Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
69 registered members (2009Edge, 94astro, 4WD, 53' Stude, Amkeer, 8 invisible), 1,078 guests, and 22 spiders.
Topics303,303
Posts5,233,559
Members71,038
...musical 'flat-tappet' oils #5356354 02/21/20 10:44 AM
M
Mad_Max_Sam Offline OP
M
hey peeps - so I've spent several hours scanning the lab results from 540rat and I'd like some confirmation about what the 90,000 psi 'magic number' really means. Is that the 'requirement' for flat-tappet cam engines? I own several 'flat-tappet' hot rods, including my mighty Cummins 5.9 (solid cam), and so I've got a couple questions...
I talked with the tech folks at Shell and they claim their Rotella T4, 5 and 6 all have the 'flat-tappet' package, so I've been running Shell Rotella T4 10W30 in my hot rods, but alas the info from 540rat does not specifically list the 10W30, so I don't know how it rates.
It does list the Shell Rotella 5W30 Gas Truck oil with a nice rating of ~96,000 psi, which I am now leaning towards for my hot rods.
It also lists both the new and old Rotella 15W40 diesel oils, both of which rate in the low 70,000 range - not at/above the 90,000 number...which was very disheartening considering it's what I've been running in my solid cam Cummins.
So, looking at the results there seem to be three local off-the-shelf contenders of 'normal' oil that I'm leaning towards for my hot rods, all of which are above the 90,000 magic number:
- Quaker State Ultimate Durability 5W30, ~133,000 psi rating
- NAPA 5W30, ~105,000 psi rating
- Shell Rotella 5W30 Gas Truck oil, ~96,000 psi rating
All of these are full synthetic, and all of them list "Dexos" on the bottle - wonder what that means...
I also have a fresh 440 that needs to be broken in, and I am VERY curious about the Lucas Break In Oil I bought for the initial break-in - it only rates at ~49,000 psi - not even worth saying how low it rates...and this is a 'break-in' oil?
Meanwhile...I am still trying to determine what to run in my Cummins - none of the local 'off-the-shelf' contenders are rated above 90,000 psi; not Rotella, not Delo, so I may have to resort to the expensive mail order oils like Amsoil...and maybe they are worth it...?
Here is the link to the lab data from 540rat - https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Would appreciate any thoughts/recommendations.
Cheers
- Sam
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356381 02/21/20 11:04 AM
P
PontiacHO Offline
P
I’m sure there will be a lot of preferences and technical info coming your way. I can only speak from experience. My 1967 396 was broken in and ultimately ran with Valvoline VR1 10w40 (Not street legal) conventional oil. I assembled this engine with a flat tappet cam for street performance with .520 lift - 224 @ .050. Not terribly hard on valvetrain components but stronger valve springs than stock none the less. Used GM EOS oil supplement in the oil for initial camshaft break in then dumped that oil & filter and went back again with fresh Valvoline VR1. Never a problem. Ran the dog sh*t out of it....
Go with real world experience rather a blogger’s opinion.
I imagine most over the road truckers’ tractors are using Rotella, Delvac, Valvoline Premium Blue or Delo. They are very attentive to longevity. It’s their livelihood.
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356389 02/21/20 11:17 AM
O
OVERKILL Offline
O
The 540 Rat blog has been covered extensively on here before in past threads. I know the search function isn't great, so the best way to find these discussions is to use google:
Seach BITOG via google for 540 Rat
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356390 02/21/20 11:19 AM
K
kschachn Offline
K
There are many long and detailed threads on here about Rat, please do what Overkill posted and read them first.
Many, many threads. Long ones. Many of them.
The short answer to "I am still trying to determine what to run in my Cummins" is that you use an oil, any oil, that meets the specification or approval your engine requires and has a winter rating appropriate for your expected starting conditions. You find this specification or approval in the owner's manual and once you know that information, Walmart likely has several excellent choices.
Somehow though I think you might already know all of this.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356410 02/21/20 11:38 AM
P
PontiacHO Offline
P
Or go with is being used in the real world that is working.
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356412 02/21/20 11:40 AM
M
M
I appreciate the fast replies. I had done the recommended searching and came up with more hits than I could count. I am using the Rotella T4 because Shell says it has the correct stuff in it for flat-tappet cams, including a solid lifter Cummins, and is also what the bottle states, so I thought I was (might still be) fine. Just after reading the lab results from 540rat...which might be crap(?)...I was just wondering about the 90,000 psi rating, and the fact that the Rotella 15W40 rates under that.
And even though the Lucas break-in oil clearly states it's specifically for flat-tappet' engines the very low psi rating really got my attention...
Is there any validity to the 90,000 psi rating...which I presume is directly related to proper flat-tappet use? Maybe not?
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356419 02/21/20 11:45 AM
RDY4WAR Offline
Do yourself a favor. Take that 540rat blog, close the tab, and never open it again. There is absolutely nothing useful about that pseudo-science.
The flat tappet lifter to lobe interface operates in boundary lubrication. Hydrodynamic oil film is already out the window. What you need is a tribofilm formed from activation of anti-wear additives (ZDDP in particular) to minimize abrasive wear of the cam lobes and lifters as much as possible. The amount of anti-wear (ZDDP) necessary is largely dependent on acceleration or "jerk" in the valvetrain, the weight of the valvetrain, valve spring pressure, and rpm. Higher lift cams with more aggressive lobes using high spring rates and turning more rpm need more ZDDP to cushion the blow.
Your hot rods... do they use stock cams or aftermarket? Are they driven hard and frequently or casual cruisers that never see more than 3k rpm? What engines specifically?
The Cummins I'd just put Rotella T6 5w-40 in and not worry about it.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356420 02/21/20 11:45 AM
K
kschachn Offline
K
None, zero. When that data is properly analyzed and presented no oil tests better than any other oil. They all test the same. Besides that, the test he performs is not applicable to motor oils. There is absolutely nothing "directly related" to anything out of that website. All the work that... guy has done isn't even worth the bandwidth it consumes.
1994 BMW 530i, 252K
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356421 02/21/20 11:47 AM
P
PontiacHO Offline
P
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356432 02/21/20 11:53 AM
RDY4WAR Offline
Nope. It's a figment of 540rat's imagination. It has absolutely no meaning whatsoever. His "testing" is no more relevant to engine oils than testing which color of Prius can tow easier.
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356435 02/21/20 11:55 AM
P
PontiacHO Offline
P
Or a person could chose to go with is being used in the real world that is working
Re: ...musical 'flat-tappet' oils [Re: PontiacHO] #5356436 02/21/20 11:57 AM
M
M
with all respect, I would be delighted to continue to use what I have been using in the real world that has been working - I am simply curious about what seems to be a significant amount of research that was done specifically about oils, and it sounds like while the research is extensive it may not have a direct correlation to the real world, and that is based on what 'info from someone on a thread' says, so again with all respect I take pretty much everything with a couple grains of sugar (salt is no fun...unless there's tequila involved smile ).
I would be more than delighted to keep using the oil(s) I have been using, which were chosen based on the manufactures specs. I also don't want to be foolish just because a company says 'yah it's got all that stuff - now how many would you like to buy from us?'.
Granted - I've never blown out a cam, but I also know that with the change to roller cams oils have also changed, so I'm just trying to keep up with the times...sift through the nonsense...and keep the proper oil in the pan(s).
- Sam
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356444 02/21/20 12:01 PM
K
kschachn Offline
K
The proper way to sift through the nonsense is to know what specification or approval your owner’s manual requires for your engine and then pick an oil that carries that specification or approval. There is no “test” on the Internet that judges an oil for higher quality, and there’s no need to ask the manufacturer or spend hours reading through truly irrelevant data on some site to try and divine an outcome.
1994 BMW 530i, 252K
Re: ...musical 'flat-tappet' oils [Re: Mad_Max_Sam] #5356447 02/21/20 12:03 PM
P
PontiacHO Offline
P
You have a sound plan. Go with that with confidence.
Re: ...musical 'flat-tappet' oils [Re: RDY4WAR] #5356457 02/21/20 12:10 PM
demarpaint Offline
Good advice!
God Bless Our Troops
