Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
MattV922, Bruce_S, Rwogs, MechEnDawg, jimbacot
71538 Registered Users
99 registered members (01rangerxl, amh, Alfred_B, Aredeeem, alchargo, 14 invisible), 2,363 guests, and 71 spiders.
Topics305,935
Posts5,283,110
Members71,538
1991 Land Cruiser FJ80 #5356073 02/20/20 10:57 PM
CCI Offline OP
Owner had rear tires worn down, front tires new, we're seeing 8 inches in 10 rotations LR and 6 inches in 10 rotations RR difference from front tires. Not good, seems to have done some driveline damage.
Put two new tires on the back same brand and size as new fronts, seems to be a lot better but center diff whines under load, front diff chatters and bumps a little turning in reverse.
Factory recommended lube is just regular old gear oil, GL-5 SAE 90.
Not looking for a miracle in a bottle, but is there any lubricant that will work better in these differentials?
Re: 1991 Land Cruiser FJ80 [Re: CCI] #5356095 02/20/20 11:40 PM
A
andyd Offline
A
Open diffs? Then regular ol' 80w90 is good.Different size tires are bad for diffs. maybe go thicker on TC to see if it quiets down. If the TC has a chain ,can you check it for slack? On my old Wags any deflection over 3/4" was a bad sign. grin2
Thick oil is better grin2
Re: 1991 Land Cruiser FJ80 [Re: andyd] #5356740 02/21/20 07:32 PM
CCI Offline OP
It's old enough that anything could have happened over the past 29 years but I think the front and rear diff are probably stock, I will check next time it's on the lift. Likely yes, open front and rear, this one has the electric (3 relays) locking center diff.
4 speed automatic transmission seems to be in pretty good shape. Shifts hard into 4th gear unless you really have your foot in it, I'm wondering if it's just a little goo around the spring behind the ball, this one has been sitting a long time.
What doesTC stand for?
Re: 1991 Land Cruiser FJ80 [Re: CCI] #5357772 02/23/20 03:00 AM
R
RoyFJ Offline
R
I use Redline 75W-110 on my diffs for the FJ Cruiser, works out real good.
