Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
96 registered members (4WD, 07titan, 007, 1978elcamino, 10ecfarmer, 2004tdigls, 9 invisible), 1,606 guests, and 16 spiders.
Topics303,499
Posts5,235,284
Members71,063
Page 2 of 3 1 2 3
Re: 1 time wax car after more than 10 years opinion [Re: Donald] #5350566 02/15/20 09:00 AM
A
alarmguy Offline
A
Originally Posted by Donald
Originally Posted by alarmguy
Nu Finish and your good to go
+1 thorough washing. Then Nu Finish. Careful not to get it on any vinyl.
good point on the vinyl.
To this day, it still amazes me, the Nu Finish would be perfect for the OP purpose but whatever :o)
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5350598 02/15/20 09:31 AM
A
Amkeer Offline
A
I used Nu Finish in the 80's and 90's. I don't use it anymore since there are way better alternatives out there. Your plan sounds solid. I use Optimum Products, Chemical Guys, Adams and Mcguires. Since I am in Florida the sun will cook the finishes. I use a spray wax on a microfiber towel on each wash or every other wash. It takes about 15 minutes to do the whole vehicle. I use Optimum Spray Wax and Optimum No Rinse to clean. I keep my vehicles for a long time so the product needs to be good.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 101000
2008 Toyota Tundra D Cab 5.7 M1 5-20 98000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 214000 miles
2014.5 Toyota Camry SE 2.5 M1 0-20 72000
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5351753 02/16/20 01:49 PM
spasm3 Offline
Thats one reason i like Klasse. You can use it on the vinyl and plastic as long as they are clean. It won't be white on them. Sometimes i have to buff it off the paint again the next day. But the protection is great.
I even use it on the front and rear windshield and side windows.
EDIT: I should have specified KLasse Sealant. The SILVER bottle. The RED bottle is a cleaner also, and WILL be white on the plastic and trim.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5351834 02/16/20 03:45 PM
danez_yoda Offline
Where is that "This thread is worthless without PICS" meme??? LOL.
You have probably bought too much stuff for what you are trying to solve. Honda paint is not very hard to correct so I would not go after it with harsh abrasives.
If you have clear coat failure,
[Linked Image]
nothing can fix that except sanding off the failed parts and spraying clear over that body panel. I just did this on my 07 Tacoma.
If you dont have clearcoat failure, I would just wash really well, claybar, meguiars ultimate polish with a dual action polisher (porter cable, HF Bauer or equivalent) then any wax you want. Meguiars ultimate wax is a good one readily available at walmart.
Re: 1 time wax car after more than 10 years opinion [Re: danez_yoda] #5352274 02/16/20 11:59 PM
T
Toh1 Offline OP
T
There is little clear coat that is remove but that is no bigger than small pizza size but still the paint is there just clear coat is gone. I agree I buy it too much stuff but all was less than $15 and retail for more than $50.
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5352352 02/17/20 06:50 AM
A
Amkeer Offline
A
This is why I like using the Optimum No Rinse and spray wax. Your less likely to remove clear coat over a period of time. This is extremely important in Florida.
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5353121 02/17/20 09:07 PM
danez_yoda Offline
If you are really wanting to fix it. this is the clearcoat to use.
https://www.amazon.com/U-S-Chemical-Plastics-4333062164-Spraymax/dp/B0043B7UQY
be careful as this is professional quality stuff. paint boot rated resporator is Mandatory or you can get nerve damage from breathing this stuff. Also goggles for your eyes.
I did mine in my double car garage so the overspray would not get on my OCD neighbors truck, i sanded down with 1000 grit wet. sandpaper until the edges were feathered in. you have to be careful not to cut through the color coat where the clear is fully gone. block sanding will help here but still be careful.
wash with water and a spongue the wipe down with alcohol. do an entire section or you will have blending lines to deal with. it can be done but requires a practiced hand.
therr are many youtube videos on how to do it.
Re: 1 time wax car after more than 10 years opinion [Re: Amkeer] #5355372 02/20/20 11:49 AM
grampi Offline
Yeah, I can't believe people still recommend Nufinish...there are MANY better products available today...might as well recommend the old Simonize from the 1950s...
Re: 1 time wax car after more than 10 years opinion [Re: grampi] #5355963 02/20/20 08:50 PM
A
AC1DD Offline
A
Consumer Reports which does test for durability finds that Nu finish still does a good job in this respect.
Re: 1 time wax car after more than 10 years opinion [Re: grampi] #5356001 02/20/20 09:33 PM
CKN Offline
Define better? Yes-there are products that don't do the "black plastic/rubber thing"-but NuFinish has a durability component that is right up there among the best and newest.
There are plenty of youtube videos that illustrate this.
Re: 1 time wax car after more than 10 years opinion [Re: CKN] #5356226 02/21/20 07:51 AM
grampi Offline
Okay, just for the sake of argument let's say that Nufinish lasts as long as any of the other products (which it doesn't, but let's say it does). Why wouldn't a person use something else just because Nufinish stains trim? That alone is enough for me not to recommend Nufinish...
Re: 1 time wax car after more than 10 years opinion [Re: grampi] #5356546 02/21/20 02:10 PM
L
Leo99 Offline
L
What do you recommend instead of nu finish?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5357048 02/22/20 06:49 AM
A
Amkeer Offline
A
Like I said there is way better products out there, I wouldn't even consider using NuFinish. Klasse All In One is good all around sealant and you can top it with Klasse SG if you wanted. It won't damage your rubber and black trims like NuFinish will. You can also check out products from Maguires. I use Optimum products too. I primarily use a spray wax like Optimum Spray Wax as it is applied after every wash. I use it on my boat too. The key is keeping the finish free of contaminants. If you do you can just apply the spray wax. You can also start with a ceramic type coating then periodically apply a spray wax to it. My Tundra still looks brand new after 12 years in the Florida sun using these methods.
Re: 1 time wax car after more than 10 years opinion [Re: Toh1] #5357850 02/23/20 08:18 AM
grampi Offline
As has been recommended every time this subject comes up, Collinite, Zaino, Klasse, and Duragloss all make better products, as well as many of the new spray-on ceramics, and even some of the non-ceramic sprays...none of which will stain trim...
Re: 1 time wax car after more than 10 years opinion [Re: Donald] #5361110 02/26/20 11:08 PM
T
Toh1 Offline OP
T
I buy nufinish now thinging or using Nufinish (sealant) then griot garage wax I buy on clearance for$3.25 ? Is this is good idea ?
Page 2 of 3 1 2 3
