Originally Posted by Omar_Eltahan
Originally Posted by Mad_Hatter
I don't know that you can remove sulfur from the fuel with a pour in treatment. I think it requires a catalyst of some kind during the refining process, but maybe I'm wrong and there's something out there that I've never heard of. Does Egypt not have standards for octane and low sulfur? Can you find a better fueling station that can provide low sulfur fuel? High SO2 in the exhaust stream is def' not good for the catalyst (noble metal), so I would get on top of this issue.
As for solids finding their way into your tank a fuel system cleaner won't do much about that. Again, find a reputable service station that changes their pump filters regularly and you keep an eye on your fuel filter so that the pump doesn't end up dying prematurely from working too hard because of a clogged filter.
You could use aftermarket octane boosters if you feel you're not getting the octane your car requires or Google toluene and fuel? You could dose your own fuel with a few ozs of toluene to raise your octane.
From BP for example 👇.. like I said, Google it for more info.
thanks for for replying. though, i probably confused people instead of clearing the situation ...
lets start over ....
i want to know if fuel system cleaners useful to clean the fuel system from carbon residuals over pistons, valves, injectors etc, .. or they are just marketing without efficiency??
Redline SI1. Marketing WITH sgificant efficiency.
