Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
110 registered members (53' Stude, 762fermeandyou, 07titan, 2015_PSD, AnthemBassMan, acmesupply, 11 invisible), 2,392 guests, and 20 spiders.
Topics303,644
Posts5,238,990
Members71,105
2008 CR-V AT Question #5355760 02/20/20 05:18 PM
G
Gebo Offline OP
G
I noticed while doing some work on a 2008 Honda CR-V that in high hear in lowest steady RPM's, there was a slight rumble. Around 1800 RPM in highest gear on level highway. I did a little searching and it appears this is a somewhat common problem.
I did 2 drop and fills with Honda DW1 and it still does it. Any comments?
Last fluid change was 30K ago at Honda Dealership.
The owner has never noticed it.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2008 CR-V AT Question [Re: Gebo] #5355765 02/20/20 05:21 PM
W
WhyMe Offline
W
i had that problem in my 2011. i thought it was the tires and even after new tires it was still there. thought it was the wheel bearing and i changed that also. No change. could never figure it out. also, check for water in the spare tire area
Re: 2008 CR-V AT Question [Re: Gebo] #5355771 02/20/20 05:25 PM
G
Gebo Offline OP
G
WhyMe, I did many test runs over the week I had it. It only did it at 1800-2000 RPM's in high gear. As soon as it shifted down, rumble gone.
It has to be in the Transmission, right?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: 2008 CR-V AT Question [Re: Gebo] #5355778 02/20/20 05:30 PM
J
jayjr1105 Offline
J
I think it's torque converter and it's very common with those CR-V's. I don't know that it's actually hurting anything and I think most people live with it.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: 2008 CR-V AT Question [Re: Gebo] #5355780 02/20/20 05:33 PM
W
WhyMe Offline
W
yep i only noticed it on the highway driving at about 55 to 70. it was a feeling like the tire was going up and down. i can't say its in the trans though. i did not want to spend money to find out so i lived with it .
Re: 2008 CR-V AT Question [Re: jayjr1105] #5355793 02/20/20 05:47 PM
G
Gebo Offline OP
G
You are confirming what I thought. I’m gonna email agco and see what Lewis says.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
