Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
3+ weeks in, and no TP
by MrQuackers - 04/04/20 06:20 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
UOA, DexronVI, 26k miles, GM 6L80
by jetman - 04/04/20 05:37 PM
2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
northestPM, dgvu89, Kevin1987, Thetrashman33, YLK
71099 Registered Users
28 registered members (dishdude, FordCapriDriver, dervdave, bachman, ford46guy, 928, 1 invisible), 1,141 guests, and 21 spiders.
Topics303,612
Posts5,238,344
Members71,099
Caliper Boot Was Loose When Changing Pads #5355393 02/20/20 12:15 PM
F
Fitz98 Offline OP
F
Changing front pads and rotors on my 98 Expedition 4x4.
When I removed the caliper from the drivers side, the lower boot was not seated in the piston bore casting.
Here is a picture of the boots I am referring to. Keep in mind I removed both boots for inspection and cleaning. Only one was not seated properly upon removal of the caliper. They both seat with finger pressure and both can be removed without tools as well. The boots are in good condition still.
Is that how tight they are supposed to be, or should I be using some sort of sealant to secure the boot to the caliper housing?
[Linked Image]
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355403 02/20/20 12:30 PM
Chris142 Offline
Needs a caliper. See all that contamination on the pistons? When you push them back in thats going to cause problems.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355406 02/20/20 12:32 PM
K
kschachn Offline
K
I had that happen on my BMW a while back, to me the worst problem is the rust on those pistons. I can't imagine they will seal properly when you push them back into the caliper for the new pads.
I've never glued the boots into the caliper but I do make sure the groove is clean and that the boot is seated properly all the way around. Sometimes it is difficult to seat the boot and if it isn't completely in the groove it will definitely pull out as it has done in your picture.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Caliper Boot Was Loose When Changing Pads [Re: Chris142] #5355409 02/20/20 12:37 PM
M
MarkM66 Offline
M
What about pulling the pistons and cleaning them with a scotch-bright pad?
Re: Caliper Boot Was Loose When Changing Pads [Re: MarkM66] #5355419 02/20/20 12:44 PM
B
buck91 Offline
B
I have had excellent results doing this with my old Yamaha brakes. I used a very light brass brush on a dremel, though.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355422 02/20/20 12:48 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
The seal mounting surface is compromised. One path for water intrusion is on this sealing surface. This means you need new calipers.
I now pack a fair amount of silicone grease behind the dust boot, as well as buttering the bore surface with silicone, to give an extra measure of protection from moisture intrusion.
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355430 02/20/20 12:52 PM
F
Fitz98 Offline OP
F
You bring up a good point about the contamination on the piston. Perhaps that is the result of the loose dust boot.
AZ has a lifetime reman in stock for 50.00, so no reason not to replace, assuming quality of an AZ rebuilt caliper is OE quality...must be better than what I have now.
I had to replace my AZ passenger side after 5 years. Something happened that caused my inside pad to wear out before the outside pad that has the wear squealer on it.
I am thinking the caliper must have hung up on the mounting bracket or shims somehow, otherwise pad wear should have been even I would think, so not sure if that was a function of lubrication or a caliper failure.
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355434 02/20/20 12:55 PM
K
kschachn Offline
K
AZ has one in stock for 50.00, so no reason not to replace, assuming quality of an AZ rebuilt caliper is OE quality...must be better than what I have now.
Yes it is due to the loose boot. It's not just to keep dust out of the space.
As has been mentioned I'm sure you could pop out the piston and try cleaning it but on my BMW the rust was far worse making some big pits on the polished surface.
1994 BMW 530i, 252K
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355549 02/20/20 02:36 PM
Donald Offline
You can pull the pistons and try and wipe them clean. But you should not be cleaning them with an abrasive. The piston is plated and if there is rust then some of the plating is gone and it will not seal properly.
Rebuild caliper or replace.
2015 Ford F-250 w/Powerstroke
Re: Caliper Boot Was Loose When Changing Pads [Re: Fitz98] #5355848 02/20/20 06:45 PM
F
Fitz98 Offline OP
F
Thanks for the feedback. I wasn't considering of the condition of the pistons themselves, you gave me something to evaluate that otherwise would have been overlooked and I ended up replacing the caliper. Not expensive and easy to do, while I had it all apart anyways.
Thanks for the advice.
