Generac Power Washer Engine Oil Type.
by Andya - 04/05/20 08:49 AM
Barrs leak oil additive
by Micahmcmeen - 04/05/20 08:10 AM
Lawn mower oil question
by icemanrrc - 04/05/20 08:10 AM
Wait until you see who's driving...
by Shannow - 04/05/20 06:57 AM
Getting My Harley Back On The Road
by Silverado12 - 04/05/20 06:45 AM
Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
London, Dave66, Kurt_Kent_09, northestPM, dgvu89
71102 Registered Users
112 registered members (aba4430, 53' Stude, Andya, 64bawagon, Alaskanmont, 55hambone, 8 invisible), 1,824 guests, and 21 spiders.
Topics303,619
Posts5,238,476
Members71,102
1/4 to 1/2 quart underfilled dexron vi any problems? #5356579 02/21/20 03:10 PM
A
apollo18 Offline OP
A
Hey guys I have a 4l60 in my truck and I did a pan drop and also exchanged the fluid through the cooler lines so I got all 12 quarts exchanged. I ensured the pan gasket was seated good and I did each pan bolt to 10 foot lbs with torque wrench. I ensured the transmission cooling line was tight and fit properly. Before I drove the truck I made sure it was at the correct fluid level cold and then I drove 20-30 mins and shifted between all gears and checked the fluid again and had to add some probably about ¼ quart ish and maybe upto ½ quart maximum I added. I was on a pretty level surface and then i locked the dipstick in place and drove home. The next morning, I started the truck and everything was normal and I hit the road on the highway for 6 hours but I stopped a bunch of times and noticed nothing with the transmission. And then a couple days later, the temperature was noticeabley colder in my city and I started the truck and I noticed when I switched from park to reverse and reverse to drive , the rpm would rev up before going into gear. I thought it was just due to the cold weather or something and then i hit the road and after driving 100 km on the highway I pulled over to fuel up and also check the tranny fluid level incase I needed to add some more. I switched it into every gear and then did the check. The tranny was obviously hot and when I went to check the level was at the cold position. I checked again and ensured the level was at the cold position again which kinda freaked me out. I added probably about ¼ quart ish maybe a little bit more to get it to the hot section on the dip stick and drove the rest of the trip on the highway. Ever since I filled the fluid, the tranny has been normal. No rev ups when I shift and nothing else.
My question is did I do any damage? ¼ quart – ½ quart underfilled is barely any fluid but it seems like my tranny is very sensitive. Does this obviously mean I have a small leak somewhere? Or could there some other reason that I lost .25 quart of fluid over a couple days of driving? Before I did the fluid exchange and pan drop I checked the fluid color and it was red and not burned so I know it wasn’t too late for my tranny. It just seems super weird that I lost some fluid and that the fluid loss caused rev ups and weird tranny operation when cold.
Thanks!
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: apollo18] #5356597 02/21/20 03:44 PM
J
JMJNet Offline
J
FWIW, it happened to me the first time I replace ATF in my Camry.
When I started driving it the next morning, it was surging.
I thought I damage the trans, so I brought it to my mechanic.
All he did was top the fluid.
I drove the car for another > 100k miles before I sold it.
As far as damage, you will never know unless you open it up and measure everything with a caliper to see if there is any wear or do an oil analysis.
  • 2017 Toyota Sienna
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: apollo18] #5356604 02/21/20 03:57 PM
V
vw7674 Offline
V
Probably no damage to the trans.
The damage that can happen with low fill levels or failing bands & servos is
damage to the thrust bearing holding the crankshaft, the intermittent slamming
into gear can end up putting fine particles in suspension in the crankcase oil of all places.: (
You probably did none of that just 1/4 quart shy of full.
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: JMJNet] #5356606 02/21/20 03:59 PM
A
apollo18 Offline OP
A
thanks for the reply and thats true but i feel like .25 to .5 quart is nothing in like a 6 quart pan and 12 quart system. but i aint a tranny tech
