Amber Alerts at 5am
by rekit - 04/08/20 03:16 PM
MC FL-910S cut open
by kstanf150 - 04/08/20 03:12 PM
Cartridge Weight Question
by Gebo - 04/08/20 02:54 PM
Auto insurance rate cut
by Wolf359 - 04/08/20 02:18 PM
Do you "correct" your service technician or not?
by SevenBizzos - 04/08/20 02:07 PM
How to keep glasses from fogging up?
by Chris142 - 04/08/20 01:58 PM
1.6 EB ,RL 5w20,18175 miles OCI,TAN>TBN
by ovidiu - 04/08/20 01:02 PM
cut ADBV in Mobil1 oil filter
by RavenTai - 04/08/20 12:55 PM
Oil shopping USA vs France
by M119 - 04/08/20 11:50 AM
Blackstone labs... open??
by researcher - 04/08/20 11:41 AM
Hyundai 2.4 Engine Issues
by Hallj49803 - 04/08/20 11:36 AM
Do old style centrifugal filters do anything?
by atikovi - 04/08/20 11:34 AM
NAPA oil deals
by Oildudeny - 04/08/20 11:17 AM
Oil weight spec thinning over time?
by MontePrix28 - 04/08/20 10:12 AM
High Performance Lubricants PDS
by High Performance Lubricants - 04/08/20 10:11 AM
13 Hyundai Sonata 24 vs 12 Jetta 2.0 TDI
by Hallj49803 - 04/08/20 10:09 AM
Mustang 4.6L spark plug change
by kstanf150 - 04/08/20 10:03 AM
Cutting Cable-Roku?
by PontiacHO - 04/08/20 09:59 AM
Mor gas price fun.
by Chris142 - 04/08/20 09:42 AM
LMVLS1, Jotorobi, jhoffy22, EcoBoosted, mmich187
71126 Registered Users
113 registered members (2015_PSD, 53' Stude, 762fermeandyou, 94astro, 77GrandPrix, 4WD, 9 invisible), 2,688 guests, and 16 spiders.
Topics303,776
Posts5,241,704
Members71,126
Buick Regal 2.0T Ecotec Engines #5355139 02/20/20 07:34 AM
E
ET16 Offline OP
E
How are these GDI engines, LHU and LTG?
I know that the 2.4 Ecotec has had problems, as have earlier Saab versions of this engines (soft intake valves).
Any problems here?
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355143 02/20/20 07:38 AM
T
Trav Offline
T
Saab 2007 and up the 06 and down were fine but had some chain issues. the 2.0T in the Buick doesn't have any of the older engine issues that I know of.
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355165 02/20/20 08:14 AM
B
beast3300 Offline
B
I've only seen VVT solenoid failures on them, but I believe there is special coverage for them.
'03 Regal GS L67: PPUP 5w30/FU3980
'03 Sable Duratec QS conv 5w20/NAPA Gold
'03 Lesabre Val PP 10w30/TG3387A
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355243 02/20/20 09:43 AM
W
WyrTwister Offline
W
I would guess any engine with cam phrases , be very diligent with frequent oil/filter changes , using good synthetic oil . Please correct me if I am wrong .
Also , if the engine has difficult to get to timing chains and associated parts .
Wyr
God bless
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355261 02/20/20 10:03 AM
ls1mike Offline
I have a LTG in Malibu 65,000 miles no issues. I know there are ones out there with a lot more. 2013 they did have some problems in the ATS but the pistons were upgraded and the initial run was fixed by GM.
Mine does not use any oil, but on average people who go 6000 miles or more an oil change will add make up oil. Plugs require replacement every 60,000 to 65,000 miles
Like any GDI they can suffer from LSPI or low speed pre ignition. I have not seen that on my car. It appears it happens more on the cars that run low grade fuel and run the oil longer than 7000 miles.
I change the oil in the my Malibu every 4000 to 5000 miles for those reasons. It is a 35 to 40 dollar oil change with Mobil 1 and Mobil 1 filter twice a year. I also always run premium in it. Not sure why you would run anything less in any turbo car.
The current run of 2.0 LTG engines don't really have any problems if you maintain them properly, meaning use Dexos approved oil in them. They are formulated to help prevent LSPI.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355262 02/20/20 10:03 AM
L
LotI Online Sleepy
Online Sleepy
L
The LTG has been a solid engine. It’s been around in Cadillac the longest, currently in the Camaro, Equinox...it’s everywhere. I have one now and it’s been solid for 18k miles. Like most new GM motors the oil pressure is regulated from the galleys, not the pump so make sure you use the correct filter with a 22psi bypass.
From GM’s (and others) cam chain failures in the 3.6l I am convinced that the OLM should not be followed for oil changes. 7-10k miles is way too long but it will get you through the warranty! The DIT motors put more soot and particulate in the oil and my LTG darkens the oil much faster than my previous cars, even a GTI with the ea888.
I change my oil in my LTG at 50% OLM which works out to 3750 miles. <$2/qt Clearance oil and PF64 filters for less than $3 means it’s a $15 DIY oil change with a top synthetic.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Buick Regal 2.0T Ecotec Engines [Re: WyrTwister] #5355275 02/20/20 10:10 AM
T
Trav Offline
T
Regular oil changes with these engines is an absolute must, a good Euro oil changed every 5K will keep them in good shape.
I see they moved the turbo to the front like the earlier engines instead of the rear, this should improve turbo cooling, right side CV axle boot life and possibly rack life.
Doing the chains is going to be a bit tight as with most horizontally mounted engines but doable unlike the earlier ones with cast iron block, that were a real bear.
Again changing the oil every 5K and not by the OLM will greatly increase chain life (GM shortened their OCI on the 3.6 because of this issue) and it may never need replacing. If they recommend xw20 in this forget it, a Euro higher HTHS oil is what they really need to survive long after the warranty has gone.
Edit when I say a Euro oil I mean like a dex2 oil eg Mobil1 0/5w30 (the last GM Europe spec for these engines) this has proven to keep the chain system in good condition in many cases over 200K.
Re: Buick Regal 2.0T Ecotec Engines [Re: Trav] #5355307 02/20/20 10:40 AM
ls1mike Offline
They recommend 5W-30 which is nice because I run Mobil 1 5W-30 in everything but the Trans Am which gets 10W-30 or whatever is laying around.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Buick Regal 2.0T Ecotec Engines [Re: ls1mike] #5355325 02/20/20 10:56 AM
T
Trav Offline
T
At least they didn't get silly and spec a thin oil for these engines. The LS1 TA engine of that vintage does well on a 10w30 IIRC.
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355428 02/20/20 12:51 PM
B
benjy Offline
B
everything made today has issues, more or less, many GM's have wheel bearing- hub issues + my girlfriends oil burning 13 malibu 2.5L was using over a qt in a thou when traded at just over 60 thou. turbo charged direct injected engines are more prone to carboning + their more costly when things go south! if you trade often + early as many do your ok, but looking for over a 100 thou good luck. checking vehicle specific forums can be a good idea for sure!
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355469 02/20/20 01:13 PM
E
edyvw Offline
E
Any problems here?
Probably oldest roots of any turbo engine today.
Original 2.0T was in Opel Calibra and Vectra A in 1991 having 204hp and 260nm. It was called widower as it was put in light chassis with undersized brakes and aerodynamic coefficient of 0.26cw which is absolute record for vehicle at that time. Developed originally by Cosworth and Opel. Probably best 2.0T engine of 1990's. Unfortunately, GM cost saving policies later made impossible for engineers to keep up with competition.
It should be stout engine, but nothing special. Should not have some infant issues like LSPI etc.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355486 02/20/20 01:28 PM
Malo83 Offline
LTG in my 17 Regal GS, only has 9K on the clock so she's still breaking in, 2 yrs of trouble free driving, run 91 fuel and do 5K oil changes, believe with the LTG all the fixes for the LHU, great little engine. cheers
https://gmauthority.com/blog/gm/gm-engines/ltg/
Re: Buick Regal 2.0T Ecotec Engines [Re: edyvw] #5355526 02/20/20 02:13 PM
T
Trav Offline
T
Any problems here?
You left some of the history for the generation most similar to the engine being talked about out. While it may be similar the original was an iron block engine.
Quote
Development began in 1994, by an international team of engineers and technicians from Opel's International Technical Development Center in Rüsselsheim, Germany, GM Powertrain in Pontiac, Michigan, and Saab in Södertälje, Sweden.[2] Much of the development work on this project was carried out by Lotus Engineering, Hethel, United Kingdom
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355590 02/20/20 03:12 PM
E
ET16 Offline OP
E
When did the LTG start in the Regal?
Re: Buick Regal 2.0T Ecotec Engines [Re: ET16] #5355598 02/20/20 03:17 PM
Malo83 Offline
2013, Caddy ATS and Chevy Malbu.
