Hello all. My first message in this forum, although I used the forum for information before.
I modded my diesel truck to have a different oil filtering system. I am currently using BT8851-MPG filter. When I searched, I saw another filter, BT8850-MPG, has the same diameter, same thread size. It also has "enough" gallon per minutes (20 gph) - this info is from my memory, I can't find the source for this. It has a little better micron rating I think (5 micron vs 8-10 micron).
From the document, it says not a replacement of each other. But I don't know exactly why.
Here's the info I found:
BT8850-MPG
Maximum Performance Glass Hydraulic Spin-on
Notes: Rated 1000 PSI minimum burst.
NOT interchangeable with BT8851-MPG.
Can be used with OB8711, OB8712, OB8720, OB8721, OB8722, OB8724, OB8726, OB8731, OB8732, OB8740, OB8741, OB8742, OB8743, OB8744, OB8745, OB8746 filter bases.
Fits: Case, Case-International, Caterpillar, Daewoo, Fiat-Allis, John Deere, Kawasaki, New Holland, Steiger, Thomas EquipmentReplaces: Case D94236; Caterpillar 9T5916; Fiat 73144499; John Deere RE34958
Thread: 1 3/8 -12
O.D.: 3 3/4 (95.3)
Height: 9 17/32 (242.1)
I.Gskt: [1] Included
BT8851-MPG
NOT interchangeable with BT8850-MPG.
Can be used with OB8711, OB8712, OB8720, OB8721, OB8722, OB8724, OB8726, OB8731, OB8732, OB8740, OB8741, OB8742, OB8743, OB8744, OB8745, OB8746 filter bases.Fits: Agco, Caterpillar, Cedarapids, Ford, Gehl, John Deere, New Holland, Vermeer, V.M.E., Volvo EquipmentReplaces: Agco 303506819; Caterpillar 1G8878; Cedarapids 451750014101; John Deere RE47313; New Holland 89821387; Vermeer 73113001; V.M.E. 110366077
Thread: 1 3/8 -12
O.D.: 3 3/4 (95.3)
Height: 9 19/32 (243.7)
What would you say why they can't be interchanged?
BT8850-MPG
Thread: 1 3/8 -12
O.D.: 3 3/4 (95.3)
BT8851-MPG
Thread: 1 3/8 -12
O.D.: 3 3/4 (95.3)
