VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
Westinghouse iGen 4500 Generator
by SailSkiDrive - 04/05/20 09:16 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
89 registered members (53' Stude, 4WD, ArrestMeRedZ, ammolab, 77GrandPrix, 2oldtommy, 8 invisible), 2,797 guests, and 17 spiders.
Topics303,641
Posts5,238,889
Members71,105
2019 Sienna #5355733 02/20/20 05:01 PM
s2krunner Offline OP
Hello all,
Im looking to do first oil change on Sienna. It is recommended 0w20 or 5w20 and total needs 5.8 qts.
I picked up Castrol Magnatec 0w20 5 qts, and i still do have new 5 qts Mobil 5000 5w30 in garage.
Should i mix them or should i pick up another 0w20 5qts?
Im pretty sure 99% will say use them haha
Thanks
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Re: 2019 Sienna [Re: s2krunner] #5355751 02/20/20 05:12 PM
skyactiv Offline
The next most important procedure after doing a proper oil change is documenting it. Write the VIN#, date and mileage on the receipts and store in a safe, cool dry space. Also consider updating the maintenance info to Carfax which you can.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 2019 Sienna [Re: s2krunner] #5355752 02/20/20 05:13 PM
P
Pete Offline
P
Are you sure of the capacity? You need 5.8 quarts (I have an '18).
I'd buy a quart of each of those oils and use them sequentially.
Re: 2019 Sienna [Re: Pete] #5355757 02/20/20 05:16 PM
You are right. Some what online resource says that amount. But i just looked manual and 5.8 is correct
Re: 2019 Sienna [Re: s2krunner] #5355764 02/20/20 05:19 PM
Currently all my vehicles uses 0w20, so if i dont use then this 5w30 going to recycle center since i wont be using it for years.
Re: 2019 Sienna [Re: s2krunner] #5355787 02/20/20 05:40 PM
danez_yoda Offline
you can top off with 5w30 no problem.
just next time get an extra 5qt jug to keep in your stash. that will be good for 5 oil changes or 50,000 miles if you fillow the factory OCI.
Re: 2019 Sienna [Re: s2krunner] #5355805 02/20/20 05:54 PM
T
tiger862 Offline
T
Since you are in Texas I would use 5 qt jug 0w20 and one qt of 5w30. You could always use the 5w30 on lawn equipment.
Tiger862
2018 Grand Caravan
Re: 2019 Sienna [Re: s2krunner] #5355840 02/20/20 06:31 PM
PimTac Offline
Stick with the 0w20 and donate the 5w30 to someone who needs it.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 2019 Sienna [Re: s2krunner] #5355873 02/20/20 07:17 PM
E
edyvw Offline
E
Originally Posted by s2krunner
Hello all,
Thanks
I strictly use in my SIenna 5W30.
Those engines can run pretty much anything, and your manual does not say that you MUST stick to 0W20.
Same engines in Europe are recommended for 5W30 ACEA C3, which are borderline 5W40 oils.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: 2019 Sienna [Re: s2krunner] #5355909 02/20/20 07:50 PM
M
Mad_Hatter Offline
M
Why not just use it? It's not like your engines gonna blow up. Use the 5qts of 5w30 to 1qt of 0w20, you'll end up with a thin Xw30 (probably around a 9cSt 100c kv since it's a 10.3cSt unadulterated) or thick Xw20 at worst.
Re: 2019 Sienna [Re: s2krunner] #5355918 02/20/20 08:05 PM
Bryanccfshr Online Content
Online Content
Just use the 5w30, the engine will not know the difference.
My Tacoma runs great on 5w30,10w30 and 0w40
Same engine in a longitudal set up.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 2019 Sienna [Re: s2krunner] #5356076 02/20/20 11:03 PM
Thank you guys, i will just use them.
