford's TSB 19-2058.
2019 Toyota Tundra
24,500 on the truck
Out: Dealer bulk 0w20 | Toyota Filter
In: 8.5 quarts of Amsoil SS 0w20 | Toyota Filter
Out: 4.5qts Mobil1 0w-20 AFE and Fram Ultra Synthetic Filter. 8,504 Miles, 0qts Make-Up Oil Added MM 20% Oil Life Remaining
In: 4.5qts Castrol Edge 0w-20 and Fram Ultra Synthetic Filter
Besides using Pennzoil Platinum once, and one dealer change, this engine has only known Mobil1 AFE.
[Linked Image]
2017 Jeep Renegade 2.4, 28,430 miles
Out: Mobil 1 EP 0w20, with about 7200 miles on it. Fram XG10060.
In: Havoline Pro DS 0w20 (From the box!) and a new Fram XG10060.
This little engine is off to a good start! We'll probably do a UOA on the Pro DS. I'm very curious about it.
Next up: Rotella Gas Truck 0w20 for my 2018 Jeep JL 3.6.
2007 BMW X-5 3.0
36K miles (inherited from father)
OCI 4K miles 12 months ago
Out 5W40 synthetic by top notch euro shop for
$120 ya right but BMW Advantec is like $70/gallon
In 0W40 Castrol Edge Full PAO Synthetic/ OEM filter $65 for 10 Qts (3.1 Qts left over) and the OEM filter
