Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
Are harbor freight generators any good?
by NavyVet88 - 03/31/20 12:37 PM
Anyone on RD Forum .org? I've been banned
by FADEC - 03/31/20 11:48 AM
A picture of me in my youth! :-)
by SLO_Town - 03/31/20 11:18 AM
5w50 Motorcraft in 6.2L Raptor
by KlenFrappe379 - 03/31/20 11:16 AM
Fast 22 LR
by stockrex - 03/31/20 10:33 AM
Filter size info required please
by Richierich56 - 03/31/20 09:50 AM
Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
TreyT42, Abi, Transpections, burgM, SantiagoT
71067 Registered Users
109 registered members (53' Stude, atikovi, AC1DD, 2015_PSD, 4WD, Al, 9 invisible), 2,287 guests, and 23 spiders.
Topics303,517
Posts5,235,628
Members71,067
Which 15W40 for an Onan generator? #5356745 02/21/20 07:39 PM
A
atikovi Online Content OP
OP Online Content
A
Not sure which forum to post this, but I need to change the oil in an air cooled 2 cylinder gas engine Onan generator. The manual calls for 15W40 but all I see for that weight mentions diesel. Is that ok for this engine?
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5356748 02/21/20 07:41 PM
T
tundraotto Online Content
Online Content
T
Yes - just get a 15W-40 that is also API SN rated for gas engines if it worries you; delvac, delo etc....
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5356749 02/21/20 07:45 PM
A
OP Online Content
A
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5356750 02/21/20 07:46 PM
T
Online Content
T
Yes for sure. Note the SN on the API roundel on the back label.
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5356830 02/21/20 09:40 PM
V
Vern_in_IL Offline
V
Rotella
Re: Which 15W40 for an Onan generator? [Re: Vern_in_IL] #5356847 02/21/20 10:10 PM
T
Online Content
T
While I am sure Shell Rotella would work just fine - it is not certified or approved for gasoline engine use.
Re: Which 15W40 for an Onan generator? [Re: tundraotto] #5356911 02/21/20 11:13 PM
pkunk Offline
Been working fine in mine for over 20 years
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5357142 02/22/20 09:35 AM
A
ARCOgraphite Offline
A
Marine 4 stroke oils are MUCH better than Diesel and Fleet . If for Spring through Summer use.
Quicksiler Marine 4 Stroke
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Which 15W40 for an Onan generator? [Re: ARCOgraphite] #5357149 02/22/20 09:42 AM
CT8 Online Content
Online Content
At the commercial marine operations I have been to I never have see any using Mercury oil, just the mainstream HDEOs.
2015 F150 2.7
2018 F350 6.2
Re: Which 15W40 for an Onan generator? [Re: ARCOgraphite] #5357153 02/22/20 09:47 AM
4WD Online Confused
Online Confused
The local O’R’s parts house carries Mystik … pretty good numbers. Going to try some next change.
Re: Which 15W40 for an Onan generator? [Re: atikovi] #5358054 02/23/20 01:02 PM
B
bithebay87 Offline
B
Super Tech 15w40 will fit the bill fine.
I have ran many hours using delavc/ST 15w40.
I have use of/cf2 in sae 30/40, pceo sae30/40/50, 20w50 also with good results for what it matters.
Any oil will treat you well as long as you do regular oil changes and keep it full.
-Harvey
