RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
03 4.7 Durango - AC System
by joshuawesl - 07/06/20 10:40 AM
19 4Runner M1 0w40 11k oci
by Doublehaul - 07/06/20 10:11 AM
Fiberglass Garage Door
by Al - 07/06/20 09:57 AM
EcoGard x4615 can l "use it with confidence"?
by Joe1 - 07/06/20 09:43 AM
Bearing issues on rebuilt engine
by Mullady76 - 07/06/20 08:57 AM
Portable tire inflator
by RoyClark - 07/06/20 08:52 AM
Air filter maintenance
by nomas - 07/06/20 08:41 AM
Great Deals At NAPA
by Mathew_Boss - 07/06/20 08:40 AM
Repaint older tractor
by redhat - 07/06/20 08:34 AM
Another Civic Down
by ctechbob - 07/06/20 01:25 AM
Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
AnotherPerson, biomatrix, CDN, KeyzzDzz, carms
71858 Registered Users
102 registered members (4WD, aquariuscsm, 5AcresAndAFool, Alfred_B, ABN_CBT_ENGR, aaronc7, 9 invisible), 2,134 guests, and 24 spiders.
Topics307,483
Posts5,311,967
Members71,858
Difference Between Drivers Side and Passenger Side Caliper #5356009 02/20/20 09:46 PM
F
Fitz98 Offline OP
F
I went to AZ to buy a new driver side caliper today.
No reason to think there was any issue and everything installed fine, until I went to set the brake pads and noticed the driver side caliper installed differently than the passenger side. One side I had to install the top first and push in the bottom and the other side I had to install in the top first and then push in the bottom.
That got me thinking to compare.
The bleeder screw is on the top on the passenger side, but on the bottom of the drivers side.
My original driver side has the bleeder on the top as well.
The part number on the box matches the correct image that matches my original caliper, but is different than the one that was in the box.
Seems like someone did me the favor of returning a passenger side caliper in a drivers side box, which would explain all the grease on the box itself when I picked it up.
Shame on me for not checking before installing.
I imagine the bleeder should be on the top. Does that sound right?
[Linked Image]
[Linked Image]
AutoZone Driver Side Caliper
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356012 02/20/20 09:49 PM
bdcardinal Online Content
Online Content
The bleeder has to be on top in order for the brakes to be bled. That looks like a mis-box.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356014 02/20/20 09:54 PM
F
Fitz98 Offline OP
F
I figured as much. Lesson learned I guess...always check before installing. The differences are very subtle, but important.
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356018 02/20/20 10:03 PM
DuckRyder Offline
Doesn’t it say “RH” right on it?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356032 02/20/20 10:21 PM
Nick1994 Online Content
Online Content
Very important that the bleeder is on the top.
My brother and I reinstalled the front axle in his Jeep after a rebuild and could not for the life of us get the brakes to gain pressure whatsoever until we realized the calipers were swapped.
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356053 02/20/20 10:39 PM
H
hallstevenson Online Content
Online Content
H
Think of the bleeder screw as an air vent as well. You bleed fluid and air out of them on occasion.
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356085 02/20/20 11:14 PM
B
bobbobtar Offline
B
I found out the hard way installed one with the bleeder on the bottom worked almost an hour trying to bleed the system neighbor stops by and looks at it and say's the bleeder should be on top. Thanks, parts store.
2020 Chevy Silverado LT 1500 3.0L diesel
2018 John Deere 2032R
2019 F3 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356287 02/21/20 09:12 AM
M
MarkM66 Offline
M
In a pinch, you could always bleed the caliper off the bracket with the bleeder pointed up, then install into the bracket.
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: MarkM66] #5356467 02/21/20 12:20 PM
Online Content
That would work. Just have to make sure something is between the pads to keep the pistons from compressing.
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5356488 02/21/20 12:46 PM
M
Miller88 Offline
M
The problem I always have is the parts store bleeders are always so tight. More than once I have snapped the bleeder off trying to bleed the brakes. Now I always make sure I have a wrench with me at the store and loosen up the bleeder before I start.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Miller88] #5356636 02/21/20 04:41 PM
Online Content
I have bleeder screw wrenches which are basically really long 6 point wrenches in the common bleeder sizes. You can also use a 6 point socket and a long 1/4" ratchet.
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: Fitz98] #5357566 02/22/20 08:03 PM
another Todd Offline
The calipers on my car dolly has bleeders on the top and bottom so they are interchangeable left and right. I don't know why more manufacturers don't do that if they are otherwise interchangeable, they would cut in half the part numbers for that application.
2019 Jeep Cherokee Trailhawk V6
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
Re: Difference Between Drivers Side and Passenger Side Caliper [Re: another Todd] #5357611 02/22/20 09:12 PM
slacktide_bitog Offline
approved
