Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
24 registered members (BeerCan, bismic1, Bookmaker, crainholio, Char Baby, anndel, 1 invisible), 531 guests, and 15 spiders.
Topics303,255
Posts5,232,693
Members71,032
drywall crack. how do i fix it? #5356602 02/21/20 03:55 PM
W
WhyMe Offline OP
W
had problems with this area as long as i have had my house. it lifts in the winter and cracks. not sure how to fix it. i know we got some savvy home diyers out there
[Linked Image from i.imgur.com]
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356618 02/21/20 04:21 PM
B
barryh Offline
B
I'm in a different country so detail construction methods will differ.
My house is drylined with taper edged plaster board with a thin layer of finish plaster on top. Where I have movement at the join between two boards the only thing that works is to remove the finish plaster an inch or so either side of the join and then apply a stronger modern fibre glass jointing tape. I then use a specific jointing compound intended for the purpose over the tape to re-finish.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356621 02/21/20 04:22 PM
P
PW01 Offline
P
If it keeps coming back you have to find a way to stop the movement.
2015 Ford Fusion Titanium, Ecoboost 2.0L turbo, Magnetic (metallic gray)
2015 Chevrolet Silverado 1500 Double Cab, 4x4, 4.6L V6, Black
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356658 02/21/20 05:26 PM
J
JTK Offline
J
Hard for me to tell from the pic, but is that an outside corner?
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: drywall crack. how do i fix it? [Re: JTK] #5356669 02/21/20 05:41 PM
W
WhyMe Offline OP
W
yes. there is a truss connection at that corner and a great room there. its truss movement that opens and closes with the seasons.
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356681 02/21/20 06:10 PM
Donald Offline
fiberglass tape to reinforce then mud.
you may want to scrape it down before applying the fiberglass tape.
2015 Ford F-250 w/Powerstroke
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356712 02/21/20 06:57 PM
J
JTK Offline
J
Gotcha.
I'd put a piece of outside corner molding, or some type of molding over it and call it day.
Like said, if you do a conventional tape and mud repair, it's just going to crack again with the movement.
Re: drywall crack. how do i fix it? [Re: JTK] #5356741 02/21/20 07:36 PM
spasm3 Offline
Gotcha.
+1
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356751 02/21/20 07:48 PM
M
maxdustington Offline
M
Everyone is wrong in this thread, that's a cornerbead: a thin metal angle that is nailed or screwed to outside corners to increase their durability. If you look at the part that has chipped off, the pattern stamped into it is unmistakable. Something could have whacked that and knocked the plaster off, but it doesn't look that distorted. It could have just popped the plaster off due to expansion or lack of adhesion.
You do not apply tape to beads, they stand proud of the board and you feather the plaster out to the surface of the drywall. To fix it, you need to remove the loose plaster, reapply new plaster and then paint it. The hard part will be replicating that stucco? finish.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: drywall crack. how do i fix it? [Re: JTK] #5356781 02/21/20 08:30 PM
W
WhyMe Offline OP
W
Gotcha.
probably what i will have to do. any repairs in the past just don't last . as soon as the corner lifts it cracks
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356825 02/21/20 09:32 PM
E
ecotourist Offline
E
It sounds like you have movement of the underlying structure. And unless you can stop that, no plaster repair is going to last.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: drywall crack. how do i fix it? [Re: WhyMe] #5356963 02/22/20 12:41 AM
P10crew Offline
Op that is a very good place for a Sheetrock expansion joint.
