Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
36 registered members (1foxracing, 4WD, Char Baby, Bailes1992, BlueOvalFitter, 6 invisible), 659 guests, and 19 spiders.
Topics303,303
Posts5,233,536
Members71,038
Best beginner press? #5356391 02/21/20 11:20 AM
M
MVFarms Offline OP
M
I've played around and had success with Lee Loaders and am ready to make the step up to a press setup (need to full length resize some stuff). Mostly rifle, some pistol . . . hobby level stuff.
The RCBS Rock Chucker Supreme looks like the best thing going, but I'm open to any suggestions . . . and wondering if I'll regret not going with a turret (of which I like the New-ish Lyman).
I usually 'invest' in the middle of the road as far as equipment goes. Better than I need, but always good enough . . .
Re: Best beginner press? [Re: MVFarms] #5356407 02/21/20 11:35 AM
JohnnyJohnson Offline
I got my Rock Chucker Supreme in 1973 its turned out 10's of thousands of rounds and just keeps doing so. Look around at gun shows/gun forums and you can pick up some quality equipment for a very reasonable. My experience tells me the turret equipment unless you go to a higher level like the Dillion don't waste your money.
2004 Corolla 139577
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Best beginner press? [Re: MVFarms] #5356416 02/21/20 11:43 AM
W
WyrTwister Offline
W
In my opinion , the Lee Cast Iron Turret Press is the best value for the money .
https://leeprecision.com/4-hole-classic-turret-press.html
If you go for a single stage press , I suggest this one .
https://leeprecision.com/classic-cast-press.html
How ever , the Challenger , is not bad . Although , I personally see the breech lock system as more a solution in search of a problem . My Challenger press is an older one that does not have / use the breech lock system .
https://leeprecision.com/breech-lock-challenger-press.html
Wyr
God bless
Re: Best beginner press? [Re: MVFarms] #5356434 02/21/20 11:54 AM
B
BISCUT Offline
B
I've had Hornady single stage press for about 15 years and a Hornady progressive press for over 10 years. Very happy with both of them. The single stage is my favorite; love how it slows you down and allows a high level of consistency.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(44k)
2017 Sub OB M1 5-30 EP FRAM Ultra(74k)
Re: Best beginner press? [Re: MVFarms] #5356480 02/21/20 12:33 PM
J
jjjxlr8 Offline
J
RCBS Rock Chucker is very nice. Based on your "middle of the road" comment that would be your best choice. I use a lot of RCBS reloading equipment these days and I really like it.
I started with the extremely manual Lee Handloader kits in the beginning and then bought the Lee Anniversary kit, along with a better RCBS hand priming tool, and have been using the Lee Challenger press for 19 years, now. It works. My freind has the RCBS Rock Chucker and it is a step up from the Lee Challenger.
I think you are smart to stay away from the turret style presses, especially as a beginner. Afterall, with ammo prices as low as they have been in the last 10+ years, it's tough to reload some calibers for much less than you can buy factory ammo. You can make *better* ammo than the factory stuff, though, but you don't typically do that on turret presses. For accuracy, it's about quality, not quantity, and single stage presses are better for that.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: Best beginner press? [Re: MVFarms] #5356540 02/21/20 01:57 PM
M
MVFarms Offline OP
M
Thanks for all the input . . . much appreciated.
Re: Best beginner press? [Re: MVFarms] #5356544 02/21/20 02:03 PM
U
Ursatdx Offline
U
2nd the Lee progressive.
223/556
.40
357
38
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Best beginner press? [Re: MVFarms] #5356549 02/21/20 02:18 PM
W
WhyMe Offline
W
depends on how much ammo you load a year . i go through 10k plus and a single stage would be torture. if you want all around can do most stuff a dllion 550 will do both rifle and pistol . you can use it as both a single and progessive.
Re: Best beginner press? [Re: MVFarms] #5356587 02/21/20 03:29 PM
CT8 Offline
With out doubt the best press to learn on is a Dillon 550. I started loading in 1976 with a Rock Chucker press a friend left at my house for me to use. 1991 I bought a Dillion 550 and I am still happy.. i have taught 5 people to reload on the Dillon 550 and they all purchased their own Dillon 550s and are very happy. I have loaded on the Dillon 550 38 special and 357 mag , 9mm, 40S&W, 45acp, 223, 308, 30. 06, 300 Weatherby mag and 338 Lapua
2015 F150 2.7
2018 F350 6.2
Re: Best beginner press? [Re: CT8] #5356624 02/21/20 04:25 PM
2015_PSD Offline
I would second that and add if you wanted to start slowly and build up, you could buy the BL550 which is in essence a single stage press like a Rock Chucker. The difference is the BL500 can be converted to an RL550 and become a progressive press WITHOUT losing the investment like you would with nearly any other single stage press. I have 2 XL650's, 1 RL550C, and an SL900 from Dillon and their total "no-BS" warranty is the best on the market. I sold an RL550B a few years ago that had reloaded no less than 100K rounds and it was still going strong.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Hastings]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Best beginner press? [Re: MVFarms] #5356657 02/21/20 05:23 PM
claluja Online Content
Online Content
For precision rifle, consider Forster co-ax (if you're interested in precision, as opposed to mass reloading).
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: Best beginner press? [Re: MVFarms] #5356714 02/21/20 06:59 PM
O
OLEJOE Offline
O
I’ve got the Lee Classic Cast and like how it confines the spent primers. It will do it all with ease. Even 50 cal. Case forming is a breeze. And the three point mounting system.
Jack of All Trades. Master of some.
Re: Best beginner press? [Re: MVFarms] #5356763 02/21/20 08:04 PM
H
hatt Offline
H
The Rockchucker kit is pretty decent. If you aren't planning on shooting a ton the single stage presses are fine. Even if you do decide to go progressive later having a single stage around is nice.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Best beginner press? [Re: MVFarms] #5356822 02/21/20 09:29 PM
B
bulwnkl Offline
B
A RockChucker was my first press. Big and monstrously heavy. Worked fine. Sold it long ago in college. Used a Lee hand press thereafter (still have that one).
Had a Lee Challenger. Not bad.
Have a Lee Classic Cast. Excellent press, and a far better value than any of the other companies' wares.
I'd like to try a Forster Co-Ax one day.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Best beginner press? [Re: MVFarms] #5356823 02/21/20 09:30 PM
Driz Offline
Snoop around yard sales and Craig’s List there tends to be a lot of really nice reloading gear. My buddy just landed a whole load of first class gear someone was selling off a deceased relatives estate. He said you see a lot of reloading gear like that if you like wandering around some.
I’m still using the same Rock chucker I bought in1982. It does the deed . For dies I have a mix of Lee and RCBS. They all do the deed. Lee are a lot cheaper while RCBS are nicer, pick your poison.
