Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
23 registered members (Black_Thunder, 97prizm, Char Baby, AAIRCraig, bmod305, 4WD, 2 invisible), 564 guests, and 17 spiders.
Topics303,255
Posts5,232,680
Members71,032
1/4 to 1/2 quart underfilled dexron vi any problems? #5356579 02/21/20 03:10 PM
A
apollo18 Offline OP
A
Hey guys I have a 4l60 in my truck and I did a pan drop and also exchanged the fluid through the cooler lines so I got all 12 quarts exchanged. I ensured the pan gasket was seated good and I did each pan bolt to 10 foot lbs with torque wrench. I ensured the transmission cooling line was tight and fit properly. Before I drove the truck I made sure it was at the correct fluid level cold and then I drove 20-30 mins and shifted between all gears and checked the fluid again and had to add some probably about ¼ quart ish and maybe upto ½ quart maximum I added. I was on a pretty level surface and then i locked the dipstick in place and drove home. The next morning, I started the truck and everything was normal and I hit the road on the highway for 6 hours but I stopped a bunch of times and noticed nothing with the transmission. And then a couple days later, the temperature was noticeabley colder in my city and I started the truck and I noticed when I switched from park to reverse and reverse to drive , the rpm would rev up before going into gear. I thought it was just due to the cold weather or something and then i hit the road and after driving 100 km on the highway I pulled over to fuel up and also check the tranny fluid level incase I needed to add some more. I switched it into every gear and then did the check. The tranny was obviously hot and when I went to check the level was at the cold position. I checked again and ensured the level was at the cold position again which kinda freaked me out. I added probably about ¼ quart ish maybe a little bit more to get it to the hot section on the dip stick and drove the rest of the trip on the highway. Ever since I filled the fluid, the tranny has been normal. No rev ups when I shift and nothing else.
My question is did I do any damage? ¼ quart – ½ quart underfilled is barely any fluid but it seems like my tranny is very sensitive. Does this obviously mean I have a small leak somewhere? Or could there some other reason that I lost .25 quart of fluid over a couple days of driving? Before I did the fluid exchange and pan drop I checked the fluid color and it was red and not burned so I know it wasn’t too late for my tranny. It just seems super weird that I lost some fluid and that the fluid loss caused rev ups and weird tranny operation when cold.
Thanks!
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: apollo18] #5356597 02/21/20 03:44 PM
J
JMJNet Offline
J
FWIW, it happened to me the first time I replace ATF in my Camry.
When I started driving it the next morning, it was surging.
I thought I damage the trans, so I brought it to my mechanic.
All he did was top the fluid.
I drove the car for another > 100k miles before I sold it.
As far as damage, you will never know unless you open it up and measure everything with a caliper to see if there is any wear or do an oil analysis.
  • 2017 Toyota Sienna
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: apollo18] #5356604 02/21/20 03:57 PM
V
vw7674 Offline
V
Probably no damage to the trans.
The damage that can happen with low fill levels or failing bands & servos is
damage to the thrust bearing holding the crankshaft, the intermittent slamming
into gear can end up putting fine particles in suspension in the crankcase oil of all places.: (
You probably did none of that just 1/4 quart shy of full.
Re: 1/4 to 1/2 quart underfilled dexron vi any problems? [Re: JMJNet] #5356606 02/21/20 03:59 PM
A
apollo18 Offline OP
A
thanks for the reply and thats true but i feel like .25 to .5 quart is nothing in like a 6 quart pan and 12 quart system. but i aint a tranny tech
